How do you explain why the A/S increases on thermal entry?
Old April 7th 05, 12:41 PM
J.A.M.
Not always... the technique is sutile and differs from pilot to pilot. Neve
been able to summarize it and in the end always ends the same way, if you
want to learn how to thermal... fly a lot of thermals and try a lot of
approaches to it.
One thing for sure. Turning away from the lift won't make it.
"F.L. Whiteley" escribió en el mensaje
Are you sure you center more quickly if you turn toward the rising wing?
Frank
J.A.M. wrote:
I don't think it's just that important.
If you're fliying into a thermal, a wing rises, the IAS increases,
etc...
just pull back to the original speed, turn into the rising wing, an FLY.
Complex aerodinamic explanations are good for winter, but look out of
window... and go flying.
Old April 8th 05, 04:12 AM
This thread reminds me of the original explanation for malaria "bad
air". Everyone knew that he disease came from bad air wafting up
from
hot swamps. It took some actual research to determine that it came
from
a mosquito borne parasite.
Clearly there are lots of arm-chair (desk-chair?) explanations for
why
IAS increases upon entering a thermal, but nobody *really* knows
because
no experimentation has been done to figure it out. Some wise old
sages
out there are certain of their explanation, and maybe they're right,
or
maybe it's just bad air.
This seems like it would be a good youth-in-soaring sort of question
to
solve with real science.
Shawn
This ain't rocket science it is basic aerodynamics. Experimentation
is worthless without a basic understanding of aerodynamic force. You
will only propagate the narrow minded misinformation found in some real
science books. Its takes life long conspiracy to get pilots (private
and commercial) so ignorant about aerodynamic force that they do not
know the simple single difference between the definition of lift and
drag. You have to start when they are young and gullible and hope they
do not practice much original thought or apply what you tell them with
actual occurrence.
When you introduce them to one of the many different inaccurate
definitions like drag is a resistance force hope they do not realize
that the major use of lift in aeronautics is to resist gravity. When
you talk about the dynamics of a balloon preoccupy them with the
aerostatic lift that it produces and do not mention the fact that it
has circumnavigated the earth using drag exclusively for horizontal
acceleration. When you tell them that lift is the aerodynamic force
that supports the weight of an airplane in flight hope that they
don't realize that if drag opposes motion and if that motion is
downward drag is in an upward direction. Explain terminal velocity of
a dropped object on another day maybe they won't put two and two
together.
Why if you were to try something novel like telling them the truth the
hole truth and nothing but the truth so help you god maybe when they
are thinking about an aerodynamic force that impedes the forward motion
or an aircraft they will have an open mind and not just jump to the
inaccurate conclusion that it is always drag. When they are thinking
about an aerodynamic force that accelerates a glider upward they will
not jump to the inaccurate conclusion that it is always lift especially
since the glider is in lift.
It is impossible for the air speed of a glider in normal flight to not
be increased by a sudden thermal. The only way that the glider will not
be affected is if it had no inertia. If the glider moved readily with
the thermal there would be no increase in motion of the glider in
relation with the upward airflow. If experimentation is needed to
figure this out how are you going to be able to figure out the
experiment?
I hate to brag but I am a walking talking aerodynamic experiment. Why
even in my sleep I possess the ingredients for aerodynamic force. I am
a solid object that is influenced by a relative airflow 24-7 as a
result of respiration among other things. Not to mention other fluid
flows like blood and urine. And I have been known to emit a little
swamp gas (what you refer to as "bad air"). To the people that I am
related to this is referred to as relative wind.
Old April 8th 05, 04:02 PM
Shawn
from
from
why
because
sages
or
to
Shawn
actual occurrence.
snip
LOL
Guess you're right Spock pun intended ;-) , the current fashion is to
eschew science in favor of "common" sense.
Shawn
Old April 7th 05, 01:33 AM
Steve
On 5 Apr 2005 20:11:57 -0700, wrote:
Very Nicely said...
That would explain why I get outclimbed by a garbage bag that got
sucked up in a thermal.
Steve
Fred wrote:
Just got asked this question, didn't have a quick and easy answer.
How
do you explain it?
Airspeed is not defined as the speed of the glider nor is it the speed
of the wind moving over and around it. Airspeed is the speed of an
aircraft relative to the air in which it is flying. It is the speed of
the relative airflow that is aerodynamically influencing the aircraft.
When the glider is flying in still air all of its airspeed is generated
by its motion thru the air. To move thru the air it must over come
drag. When the glider in slightly downward flight experiences a thermal
part of its airspeed is now caused by the motion of air around the
glider. To remain still in moving air you must overcome drag.
The only thing the glider has to overcome the drag caused by moving air
is its reluctance to change speed (inertia). The glider is being held
in the upward airflow by inertia. As drag overcomes the gliders inertia
it starts to accelerate upward with the airflow. This reduces the
effect of the thermal on the airspeed and aerodynamics because the
glider is now moving with the upward flow and produces no relative
motion between the two.
The glider in downward flight in still air is supported by an
aerodynamic resistance force that opposes gravity called lift. Also
like lift in particular circumstances drag can resist motion and if
that motion is downward drag is upward also resisting gravity. Lift and
drag slows its descent in still air and cause its assent while in a
thermal.
The upward acceleration of the flying glider in a thermal entry is
caused 100 percent by the component of the relative airflow caused by
the thermal. It requires a force to accelerate the glider upward. Lets
see what aerodynamic force is most accurately defined as the
aerodynamic force that is in the direction of the relative airflow that
caused it? That's right drag.
It is true that angle of attack goes up causing more lift but as far as
accelerating the glider upward this extra lift is negated by the fact
that the direction of this lift moves farther away from the upward
direction. This extra lift comes with extra drag and its direction is
more in the upward direction as a result of the thermal. The thermal
not only increases the airspeed it changes its direction.
Old April 24th 05, 02:33 PM
Robert Ehrlich
How do you explain it?
Although this thread is now pretty old, I would like to add my
contribution, for 2 reasons. The first one is that nobody among the
contributors made a clear distinction between two effects involved in
this process. The second one is to try to share with all the readers
of this newsgroup a quantitative estimate of one of these two effects.
The two effects among which I want to make a distiction a
1) the pitch stability of the glider tend to keep it at the same
angle relatively to the air airstream, as long as the pilot doesn't
move any control that would change that. The thermal make a change
in the direction of the airstream, the stability of the glider make
it follow this change by pitching down. This is a cause of long term
airspeed increase.
2) even in the absence of the first effect, e.g. if the pilot reacts
to the pitch down tendancy (that's what I teach to my students: don't
let the thermal accelerate your glider, otherwise it will throw you
outside by increasing your turn radius), there is a change in the
aerodynamic force (vector sum of lift + drag) which causes an
immediate acceleration.
Now let's have a closer look on the 2nd effect. In order to make a
rough estimate of this effect, I want to do some first order
approximations. i.e. neglecting what I consider as second order
quantities. More precisely I will consider some quantities as "small"
compared to others, and second order quantities are those which are
"small" compared to some one which is already "small". As primary
small things I will consider that drag is small compared to lift,
and the vertical speed of the thermal (increase) is small compared
to the airspeed.
The first thing caused by the thermal is to change the relative wind
in force and direction. As the thermal velocity is almost perpendicular
to the initial velocity, the change in force is a second order change,
so I will only consider the change in direction.
The change in direction causes an identical change in angle of attack.
This change causes a change in the aerodynamic force. As before the
thermal the aerodynamic force was exactly opposite to the weight, so
that the sum of all forces was zero, after the change, the net resulting
force causing an acceleration is just the (vector) difference beteween
the new aerodynamic force and the previous one. For a quantitative
estimate, as we usually count (and feel) acceleration in "g" rather
than in m/s² (or ft/s² for metrically challenged people), what is
interesting is the relative change in this force, this gives directly
the accelaration in g.
There is a change both in direction and in intensity. Both changes are
small, so the new direction is close to the previous one. So the change
in direction provides mainly an horizontal component of the differential
force an the change in intensity mainly a vertical componemt, mainly
being understood as: the difference with the real change is a second
order quantity and may be neglected.
I assume that the glider was near its best L/D speed. In this case the
change of L/D when there is a small change of angle of attack is a
second order change. So we neglect it, i.e. we consider that the
angle between the aerodynamic force and the direction of the relative
wind doesn't change. So the change in direction of the aerodynamic force
is the same as the change in the direction of the relative wind. This
change in radians is the ratio Vz/V of the thermal velocity to the
airspeed, so this is equal to the first order to the horizontal
relative change in force dFh/F and to the horizontal accelaration in
"g".
Now what is the vertical accelaration? To the first order the relative
change dFv/F is equal to the relative change of the lift coefficient
dCl/Cl. The lift coefficient Cl is near 1 at best L/D, so we may focus
on the absolute change dCl. The aerodynamic litterature says that for
a thin plate the theorical value of dCl/da (da being the change of angle
of attack) is 2pi, and "The result, that CL changes by 2pi per radian
change of angle of attack (.1096/deg) is not far from the measured slope
for many airfoils"
(http://www.desktopaero.com/appliedae...atresults.html). This
is for an infinite aspect ratio, there is a correction factor of
AR/(AR+2) for finite aspect ratio AR which is so close to 1 for the
usual aspect ratio of most gliders that we can assumme it is 1,
especially if we approximate 2pi by 6.
So the vertical acceleration is roughly 6 times Vz/V and 6 times
the horizontal acceleration. This explains (if such an explanation was
needed :-) that we mainly feel the vertical acceleration. A glider
flying at 50 knots and encoutering a 1 knot thermal (again for
metrically challenged people) will roughly accelarate by .02 g
horizontally and .12 g vertically.
An odd clearance...can anyone explain? Andrew Gideon Instrument Flight Rules 32 September 18th 04 09:35 PM
TEC, can anyone use small words and explain this to me? Snowbird Instrument Flight Rules 11 November 16th 03 05:51 PM
Please explain T3 Military Aviation 28 November 14th 03 11:11 PM
Can anyone explain what TFR's are supposed to do? Corky Scott Piloting 33 October 23rd 03 12:42 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 02:33 AM
