TEC, can anyone use small words and explain this to me?
Old October 20th 03, 08:10 PM
Snowbird
Default TEC, can anyone use small words and explain this to me?
OK, one thing I've never really understood is the point
of Tower Enroute Control. Maybe it doesn't apply much
here in the Midwest where there's space between TRACONs.
Can anyone explain this to me, using small words and speaking
slowly?
Specifically, when is this used, what is the benefit, how
does one find out whether it's an appropriate thing to request,
and how does one request it? For example, I know there are
listings in the AF/Ds for TEC routes, is TEC only available
on these routes? What is the benefit of TEC vs. other routing?
Is TEC available on any route where one is controlled by TRACONs
all the way? What about a route where one passes directly from
a DP to a STAR with no enroute section in between?
TIA for any assistance.
Very confused on this subject Sydney
Old October 20th 03, 10:05 PM
Ron Natalie
"Snowbird" wrote in message om...
There are two places TEC is used and it means different things
in each place. In both, it's a procedure put in place during the
staffing shortages after the controller strike to allow IFR's to be
hadned off from tower to tower (well approach to approach) without
involving center. This was a good thing when center controllers
weren't up to the traffic.
In California, it's a shorthand filing as near as I can determine.
You actually ask for a TEC clearance which simplifies things.
In the NorthEast (from Richmond on North) it's just the standard
IFR routes. While they map out all this TEC routing in the AF/D,
it really is the way low level traffic is always handled....you just
file a regular IFR plan and you get routed through the miriad of
overlapping approach controls.
Old October 21st 03, 12:07 AM
John Harper
In the Bay Area you can file TEC and this is essentially an abbreviated
filing. You only give origin and destination, no altitude, route or any of
the SAR stuff. It works between any airports in the Norcal area, and
maybe one or two outside (e.g. KSTS). You can *usually* do this
with ground when you would normally request to open your pre-filed
clearance. However I've had it refused when the destination tower
was busy (or couldn't be bothered?).
You can also do a sort of hybrid, where you prefile through FSS or DUATS
and put TER in the comments, omitting the route and altitude. However I
once got a long lecture from the briefer at Oakland about why this isn't
really TER and TER means something completely different. He filed it
for me anyway and I forgot the substance of what he said...
The logic in both cases is that whatever you file, you'll get what you get,
so why waste your own time and everyone else's with a load of detail that
will get trashed anyway.
John
om...
Old October 21st 03, 04:53 AM
Snowbird
"John Harper" wrote in message news:1066687571.701137@sj-nntpcache-5...
Okey, dokey. Let's see if I got this straight.
On the Left Coast, TEC means you call up ground and say you want
to go from KABC to KXYZ, tower enroute, and they clear you. No
prefiling w/ FSS or DUATS, no route given, none of the rest of
the flight plan jazz and off you go. You having looked up the
route and altitude in the AF/D and the ground controller presumably
entering you in the system with the correct route number, like
a Chinese menu.
In the rest of the country, TEC means you look for your preferred
route in two places, but otherwise you file IFR as you always file
IFR and you takes what you gets as far as routing goes, as you
always takes what you gets. It has no discernable special effects.
Did I get this straight? If so it would explain why I'm confoosed,
me having never flown under IFR in the state of California. I
couldn't figure out what difference it makes in the Midwest and
East because...it makes no difference?
If I didn't get this straight, could someone please use smaller
words and speak more slowly?
Thanks, guys!
Sydney
Old October 21st 03, 06:34 AM
John Harper
om...
Yes (if you get lucky anyway).
No. You just write down the clearance, which since it's a short flight will
always be something simple anyway.
John
a Chinese menu.
Thanks, guys!
Sydney
Old October 21st 03, 09:36 AM
Fred E. Pate
Almost. If you're taking off from Santa Barbara (a class C airport with its own approach control) then you'd just call clearance delivery and ask for tower enroute to your destination and give him the aircraft type and equipment suffix. Then he'll come back with a full IFR clearance for you to copy. The clearance is from the Chinese menu, but I don't think they use a route number. This skips the pre-filing portion.
Now at VFR towers (class D airports) in the Bay Area (and probably in the LA area, too) they usually like you to prefile (because otherwise the ground controller has to get on the interphone with a grumpy and busy approach controller who then has to enter your flight plan). If you prefile, you can tell the FSS briefer that you want "tower enroute routing" and they usually don't go beyond the destination entry in the flight plan form. But that doesn't matter to the route itself. Although not published in the A/FD for the Bay Area, the routes are fixed and published within ATC.
It is my understanding that TEC is more of a convenience to ATC than to pilots. They don't need to enter you into the ARTCC computer that is rather picky about routes, but rather give you a local squawk code and a canned route and send you on your way. You, as a pilot, need not know anything about it except that you don't need to file a route. As far as I know, on the Left Coast, there is only one TEC route for an airport pair in use at a time. They change routes when the wind blows the other way and all the major airports in the area are landing the other way. So the pilot never makes a choice of routes. The only reason to publish the routes is to make it easier to copy the clearance.
a Chinese menu.
Old October 21st 03, 10:37 AM
Craig Prouse
Within the last year or so, Oakland FSS has put some information on their
web site regarding Bay Area TEC routes.
http://www1.faa.gov/ats/oakaifss/TEC/TECInfo.htm
It's not exhaustive, for instance I'd love to know in advance what is the
preferred IFR route from VCB to PAO.
Old October 21st 03, 03:41 PM
John Harper
Other than intellectual curiosity, why? Even when they give you a
clearance you'll probably spend most of the time on vectors anyway.
I'd guess it involves Vwhatever (I'm away from home) that goes
OAK-SUNOL-SJC.
John
Old October 21st 03, 08:31 PM
Craig Prouse
OAK-SUNOL-SJC.
That's what I had guessed as well, but after conscientiously filing that
route on DUATS I found myself copying one of the more complicated and
devious full-route clearances I've ever had the privilege to accept.
If I'd known the preferred route, I would have filed it, been mentally
prepared for it (becoming familiar with the names of a couple of obscure
intersections), had it preloaded in the GPS, and copied little more than "as
filed."
And yes, after all of this, what I actually flew was: TZZ radar vectors
CCR, direct. But it was late at night.
