seat belts and restraints
Old December 8th 04, 05:21 PM
Bill Daniels
Default seat belts and restraints
I know there has been long threads about belts, 4-point, 5-point etc... I
still think there is more that needs to be discussed.
I am nursing a stiff neck from repeatedly banging my head against the canopy
on a particularly violent encounter with wave rotor yesterday. The tow
pilot is also nursing bruises from banging around in the Pawnee cockpit.
After release, I got rolled and pitched past the vertical several times - it
was that rough. I started to think that I might get knocked out if my head
hit the canopy any harder. To make things worse, I still didn't contact the
wave.
My 4-point belts were as tight as I could get them but they still didn't do
enough to keep my head from hitting the canopy. 5-point belts would have
helped, but probably not enough.
I'm starting to think about a pair of short arms that swing down over the
pilots shoulders and lock in that position. The idea is to provide an
additional, robust restraint to prevent the pilots head from hitting the
canopy. Opening the canopy would release the locks so the arms would spring
up and back out of the way.
Bill Daniels
Old December 8th 04, 06:57 PM
Vaughn Simon
"Bill Daniels" wrote in message
news:rKGtd.730764$8_6.17288@attbi_s04...
spring
Wouldn't a bicycle helmet be much simpler and lighter?
Vaughn
Bill Daniels
Old December 8th 04, 07:12 PM
Bill Daniels
"Vaughn Simon" wrote in message
spring
I've never seen one that was small enough to fit under the canopy. Anyway,
that doesn't protect your neck.
Bill Daniels
Old December 8th 04, 07:57 PM
Hi,
I use a Tilley Hat. It has a 1/8" dense foam on top. IT help some but I
dont know about rotor turbulence. Tom Knauff sell them.
S6
over
provide an
hitting the
would
spring
Anyway,
Bill Daniels
Old December 8th 04, 10:31 PM
Jim Vincent
Hi,
S6
Another trick is to just put a piece of foam in your hat.
Jim Vincent
N483SZ
illspam
Old December 8th 04, 11:05 PM
Bill Daniels
OK, how does this save your neck or avoid breaking the canopy? Isn't it
better to avoid hitting the canopy in the first place?
Bill Daniels
"Jim Vincent" wrote in message
Hi,
S6
Jim Vincent
N483SZ
illspam
Old December 9th 04, 12:07 AM
Jim Vincent
Bill,
It'll reduce the chances of breaking the canopy since the foam softens the
impact. As far as saving your neck, have you tried scootching down in the seat
or getting a thinner chute?
Jim Vincent
N483SZ
illspam
Old December 9th 04, 01:02 AM
BTIZ
I remember an article somewhere.. can't find it.. the 5 point in a glider
really only keeps you from submarining under the lap belt in case of a
landing accident as you rush forward from a rapid stop..
although there is some credence that the 5th strap will help keep the center
of the seat belt low on your waist/hips.. and hold your hips down, but it's
the shoulder straps that keep your head off the canopy.. your body still
articulates around your waist when you hit that bump that puts your head on
(or into) the canopy
BT
canopy
it
head
wave.
do
spring
Bill Daniels
Old December 9th 04, 01:06 AM
Bill Daniels
Bill,
seat
Jim Vincent
N483SZ
illspam
Even cushioned blow will break a canopy if it flexes the plastic enough. I
have a thin 'chute and I had reached my scrootchability limit.
Bill Daniels
Old December 9th 04, 01:08 AM
Stefan
.... at the price of your virility.
Stefan
