NASA Jet Might Have Hit Record 5,000 Mph
Old March 28th 04, 04:03 PM
Garrison Hilliard
Default NASA Jet Might Have Hit Record 5,000 Mph
By ROBERT JABLON
Associated Press Writer
cmLOS ANGELES (AP) -- Three years after its first test flight ended in an
explosion, NASA on Saturday successfully launched an experimental jet that the
agency believes reached a record-setting speed of about 5,000 mph.
The unpiloted X-43A made an 11-second powered flight, then went through some
twists and turns during a six-minute glide before plunging into the Pacific
Ocean about 400 miles off the California coast.
"It was fun all the way to Mach 7," said Joel Sitz, project manager at NASA's
Dryden Flight Research Center.
Flight engineer Lawrence Huebner said preliminary data indicated the
needle-nosed jet reached a maximum speed of slightly over seven times the speed
of sound, or about 5,000 mph, after a rocket boosted it to about 3,500 mph.
Huebner said it was the first time an "air-breathing" jet had ever traveled so
fast. The rocket-powered X-15 reached Mach 6.7 in 1967.
"It's a great way to end, certainly all the sweeter because of the challenges
we've had to step up to and overcome through the life of this project," said
Griffin Corpening, Dryden's chief engineer on the project.
The first X-43A flight ended in failure June 2, 2001, after the modified Pegasus
rocket used to accelerate the plane veered off course and was detonated. An
investigation board found preflight analyses failed to predict how the rocket
would perform, leaving its control system unable to maintain stable flight.
NASA built the X-43A under a $250 million program to develop and test an exotic
type of engine called a supersonic-combustion ramjet, or scramjet.
In theory, the air-breathing engine could propel an airplane to speeds of Mach 7
or faster, enabling around-the-world flights that would take several hours. The
Department of Defense also is working on the technology, which it's eyeing for
use in bombers that quickly could reach targets anywhere on the globe.
The 12-foot-long, 2,800-pound X-43A was mounted on a Pegasus rocket booster and
carried to an altitude of 40,000 feet by a modified B-52 bomber, which took off
from Edwards Air Force Base in the high desert.
A few seconds after the craft was dropped, the rocket flared, sending the jet
skyward on a streak of flame and light. At about 100,000 feet, the rocket
dropped away.
The scramjet took over, using up about two pounds of gaseous hydrogen fuel
before gliding. Applause rang out in the control center at Dryden Flight
Research Center at Edwards.
Technological hurdles mean it will be decades before such a plane could enter
service. And NASA's role in developing the technology remains in doubt, as the
agency recently cut funding for more advanced versions of the X-43A.
Engineers have pursued scramjet technology because it could allow rocket-speed
travel but with considerable savings in weight. Rockets must carry their own
oxygen to combust the fuel they carry aboard; scramjets can scoop it out of the
atmosphere.
In scramjets, oxygen is rammed into a combustion chamber where it mixes with
fuel and spontaneously ignites. To work, the engine must be traveling at about
five times the speed of sound - requiring an initial boost that only a rocket
can provide.
A third X-43A could fly as early as the fall.
Bush's guard record JDKAHN Home Built 13 October 3rd 04 09:38 PM
F-106 Speed record questions.... David E. Powell Military Aviation 67 February 25th 04 06:13 AM
What is the safety record of the F-102? Guy Alcala Military Aviation 1 February 22nd 04 04:41 AM
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
For the record: I am not BWB Larry Smith Home Built 82 January 11th 04 04:06 AM
