First NASA form filed
Old August 23rd 04, 06:52 PM
OtisWinslow
I don't see that you technically did anything wrong. A clearance to taxi
to someplace on the airport would clear you across any runways except
if that clearance was to taxi TO a runway .. then you couldn't cross it
to get to the departure end without specific clearance. Normally they'll
tell you to hold short of a runway if they want you to. Such as "taxi to
the ramp .. hold short of runway 33". Now that said I never cross
a runway without a simple "confirm Nxxxxx is cleared across runway xx."
I've never had a controller get testy over it and would imagine they
appreciate the heads up with all the emphasis on avoiding runway incursions.
"Paul Folbrecht" wrote in message
news
And I sincerely hope it will be the last.
I landed at LSE (LaCrosse) on the way home from the twin cities last
week. I landed on 18 and asked for a progressive taxi to the FBO,
having never been there before. Controller told me to turn left on
taxiway bravo down to the construction cones at the end.
As I was taxiing, I was about to cross 21, then recalled that the ATIS
had called 18 and 21 as active. I stopped, hard, but my nosegear was
over the hold line - in fact my mains were pretty much on the hold line.
I think it's important to note that the controller had not told me to
hold short of 21. If she had, then obviously this would have been a
pretty flagrant violation.
After a split second of uncertainty I told tower I was holding at 21.
She immediately told me to continue past in the chipper tone she had
been using all along. Note that nobody had landed on or departed 21
during the entire time of my taxi so there was no loss of separation.
I do believe that it was my responsibility to hold short of 21 even
though no explicit instruction had been given, though I'm not 100% sure
of that (but in the future I'll be damn sure to in similar
circumstances!). And, unless the controller deliberately wanted to make
me believe nothing was wrong for some reason, I believe she either
didn't notice I was over the hold (this intersection is pretty close to
the tower) or didn't care. Her voice indicated nothing out of the
ordinary, as I said. I know they don't 'have to' ask you to call the
tower or let you know they're making a report, though.
Though the logical side of my brain tells me that the chances of some
enforcement action here would be slim, of course I filed the form
regardless. I'd be interested in hearing people's opinions on that
matter (the chance of some investigation).
  #32
Old August 23rd 04, 08:29 PM
David Brooks
"Bob Gardner" wrote in message
At the "Communicating for Safety" conference put on by NATCA in Dallas, I
got the impression that there is a lot of controller sentiment in favor of
changing the AIM's laissez faire approach to crossing runways enroute to
departure runway.
At least since I moved up there in 2000, the controllers at PAE have always
included "cross 11" when their taxi instructions require us to cross 11/29
on the way to an intersection takeoff (such as from most of the hangars to
A4 on 16R/34L).
However, now the thread has brought up the emphasis on "enroute to the
departure runway"... does that mean a taxi instruction from the same runway
intersection back to the same parking does *not* imply a clearance to cross
intervening runways? That hadn't occurred to me before, and seems to
compound the confusion.
-- David Brooks
  #33
Old August 24th 04, 12:56 AM
Paul Folbrecht
I take it from your reply that you _are_ a controller - I did not
realize that. Obviously, you know better than I what controllers pay
attention to and what they don't.
Newps wrote:
Paul Folbrecht wrote:
Seems to me that they certainly
ought to - these are the official demarcations of the runway, right,
I am only interested in what happens within the white lines. You roll
over the hold short line by an airplane length it doesn't change what I
do one iota, as long as you remain outside the white lines.
and
*part* of the responsibility of controllers is to enforce the FARs
Enforcement is FSDO's job. The only time ATC helps out is if a loss of
separation occurs or some other near dangerous thing happens. If
controllers called FSDO everytime you bend an FAR there would be tens of
thousands of cases each year.
  #34
Old August 24th 04, 01:25 AM
Ron Rosenfeld
On Mon, 23 Aug 2004 12:29:09 -0700, "David Brooks"
According to the AIM, it *DOES* imply a clearance to cross all intervening
runways:
"In the absence of holding instructions, a clearance to "taxi to" any
point other than an assigned takeoff runway is a clearance to cross ALL
runways that intersect the taxi route to that point." (emphasis mine).
--ron
  #35
Old August 24th 04, 01:34 AM
BllFs6
runways:
--ron
Well...I guess there COULD be the danger of MORE than one way to get from here
to there.....one the controller is thinking that is OKAY given the directions
they have given OTHER pilots....and the one the pilot takes not quite knowing
the big picture or where exactly they are going
take care
Blll
  #39
Old August 24th 04, 05:39 PM
David Brooks
"Ron Rosenfeld" wrote in message
runway
cross
runways:
Ah, yes. Should have read on to paragraph 6. Back to your regular scheduled
misunderstandings.
NASA Jet Might Have Hit Record 5,000 Mph Garrison Hilliard Military Aviation 0 March 28th 04 04:03 PM
Zero - specific questions N-6 Military Aviation 30 November 21st 03 02:44 AM
Runway Incursion and NASA form Koopas Ly Piloting 16 November 12th 03 01:37 AM
Runway Incursion and NASA form steve mew Piloting 0 November 10th 03 05:37 AM
Moving violation..NASA form? Nasir Piloting 47 November 5th 03 07:56 PM
