Is my static port leaking?
Old August 9th 04, 02:34 PM
Derrick Early
Default Is my static port leaking?
The plane does have an alternate static source vented inside; however, I
pushed the valve in to select the exterior port. My guess is that either
this is normal or the static pressure system has a leak.
"Ron Rosenfeld" wrote in message
On Fri, 6 Aug 2004 10:11:59 -0400, "Derrick Early"
When I close the door to my 172, the airspeed, vsi and altimeter
instruments
jump. Does this mean that I have a leak in my static line? The last check
of the system was 18 to 20 months ago. The last thing that I want is
errors
in altitude while flying IFR.
Do you have an alternate static source that is inside the cabin, and
possible in the wrong position?
--ron
ADF static? question JFLEISC Home Built 3 December 28th 04 02:28 AM
What caused the VSI and ALT bouce in the IMC? cpu Instrument Flight Rules 38 May 5th 04 04:45 PM
FS: Avery Dennison Adds Static Cling Vinyls to Fasson® Rapid-Roll Dry erase easel pads that clings to most walls. M.Roy Home Built 0 February 11th 04 06:18 PM
Is a static port a precision thing? Larry Smith Home Built 8 August 12th 03 11:26 PM
Canard static port location Paul Lee Home Built 1 July 12th 03 03:55 AM
