#31
#32
![]() "Steve B" wrote in message ... I believe that the shoulder restraints are recommended to be anchored no more than 5 degrees below the shoulder and 30 degrees above the shoulder in a vehicle IIRC. In a glider I would think that the reclined position would change the dynamics of the restraint. Because of the reclined position I would think that there would be less of a tendency to compress the spine when the shoulder straps are under a load. Is the 5th strap and submerging the issue? Would a low anchor point help with the upward motion of the pilot? How would a low anchor point respond with a reclined seating position in a crash? Sounds like keeping your head intact is a primary concern and spine is secondary? So I am thinking 2nd set of straps with a low anchor point (for head to canopy interference) and the standard straps to keep from submerging (family jewels to 5th strap interference). Steve snip some stuff Okay, how about this: Below the adjusters on each of the shoulder straps, sew an extra strap. They should be long enough to go over your shoulders and Y together somewhere in the vicinity of the small of your back. A single strap continues down from there, through a slot in the seatpan, to a low anchor point. It continues through the rear low anchor point to a front low anchor point, where it becomes the crotch strap. Now tightening the crotch strap will also pull down on your shoulders. The low anchor point shouldn't compress your spine, because the rear low anchor point should be in front of your shoulders. Because the additional straps pull your shoulders down and forward, you can't slide up and back along the normal shoulder straps to bump your head. Because it's adjustable, it should fit more than one pilot. There's extra strap, but the same number of adjusters, so it shouldn't be too expensive. Obviously, a similar scheme could be used with two straps under the seat pan in a 6-point harness arrangement. Tim Ward |
#33
Mark James Boyd wrote:
Here's a wierd idea: Get longer wings. If the wings hit an updraft, they will go up, and flex, but the fuselage won't go up right away, kind of a "shock absorber." Then the wings will reflex, giving extra thrust, and dissipating the G's. A few oscillations later and you'll feel real queasy, but you'll have more glide and less G's. Better all around, right? OK, a bit off thread, but has anyone modeled this (dynamic) interaction? Sure sure, we know about best glide, but what about the effect of long wings flapping like a seagull in turbulence? You don't have to go to long wings to enjoy this effect, but just buy an ASW20 ("A" or C model, though the B was relatively flexible, too)! A lot of 20 owners thought/think that the 20 did well in dolphin flight because of this, compared to the stiff winged Ventus, but it might be the Ventus just had separation problems near the root, unrelated to wing stiffness. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA |
#34
![]() "Eric Greenwell" wrote in message ... Mark James Boyd wrote: Here's a wierd idea: Get longer wings. If the wings hit an updraft, they will go up, and flex, but the fuselage won't go up right away, kind of a "shock absorber." Then the wings will reflex, giving extra thrust, and dissipating the G's. A few oscillations later and you'll feel real queasy, but you'll have more glide and less G's. Better all around, right? OK, a bit off thread, but has anyone modeled this (dynamic) interaction? Sure sure, we know about best glide, but what about the effect of long wings flapping like a seagull in turbulence? You don't have to go to long wings to enjoy this effect, but just buy an ASW20 ("A" or C model, though the B was relatively flexible, too)! A lot of 20 owners thought/think that the 20 did well in dolphin flight because of this, compared to the stiff winged Ventus, but it might be the Ventus just had separation problems near the root, unrelated to wing stiffness. -- Change "netto" to "net" to email me directly Eric Greenwell Washington State USA Now THAT's interesting. My stiff carbon winged Nimbus 2C isn't worth a damn at dolphin flight. I've wondered why. BTW, I wasn't flying the Nimbus when I got hammered by the wave rotor. I'm afraid to fly it in rotor conditions with empty wing tanks as I would have to do for high wave flight. Bill Daniels |
#35
![]() "Mark James Boyd" wrote in message news:41b8925c$1@darkstar... Here's a wierd idea: Get longer wings. If the wings hit an updraft, they will go up, and flex, but the fuselage won't go up right away, kind of a "shock absorber." Then the wings will reflex, giving extra thrust, and dissipating the G's. A few oscillations later and you'll feel real queasy, but you'll have more glide and less G's. Better all around, right? OK, a bit off thread, but has anyone modeled this (dynamic) interaction? Sure sure, we know about best glide, but what about the effect of long wings flapping like a seagull in turbulence? This does NOT seem to be the same kind of thing Gary Osaba does in the Sparrowhawk or Carbon Dragon (with super stiff wings), but it seems related... Any long-wingers care to comment? I thought you guys with short stiff ones already knew that us blokes with long floppy ones got all that extra go from the flapping motion. :-) Ian ( 25.5 metres ) |
#36
My 4-point belts were as tight as I could get them but they still didn't
do enough to keep my head from hitting the canopy. Is it a matter of having no further travel in the adjuster, i.e. the adjuster stopping against a fold or stitch? Are the belts simply too long? I've had that problem (in regular turbulence... I've never been in rotor) after a bigger person had used the ship. Fortunately in the Blanik L13, the other end of the belt is also adjustable for length - don't know about yours. Or are they sufficiently short, i.e. stopping your shoulders from moving upward at all, but your head and neck are able to stretch upward to the point that your head hits? If that's the case, it seems to me that solid shoulder bars would not perform any better than straps. |
#37
Eric Greenwell wrote:
Mark James Boyd wrote: Here's a wierd idea: Get longer wings. If the wings hit an updraft, they will go up, and flex, but the fuselage won't go up right away, kind of a "shock absorber." Then the wings will reflex, giving extra thrust, and dissipating the G's. A few oscillations later and you'll feel real queasy, but you'll have more glide and less G's. Better all around, right? OK, a bit off thread, but has anyone modeled this (dynamic) interaction? Sure sure, we know about best glide, but what about the effect of long wings flapping like a seagull in turbulence? You don't have to go to long wings to enjoy this effect, but just buy an ASW20 ("A" or C model, though the B was relatively flexible, too)! Or a Pegase of the first series, which had soft wings. This is indeed comfortable in gusty air. -- Michel TALON |
#38
#39
At 05:30 10 December 2004, Tango4 wrote:
I thought you guys with short stiff ones already knew that us blokes with long floppy ones got all that extra go from the flapping motion. :-) Ian ( 25.5 metres ) Now that is impressive :-) Don (20 metres) |
#40
Don Johnstone wrote:
Ian ( 25.5 metres ) Now that is impressive :-) Don (20 metres) I always believed that size didn't matter? Stefan (23 cm) |
