Fuel Drip Containment
Old October 26th 03, 07:07 PM
Jim Weir
Yes, I thought I said that I could slow it down, but not stop it. As you can
see, others (ad infinitum, ad nauseum) will tell you the simple physics of
parking an airplane with the outside fuel vent downhill.
"C J Campbell"
-Don't fill your plane before putting it away?
-We turn the fuel valve off or turn it to left or right tank -- this seems to
-mitigate the problem considerably, though I am not sure why it does this.
http://www.rst-engr.com
Old October 26th 03, 02:52 PM
MichaelR
Sporty's oil mat #8667A might work, but I use an open gasoline can on the
floor. There's usually not much wind in a hangar, so the drips will go right
in once it is positioned. The small opening in the can reduces the amount of
evaporation you would get compared to a mat or just letting it hit the
floor.
Afterward, I use the fuel to run my lawnmower.
Old October 26th 03, 07:18 PM
Jim Weir
That's a thought. You could enhance the probability that the gas would go into
the can by gluing a funnel into the VENT port on the can, or by simply drilling
a hole into the top of the can and epoxy-gluing the funnel into permanent
position. I like that idea even more, because the only evaporation THEN is from
the little tiny funnel hole...and you could go one step further and drill a cork
stopper with a smaller hole at the top of the funnel neck so the gas would pass
through, but the evaporation would be much less.
You guyzes is clever. Thanks.
"MichaelR"
-Sporty's oil mat #8667A might work, but I use an open gasoline can on the
-floor. There's usually not much wind in a hangar, so the drips will go right
-in once it is positioned. The small opening in the can reduces the amount of
-evaporation you would get compared to a mat or just letting it hit the
-floor.
-Afterward, I use the fuel to run my lawnmower.
Old October 27th 03, 03:24 AM
Jay Honeck
All this, and the solution is a gas can with a funnel stuck in it?
Geez, after this many days, I thought for sure you guys would come up with a
more "Jetson's-like" solution for Jim...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old October 27th 03, 02:59 PM
G.R. Patterson III
You forgot - he's gonna fill it with fuel cell foam. :-)
George Patterson
You can dress a hog in a tuxedo, but he still wants to roll in the mud.
Old October 27th 03, 06:19 PM
Montblack
("G.R. Patterson III" wrote)
.....after he puts a cement weight in the bottom of the can!!
Montblack
"Styled by the laws of nature.............Concorde"
Old October 28th 03, 12:38 AM
John Galban
"Jay Honeck" wrote in message news:ud0nb.38050$Tr4.78719@attbi_s03...
Well, back when I worked for Spacely Sprockets we used a gas can
with a built-in, nuclear powered, matter disintegrator (with a funnel
stuck in it).
Old October 27th 03, 04:30 PM
Jon Woellhaf
Hose slipped over vent and part way into can to insure no "drips" miss?
"Jim Weir" wrote in message
into
drilling
is from
a cork
pass
"MichaelR"
right
amount of
-floor.
Old October 27th 03, 03:50 PM
Jim Weir wrote:
: One thought is to provide a bucket with a nonflammable liquid lighter than
: gasoline. Let the gas drip into the bucket with a "blanket" of nonflammable
: liquid on top of it. The problem is finding such a liquid.
I looked around a bit, and finding the magic liquid looks tough.
According to this, however:
http://pump.net/liquiddata/wdspecgrav.htm
ammonia might work?
-Cory
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old October 29th 03, 03:21 PM
Kevin McCue
How about dripping into a coffee can of water w/dishsoap. Should
emulsify and mix w/the water. You could even add the funnel idea into the
plastic lid.
Kevin McCue
KRYN
'47 Luscombe 8E
Rans S-17 (for sale)
-----= Posted via Newsfeeds.Com, Uncensored Usenet News =-----
http://www.newsfeeds.com - The #1 Newsgroup Service in the World!
-----== Over 100,000 Newsgroups - 19 Different Servers! =-----
spaceship one Pianome Home Built 169 June 30th 04 05:47 AM
Fuel Drip Containment -- My Solution Jim Weir Home Built 4 November 1st 03 05:22 AM
Fuel Drip Containment Sven Home Built 28 October 27th 03 10:28 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 02:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
