#31
On Thursday, February 9, 2012 5:37:29 PM UTC-5, JohnDeRosa wrote:
... A FLARM transmitts and anything that Transmitts (transceiver, transponder) is THE variable and can be massive power hogs... Please, FLARM takes very little power ! For PowerFLARM, keep the backlight turned down to minimize draw... Thanks, Best Regards, Dave "YO electric" |
#32
On Feb 9, 8:37*pm, Dave Nadler wrote:
On Thursday, February 9, 2012 5:37:29 PM UTC-5, JohnDeRosa wrote: ... A FLARM transmitts and anything that Transmitts (transceiver, transponder) is THE variable and can be massive power hogs... Please, FLARM takes very little power ! For PowerFLARM, keep the backlight turned down to minimize draw... Thanks, Best Regards, Dave "YO electric" Please excuse anything demeaning to the FLARM. The only power requirement specifications I have found are in the PowerFLARM manual which says, "Supplied power must be 12 V DC nominal at 500mA". 0.5A is nothing to sneeze at but is probably the instantaneous maximum. Does someone have some real world power requirement information for the various (US) FLARMS? I have not found an online FLARM or PowerFLARM Brick manual (sources?). Thanks. |
#33
On Thu, 9 Feb 2012 14:37:29 -0800 (PST), JohnDeRosa
wrote: . A FLARM transmitts and anything that Transmitts (transceiver, transponder) is THE variable and can be massive power hogs so keep those on a separate battery A Flarm transmits at only 50mW power. The power consumption is negligible, always less than 100mA, and it includes a GPS engine capable of NMEA communication. A radio in receive-only mode, will use more power than a Flarm. And, if I were low on battery, Flarm is still the latest "switch-off" option, considering the benefits for safety. aldo cernezzi www.voloavela.it |
#34
On Thu, 09 Feb 2012 04:33:04 +0000, RAS56 wrote:
I enjoyed your article and just completed 2 test runs using the rig you detailed..I was mildly surprised to find 2 identical batteries with identical manufacture dates vary significantly on the results. Battery #1 took 4:13 to run down to 11.5 volts, at about 5:45 it hit the "knee" at 10.5V described in the article and started dropping rapidly. Battery #2 lasted almost an hour longer...5:10 to hit 11.5, then longer than 6:30 to get below 10.5V. Both batteries were 12V 7.5 AH SLA. I just did the same: bought a pair of Yuasa 12v 7Ah SLAs, call them D and E, because A, B and C dropped off their charge curves when tested during the week before last. A and B had also been bought together in 2008 and had both been measured at a bit over 6500 mAh then, but both were under 4000 mAh this time. I put them both the new batteries on my three phase mains charger to top them off as soon as they arrived. E took over an hour longer to top off. Then I measured them with a Pro Peak Prodigy II charger/cycler. E ran the device while I measured D. Then both went back on the mains charger and this time D ran the device while it measured E. Results: D was measured at 7003 mAh and E at 7510 mAh I was a little surprised at the difference since, with both batteries being the same model there's every change they're from the same batch. The Prodigy II isn't what you'd call a heavy duty discharger and self limited itself to 0.4A despite me being optimistic and asking for a 0.7A rate. IIRC it has a 5 watt discharge limit. I As this somewhat less current than we'd expect to use during a flight and all batteries show lower capacity the faster you discharge them and the colder they are. IOW this over-estimated the in-flight capacity due to the lower current and higher temperature during my test, but thats fine: I do the same tests at about the same time of year and am only interested in the relative drop in capacity from one year to the next. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Multiple Battery Setup | JohnDeRosa | Soaring | 0 | February 7th 12 04:01 AM |
tailwheel setup question | Dick[_1_] | Home Built | 2 | May 20th 08 11:20 AM |
Vario setup | brianDG303 | Soaring | 1 | April 3rd 08 05:20 PM |
FS 2004 setup | Dave Hetteen | Simulators | 4 | June 25th 04 10:40 PM |
WX Works setup | Paul Tomblin | Piloting | 16 | December 8th 03 04:23 AM |
