Fuel Drip Containment -- My Solution
Old October 29th 03, 09:13 PM
Jim Weir
Default Fuel Drip Containment -- My Solution
I thought about this one for a while, and thanks to all of you who chimed in.
Between the lot of you, I came up to what is an optimal solution for me.
In the first place, I am clumsy. I can trip over my own shadow. If there was a
way for me to kick a can over and spill all the trapped gasoline, I would.
In the second place, I am one with Ron Natalie who opined that liquid gas is a
hell of a lot safer than gas fumes. The problem then is not to evaporate the
spill, but to contain it.
So down I goes to the local Auto Zone and there staring me in the face is a
small (5 quart) oil change drip pan -- the round "pancake" style. There in the
center of the pancake is a small round "oil drip" hole just made to put a funnel
into.
Viola. Problem solved. You can't kick over something that is a foot in
diameter and 2 inches tall. You have a capped pour spout at the end to pour the
liquid gas into your lawnmower. You could fill it with dishwasher soap and
water to emulsify the fuel if you wished. You could fill it with half a quart
of used oil and let the fuel absorb into the oil with a much lower flash point
and practically zero evaporation.
Thanks to all...
http://www.rst-engr.com
Fuel Drip Containment Sven Home Built 28 October 27th 03 11:28 PM
Yo! Fuel Tank! Veeduber Home Built 15 October 25th 03 03:57 AM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 08:09 PM
Fuel pressure Problems smf Home Built 3 September 7th 03 09:25 PM
Question ~ Does fuel injection add weight? Barnyard BOb -- Home Built 0 July 6th 03 10:47 PM
