Glider Towplane Mid-air – TP PowerFLARM Inop
Old February 10th 20, 07:32 PM posted to rec.aviation.soaring
George Haeh
Default Glider Towplane Mid-air – TP PowerFLARM Inop
TSB Canada Report
https://bst-tsb.gc.ca/eng/rapports-r.../a19w0099.html
Old February 10th 20, 08:38 PM posted to rec.aviation.soaring
Dan Marotta
What a tragic waste of lives.Â* The report mentioned that both occupants
of the glider were wearing parachutes, but there's no mention of any
attempt to bail out.Â* Is that an oversight in the report or did they
simply not try to get out?
On 2/10/2020 12:32 PM, George Haeh wrote:
TSB Canada Report
Dan, 5J
Old February 10th 20, 09:14 PM posted to rec.aviation.soaring
George Haeh
My guess is that they didn't have enough time to get out with the forces involved after the tail came off. The report does not mention whether the canopies were released.
Old February 11th 20, 12:19 AM posted to rec.aviation.soaring
waremark
In 2003 I lost my fin and tailplane in a midair. I was able to get out very easily. I and the pilot of the other glider involved were very lucky. We both used our parachutes and were completely uninjured. I would not speculate on why the pilots of this K21 were unable to get out and am surprised that the report did not address that aspect. Would any of you ground a tug because the Flarm was giving problems?
Old February 11th 20, 12:29 AM posted to rec.aviation.soaring
John Foster
It sounds like they were about 2000" AGL. I would think that would give enough time to egress, assuming the G-forces were not pinning you in the seat, but it wouldn't be a lot of time. You would have to get out fast.
Old February 11th 20, 10:19 AM posted to rec.aviation.soaring
Jim White[_3_]
Default _Glider_Towplane_Mid-air_–_TP_PowerFLARM_Inop
Without a tail would the g forces not be 0 or even negative?. I would
expect the first result to be a bunt to inverted. Just wondering
Old February 12th 20, 06:03 PM posted to rec.aviation.soaring
Darryl Ramm
I think the reverse question is more intersting. How many people would have a PowerFLARM in a towplane and tolerating it repeatedly having problems before getting it fixed.
I expect it would be good to see more PowerFLARM adoption in towplanes in the USA.
Old February 12th 20, 06:22 PM posted to rec.aviation.soaring
Dan Marotta
The ABQ soaring club Pawnee has either a Flarm or a transponder.Â* In any
case, I see it electronically all the time.
Dan, 5J
Old February 11th 20, 06:45 PM posted to rec.aviation.soaring
Dan Marotta
Once the initial negative G of the pitch over passed, the vertical
descent is essentially a zero G situation.Â* It should be really easy to
get unstrapped and out.Â* Perhaps it was simply denial of what was
happening.Â* Given an altitude at or above 2,000' initially, it would
take over 5 seconds to reach the ground, probably 6 to 8 seconds.
Dan, 5J
PowerFLARM Core or LXNAV PowerMouse Installation in Towplane Paul Remde Soaring 1 October 2nd 19 04:58 PM
Powerflarm in towplane anecdotal experiences son_of_flubber Soaring 0 July 29th 19 04:30 PM
Cirrus collides with Glider/Towplane Jody Soaring 9 February 7th 10 03:14 AM
towplane collides with glider, prop hits wingtip [email protected] Soaring 21 September 1st 09 07:24 PM
Glider - Towplane Signals Mike the Strike Soaring 24 March 26th 05 09:33 PM
