Blow out static port
Old May 2nd 05, 09:01 AM
Default Blow out static port
Hi group,
There are larve in my static ports again.
The problem is that I do not have compressed air to blow them out.
I was thinking about using CO2 cartridges like they use for emergency
tire repairs. Or maybe a bicycle pump will do the job.
My concern is the max pressure I can use before I damage something.
I know that I have to de-couple the static lines from the instruments.
I'm going to try to build something to block the ports.
The ports are about 1/8"dia. and 1/4" deep. A pin will do the job but
I'm afraid that even a small remove-before-flight flag will pull them
out in some wind.
-Kees.
Old May 2nd 05, 03:14 PM
Blanche
Disconnect the lines! I had a pitot/static test done (that IFR test)
a couple years ago and the moron didn't understand how to do it (a
student learning under the direction of the A&P who was someplace
else) and cost me $3K to replace/repair and re-install everything.
And since I can't prove it, my loss.
As for keeping this from happening again...the classic tennis ball
solution -- slice it open about an inch, slip over the pitot tube.
Old May 2nd 05, 05:54 PM
pittss1c
I knew a guy that did this with his pitot system, and unfortunately
found out there was a junction somewhere difficult to get to in the
middle of his wing (that came disconnected when he tried to blow out the
pitot tube). There was much swearing.
Old May 2nd 05, 07:58 PM
Robert M. Gary
Legally, if you disconnect the lines they must be recertified by an
avionics shop. Not even an A&P can disconnect static lines.
Old May 2nd 05, 08:48 PM
RST Engineering
Really? I'm not doubting that you found this provision somewhere, but I
don't recall it. Mind giving a chapter and verse?
And I think that if the provision exists, the "certification" (again,
chapter and verse) would be by an instrument repair facility, not an
avionics facility.
ps.com...
Old May 2nd 05, 09:53 PM
Peter Clark
On Mon, 2 May 2005 12:48:53 -0700, "RST Engineering"
I would think that any A&P can open the system, but if they do and the
aircraft wants to fly IFR I think they'd be subject to shipping it
over to a proper facility to do an AST.
91.411(a)(2) - "Except for the use of system drain and alternate
static pressure valves, following any opening and closing of the
static pressure system, that system has been tested and inspected and
found to comply with paragraph (a), appendices E and F, of part 43 of
this chapter; ..."
43(e)(1) "Test by an appropriately rated repair facility in
accordance with the following subparagraphs." does seem to support
that it has to be a repair station, but what's the practical
difference between an avionics shop and repair station?
Old May 3rd 05, 04:28 AM
Robert M. Gary
Some large A&P shops will have one guy who is certified to work on
avionics ("instrument repair" according to RST). However, most shops
use roving instrument guys who come by once or so a week. The
certification necessary to work on avionics is different than the A&P
certification.
I have run into this with aircraft owner's that are working on their
private tickets. Most don't realize that they need to have a
transponder inspection every 24 months for VFR flying. An A&P cannot
perform this test and most IA's don't mention this at annual because
they don't consider it their business.
-Robert
Old May 3rd 05, 04:25 AM
Robert M. Gary
Jim, you know more than I do. I've owned airplanes for over 10 years
now and never knew there was a difference between an avionics shop and
an "instrument repair facility". Anytime something is wrong in my panel
I just call Nat at Airborne Electronics at SAC. I've always called him
an avionics shop, perhaps he's really an "instrument repair facility".
The appropriate reg has been quoted twice now on this thread so I won't
requote it.
-Robert, CFI
Old May 2nd 05, 09:46 PM
Scott Skylane
Robert,
A) Arguably, anyone can disconnect anything they like on an aircraft.
It's the returning to service part that will require some sort of
official blessing.
B) As I read 91.411(b)(3), any Airframe Mechanic can perform the
required static system tests after opening up the system.
C) Such testing is only required *if* the aircraft is to be operated in
controlled airspace under IFR.
Happy Flying!
Scott Skylane
N92054
Is my static port leaking? Derrick Early Instrument Flight Rules 2 August 15th 04 01:13 AM
Why a static port? Paul Mennen Owning 11 August 19th 03 04:58 AM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 10:26 PM
Static in KX-165A Chad Lemmen Owning 3 July 21st 03 09:57 PM
Canard static port location Paul Lee Home Built 1 July 12th 03 02:55 AM
