Multiple Battery Setup
Old February 3rd 12, 04:10 PM posted to rec.aviation.soaring
JohnDeRosa
Default Multiple Battery Setup
This came from a separate thread "Typo in Battery Article in Soaring"
On Feb 2, 10:11 am, Karl Kunz wrote:
John, also enjoyed your article and will try your technique on a couple of batteries I am unsure of. Also, since we have an EE on the line I wanted to ask about battery setups. My partner and I have installed some new toys in our ASW20 (transponder, etc) and are wondering what is the best way add more power. We are currently running a single 12v 9amp battery. Would it be better to add another 9amp battery or to go to a single higher capacity battery. If using two batteries, what is the best way to tie them together.
-karl
I suggest multiple batteries for a couple of reasons;
Redundancy - you can have a failure either in the air or on the ground
so with two batteries you have a spare.
Expense - I replace one of my batteries (I own 4 and fly with 2) every
year so over the course of four years I replace them all (the older
units are given to the club). While two 9ah batteries are more
expensive than a single 12ah battery, my yearly replacement cost is
less of a single time bite to the budget.
Size - You are probably set up for the 9ah size and a larger 12ah may
not fit. However, someone mentioned a 12ah to me that has the same
footprint as the 9ah only taller. Anyone seen this?
Weight - Is 2x9ah heavier than 1x12ah? Is that important? Hmmmm.
Power - 2x9ah has more energy capability than 1x12ah
Now, how to connect them? What I recomment is three runs of 14-16
gauge Tefzel wire between the batteries and the panel. This gauge is
overkill but I don't want any voltage drop with a smaller gauge. 3
runs = a common ground, battery 1 and battery 2. I use red (battery)
and black (ground) heat shrink to mark each run. I use PowerPole
connectors - very robust and secure.
At the panel I use three switches to run the batteries in parallel.
Battery 1 on/off, battery 2 on/off and then the output of both to a
master switch and then to the avionics. The thinking of separate
battery switches is that you can disconnect a "bad" battery. I always
have all three switches turned on during flight - the need to be able
to turn off a bad battery hasn't arisen for me and I am unsure how I
would even know (everything dies? smoke?). I do, however, have a
voltmeter, so I turn on/off each battery to see how they are doing (on
the ground typically).
Some people wonder that with both batteries connected to one another
in parallel, is there an issue with one battery charging the other?
Certainly cross charging happens (no two batteries are identical) but
unless one battery is significantly discharged from another, this
cross charging would be slight. I always swap out both batteries
right off the chargers at the same time to minimize this. Some
solutions suggest installing diodes in series to prevent this cross
charging but diodes "steal" 0.5v-0.8v of your voltage and every volt
counts in a glider. So I don't use diodes. Does anyone else?
Finally - ABSOLUTELY CRITICAL - install a fuse on each battery right
at the terminals. Not a breaker, a fuse. Fuses are faster than
breakers. This fuse is more important than fuses/breakers in the
panel.
My $0.02. Let me know how your testing turns out.
- John DeRosa
http://aviation.derosaweb.net
Old February 3rd 12, 06:13 PM posted to rec.aviation.soaring
Karl Kunz
John, you addressed all the issues we where concerned about. Thanks for some great info.
-karl
Old February 5th 12, 01:43 PM posted to rec.aviation.soaring
rk
master switch and then to the avionics. *The thinking of separate
battery switches is that you can disconnect a "bad" battery. *I always
would even know (everything dies? *smoke?).
You would know that by total power loss of all your batteries. You
have essentially parallel connection with all your batteries during
flight. When one fails, it drains your good batteries empty. When your
radio or computer starts blinking it's too late. Best option is to use
simple selector switch to choose one battery at time, and keep other
batteries disconnected.
rk
Old February 5th 12, 04:27 PM posted to rec.aviation.soaring
kirk.stant
rk
I've been using a somewhat different approach. Two batteries, each
powering half the avionics. So batt 1 has the radio and nav computer
bus; batt 2 has the logger/PDA and backup vario bus. Instrument
"busses" hooked up via individual 3 position switches so that either
buss can be powered by either battery or disconnected. Normally, run
the batts/busses independent, but have had occasions when one batt
went low early, and just switched the bus it was on to the other
battery for all instruments for rest of flight.
I also use the built-in voltmeters in various instruments (AR-4201,
SN10) to monitor the health of the batteries during flight.
Seems to work OK for the past 12 years...
Kirk
66
Old February 7th 12, 07:45 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
The 'split services' approach is much better than running
everything off 1 battery, and then switching to another. The
standard 7AH gel cell is rated at the 20hour discharge current -
about 300mA. Any higher current and the total energy available
decreases. (and that 7AH is a new battery at room temperature,
not a 2 year old one freezing at 18,000ft).
If you have room, paralleling batteries works well, so long as
you have another independent battery to run essential services
if the main one drops below 11V (for me vario/flight director
only, and radio when 5 minutes out on final glide).
parallel.
both to a
master switch and then to the avionics. =A0The thinking of
separate
battery. =A0I
alway=
s
to be able
unsure how I
would even know (everything dies? =A0smoke?).
You
during
When your
to use
keep other
rk
each
computer
Instrument
either
Normally, run
one batt
4201,
Kirk
66
Old February 7th 12, 08:48 AM posted to rec.aviation.soaring
rk
On 7 helmi, 09:45, Peter Purdie wrote:
* The 'split services' approach is much better than running
everything off 1 battery, and then switching to another. *The
about 300mA. *Any higher current and the total energy available
I see the point of using parallel batteries to achieve lower current
draw per battery, though you have basically no way to know or control
the current draw from each battery.
The main benefit of using one battery at time is that you allways know
exactly how good your batteries are. I use two batteries, usually one
battery is just enough for day's flying, if it's cold I might have to
use second one for an hour or two. After flight I charge it overnight
and next day use the second battery as my primary. This way cycles are
evenly split between batteries and running them empty on regular basis
gives me pretty good idea how healthy they are (bad batteries develop
symptoms long before they actual fail). Only failure I have had during
flight was parallel connected batteries with one of them failing and
draining the other one empty in two minutes. After that I have flown
no 5 years with three way selector switch, without a single glitch.
This is the way they do electrical systems in Schempp, Schleicher etc.
No need to invent wheel again, IMO.
Of course running batteries empty might shorten their life a bit, but
replacement cost is next to nothing (for 7 Ah lead gel). One more
thing, switching batteries doesn't power off my acionics. They have
some capacitors built into them too.
Old February 5th 12, 07:20 PM posted to rec.aviation.soaring
John Godfrey (QT)[_2_]
John, also enjoyed your article and will try your technique on a couple of batteries I am unsure of. *Also, since we have an EE on the line I wanted to ask about battery setups. My partner and I have installed some new toys in our ASW20 (transponder, etc) and are wondering what is the best way add more power. We are currently running a single 12v 9amp battery. Would it be better to add another 9amp battery or to go to a single higher capacity battery. If using two batteries, what is the best way to tie them together.
-karl
units are given to the club). *While two 9ah batteries are more
not fit. *However, someone mentioned a 12ah to me that has the same
footprint as the 9ah only taller. *Anyone seen this?
Weight - Is 2x9ah heavier than 1x12ah? *Is that important? *Hmmmm.
Now, how to connect them? * What I recomment is three runs of 14-16
gauge Tefzel wire between the batteries and the panel. *This gauge is
overkill but I don't want any voltage drop with a smaller gauge. *3
runs = a common ground, battery 1 and battery 2. *I use red (battery)
and black (ground) heat shrink to mark each run. *I use PowerPole
would even know (everything dies? *smoke?). *I do, however, have a
cross charging would be slight. *I always swap out both batteries
right off the chargers at the same time to minimize this. *Some
counts in a glider. *So I don't use diodes. *Does anyone else?
at the terminals. *Not a breaker, a fuse. *Fuses are faster than
breakers. *This fuse is more important than fuses/breakers in the
panel.
My $0.02. *Let me know how your testing turns out.
- John DeRosahttp://aviation.derosaweb.net
I've been using very low loss Schottky diodes (95SQ015 - Vf stays at
about 0.2v @ 1A last I checked) to run all my batteries (sometimes 4)
in parallel. Increased AH capacity from parallel operation offsets Vf
and provides isolation of a misbehaving battery. Absolutely fuse at
the battery terminals with fuse sized appropriately for the size/
length of conductor. Comments welcome.
QT
Old February 5th 12, 07:24 PM posted to rec.aviation.soaring
Bart[_4_]
counts in a glider.
Ideal diode, such as LTC4358, would eliminate the voltage drop at the
cost of higher complexity.
Bart
Old February 6th 12, 04:47 AM posted to rec.aviation.soaring
JohnDeRosa
QT
Bart
First, a teaching moment for those non-techies about using diodes to
isolate two battery setups so that a bad battery won't suck the life
out of the good battery, see
http://aviation.derosaweb.net/presen...iring_2007.pdf
(page 21-25) for some explanations.
While I know about Schottky diodes and their low forward voltage drop
(0.2v which seems like the best of the diode worlds) but I had not
heard of the Ideal Diode which seems custom made for our application
of two battery sources and if one dies the other takes over. Good to
5A. What's not to like? But what is the critical forward voltage
drop? I read;
"The internal MOSFET turns on and the amplifier tries to regulate the
voltage drop across the IN and OUT connections to 25mV. If the load
current causes more than 25mV of drop, the MOSFET is driven fully on
and the voltage drop is equal to RDS(ON) x ILOAD."
25mv? GREAT NEWS!
RDS(ON) x ILOAD = 20milli-ohm x 5A = 0.1 volt. Better than a
Schottky. WHOOP!
(BTW: the small m for milli instead of big M for mega tripped me
up)
But then in the Specs Table I read;
ÄVSD Source-Drain Regulation Voltage (VIN - VOUT) 1mA IIN 100mA
l 25 mV (Typ)
ÄVSD Body Diode Forward Voltage Drop IIN = 5A, MOSFET Off l 0.8 V
(Typ)
So aren't we back to a silicon diode like forward drop? OK, when the
MOSFET is ON then we are back to the 0.1 volt. Interesting.
Lousy SM packaging for our application though. Bart - How are you
mounting it? Pictures?
Old February 6th 12, 06:27 AM posted to rec.aviation.soaring
Bart[_4_]
* *ÄVSD Source-Drain Regulation Voltage (VIN - VOUT) 1mA IIN 100mA
l 25 mV (Typ)
* *ÄVSD Body Diode Forward Voltage Drop IIN = 5A, MOSFET Off l 0.8 V
(Typ)
So aren't we back to a silicon diode like forward drop? *OK, when the
MOSFET is ON then we are back to the 0.1 volt. * Interesting.
The 0.8V voltage drop is for the "body diode" of the internal MOSFET:
http://en.wikipedia.org/wiki/Power_MOSFET#Body_diode
In other words, that's the drop you will get if the controller dies,
or if the input voltage drops below 9V.
Lousy SM packaging for our application though. *Bart - How are you
mounting it? *Pictures?
I have never used one in a glider. If I were to, I would put the two
chips on a small PCB and cover it with heatshrink. Something like
this: http://i00.i.aliimg.com/img/pb/905/8...834905_364.jpg
Actually, if I find time, I can make a prototype within a week or two.
Then Karl can test it if he wants to :-)
Bart
Multiple Battery Setup JohnDeRosa Soaring 0 February 7th 12 04:01 AM
tailwheel setup question Dick[_1_] Home Built 2 May 20th 08 11:20 AM
Vario setup brianDG303 Soaring 1 April 3rd 08 05:20 PM
FS 2004 setup Dave Hetteen Simulators 4 June 25th 04 10:40 PM
WX Works setup Paul Tomblin Piloting 16 December 8th 03 04:23 AM
