Emergency Exit
Old June 27th 18, 03:39 PM posted to rec.aviation.soaring
Dan Marotta
Default Emergency Exit
Not to change Dave's thread on leaving the Arcus, I was intrigued by
Francois' mention of the slippery cockpit floor in the front cockpit of
the Numbus 4DM.Â* I've noticed that in most single seaters I've flown and
I'm happy to say that my Stemme is fully carpeted to the forward
bulkhead which makes for better traction when climbing out. It still
takes a lot of upper body strength and, at 70 years old, I'm working out
3 days per week to try to keep some of that.
Everyone, please make every exit after a flight a simulated exit. Locate
those jettison handles, but don't actuate them.Â* Raise the canopy
normally and then bail out.Â* Release that belt, rise up, and roll over
the side.Â* You should have enough slack in oxygen and water hoses to not
stretch them.Â* But please practice!
Dan, 5J
Old June 27th 18, 05:14 PM posted to rec.aviation.soaring
Dave Walsh
intrigued by
cockpit of
I've flown and
forward
out. It still
working out
exit. Locate
canopy
roll over
water hoses to not
Dan, 5J
Or, of course, you could just fly a DG with their NOAH
system? It seems a pity that more manufacturers do not
offer NOAH given the age of many pilots...
I had one in a DG808C and although I never had cause to
use it I miss it.
Dave W
Old June 28th 18, 04:40 PM posted to rec.aviation.soaring
kirk.stant
Remember that if you still have an elevator, you may still be able to use negative G to get out of the glider: Jettison canopy, unstrap, the push the stick forward HARD and you should pop right out. If you have time you could even run the trim full forward.. ;^)
Might not work in a spin, but would probably work well in a wind-up hi-speed spiral.
Used a lot during WW2, there is even gun camera film of pilots "popping" out of their cockpits while under attack.
Kirk
Old June 29th 18, 05:13 PM posted to rec.aviation.soaring
use it I miss it.
Dave W
Were there any downsides to the NOAH system in day to day use of the glider - comfort, thickness of the inflatable bag, space for the gas cylinder (I presume there is a cylinder) etc?
John Galloway
Old June 29th 18, 06:51 PM posted to rec.aviation.soaring
Dave Walsh
to
use it I miss it.
Dave W
cylinder (I
John Galloway
No, no downsides to the system in daily use. There is one
extra cable to the pilots seat harness buckle; not really a
problem. There is also the "bag", un-inflated of course,
beneath the seat cushion, again no problem. In use this bag
is inflated by a gas bottle permanently fixed to the airframe
(in the DG it's behind the seat/oxygen bottle). The whole
system just requires the pilot to pull one handle.
There are of course maintenance and inspection costs, I
think the tank and the bag have a 10 year life?
In the unlikely event the pilot activates the system without
jettisoning the canopy the bag deflates. Plenty of detail and
videos on DG's website; just search NOAH.
The DG8800 designs have low cockpit walls. Some gliders
have significantly higher cockpit walls; I'd rate the rear seat
of a DuoDiscus as significantly more difficult to get out of
than a DG800; the front Duo seat is more difficult too.
For the older pilot I think NOAH might be a life saver.
Dave W
Old June 29th 18, 07:17 PM posted to rec.aviation.soaring
to
use it I miss it.
Dave W
cylinder (I
John Galloway
Dave W
Obviously in the case of accidental activation it is good that the Noah airbag deflates rapidly but I I guess that means that if you do activate it in an emergency and for some reason you don't get out of the cockpit immediately then the benefit is lost. Unlikely I know.
Old June 29th 18, 09:16 PM posted to rec.aviation.soaring
Dave Walsh
Dave=20
NOAH=20
not=20
cause=20
to=20
use it I miss it.
Dave W
to=20
gas=20
cylinder (I
John Galloway
one=20
a=20
course,=20
bag=20
airframe=20
whole=20
=20
I=20
=20
without=20
and=20
=20
gliders =20
seat=20
of=20
=20
=20
Dave W
the Noah
air=
activate it
in=
the cockpit
immediat=
Look at the videos on DG's site: you'd be hard put to remain
in the cockpit when the bag inflates!
Dave W
Old June 29th 18, 09:41 PM posted to rec.aviation.soaring
Mike Schumann[_2_]
to
use it I miss it.
Dave W
cylinder (I
John Galloway
Dave W
Why not just install a ballistic recovery chute in the glider? That's a lot cleaner solution and saves your butt at a lot lower altitude than bailing out.
Old June 30th 18, 03:27 AM posted to rec.aviation.soaring
Because "just installing" a ballistic recovery chute for a particular airframe takes a very large amount of structural analysis, determination of proper attach points, modification of the fuselage for installation of the rocket extraction system, blow-off panels to allow for chute extraction, actuation cable routing, FAA approvals for certified aircraft or approvals from an IA to determine the feasibility and installation of a system that very few certified aircraft mechanics (IA or A&P) have any familiarity with. This also applies to sailplanes certified as Experimental.
It's not just strapping a pack to your glider. It is WAY more complex and has to be done right.
I started flying hang gliders with a Ballistic Recovery System (BRS) in 1993. I have had two systems from BRS Inc. and one gas propelled unit from (now defunct) Second Chantz. Never had to actually use either one, but I see the advantages for sailplanes. Unfortunately, the mechanics and complex design issues pretty much eliminate practical retrofits to existing airframes.
It is sad that sailplane manufacturers do not seem to be interested in providing the guidance and engineering to incorporate ballistic recovery systems in current designs.
The only glider I know of that has a factory installed BRS system is the TsT-14 Bonus, which operates in the US with a Desert Aerospace installed retractable jet engine capable of self launch and in-flight engine extension and startup. (www.desertaerospace.com)
There may be other sailplanes incorporating ballistic recovery systems, but I have no knowledge of them. If there are others, perhaps RAS participants can offer their input.
Old June 29th 18, 09:42 PM posted to rec.aviation.soaring
I believe there is also a cable to the canopy jettison lever, you can't "fire the NOAH" until it's armed by dumping the canopy.
Air exit vent with engine box? [email protected] Soaring 5 December 8th 15 04:14 AM
An elegant exit Frank Whiteley Soaring 2 May 15th 09 02:28 PM
Accident report - PDA's can restrict emergency exit Ramy Soaring 21 December 31st 06 05:45 PM
How do you exit a F-22 cockpit? John Dallman Naval Aviation 1 May 28th 06 02:51 PM
How do you exit a F-22 cockpit? Mike Naval Aviation 11 May 25th 06 08:01 PM
