LED / Nav lights
Old April 6th 04, 06:59 PM
Greg Reid
FYI, here's another site for pre-made LED position lights:
http://www.periheliondesign.com/ledlights.htm
He has a Luxeon Star Portable 5.6W white tail-light too. (Might be
prohibitively expensive for many, tho'. These Luxeon's aren't cheap!)
(Again, for the record, I have no financial interest, blah blah blah.)
Greg Reid http://www.DivorceMagazine.com/Vision132
  #32
Old April 9th 04, 02:36 AM
Scott Gettings
Actually, a 3w luxeon is less than $20 -- more than enough for any tail
light. The other $130 goes to the guy. Get a surplus housing and drop
in an LED!
(Also no financial interest).
Scott Gettings
  #33
Old May 9th 04, 06:40 PM
Pete Schaefer
"Ernest Christley" wrote in message
m...
Scott Gettings wrote:
Glad you guys found this useful.
Our DAR says that they don't make specific demands regarding how
something is
done, so LEDs are fine as long as they are bright enough and have the
necessary
visibility pattern. He saw no problem whatsoever using LEDs for these
lights.
I noted in one of my aviation mags that Whelen has a $700+ vertical
stab. LED
strobe light! Probably doesn't include the power supply. This is
obscene and
could easily be done with a set of Luxeon 5-watt white LEDs in a
circular pattern.
Some 3-rd parties are trying to market various combinations, but unless
you need
very special hardware, you can just make these yourself at a fraction of
the cost.
You can actually make them much cheaper without the Luxeon and get the
pattern closer to the FAA spec. Buy the LED's from SuperBright LED
(sorry, can't remember the website). Their website will show the light
patter makes for each of the LED's and how much power they put out. The
FAR's specify how much light must shine where. Pick out the LED
combinations that will put the right amount of light in the right places.
Take a piece of 1/4" plexiglass. Drill holes that will be a tight fit
for the LEDs at angles that will point them where they should shine.
Push the LEDs into the holes, solder some resistors directly to the
leads, and pot the backside of the whole thing. You have a solid chunk
of plastic that will blind you at night if you put 12V across it.
http://www.ernest.isa-geek.org/
"Ignorance is mankinds normal state,
alleviated by information and experience."
Veeduber
Panel Lights Dimmer MII Driver Home Built 3 April 3rd 04 01:56 AM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
What are you guys using for cockpit lights these days? Stealth Pilot Home Built 6 December 9th 03 09:14 AM
LEDs with Strobe lights pekka1510 Home Built 11 August 31st 03 11:36 PM
LED for position lights Jerry Springer Home Built 2 August 19th 03 01:43 AM
