Two Lock Rule?
Old May 18th 05, 10:26 PM
AES
In article .com,
"nrp" wrote:
AES -
If you aren't going into business - somebody should. I think it is a
neat idea although it would need a way to detect that the electronic
box is being crunched or shot at etc etc.
Cool------
Thanks!
One could also get more complicated and have the lock and the remote
system in continuous wireless communication, to make sure the lock is
still intact -- but then there are more ways for the false alarm rate to
go up.
  #32
Old May 19th 05, 12:44 AM
Brian
Good plan, I once was pulling mine through with the mags off, on the
3rd pull it fired and sat there idling.
I went back to cockpit and the mags were still in the off position.
Always treat it like it is loaded!!!.
Brian
  #33
Old May 19th 05, 04:35 AM
George Patterson
RST Engineering wrote:
The easy way to do that is with a positive signal system. That is, the
little transmitter chirps once every couple of seconds when things are
"good". When it stops chirping (batteries low, shot, crunched, or alarm
triggered) you light the alarm fuse.
That's not very expandable. If the system gets popular, you'd need lots of
frequencies; otherwise your alarm might fail to sound when your item is stolen
because someone else close by is on the same frequency.
George Patterson
"Naked" means you ain't got no clothes on; "nekkid" means you ain't got
no clothes on - and are up to somethin'.
  #34
Old May 19th 05, 05:20 AM
Morgans
stolen
Nah, yah gotta think digital. It has to be chirping your digital code, not
just frequencies.
  #35
Old May 19th 05, 05:35 AM
RST Engineering
Then you chirp a digital code. A simple 16 bit code gives you 64K discrete
addresses. Ain't that many airplanes on the field at Oshkosh at one time.
"George Patterson" wrote in message
news:EPTie.9665$E05.6247@trndny09...
stolen because someone else close by is on the same frequency.
George Patterson
got
  #36
Old May 19th 05, 06:16 AM
Grumman-581
"George Patterson" wrote in message news:iOoie.6695$_f7.2717@trndny01...
If one were able to add in the cost of the various kickbacks
and other hidden penalties, you'd see a different picture, though
I'd bet NJ would compare very well to the Chicago area.
Hmmmm... Comparing a toxic waste dump to a cesspool... Quite appropriate...
  #37
Old May 20th 05, 03:52 AM
private
One of the better hangar stories I have heard involved an aircraft that had
just been flown and pushed back into the hangar. The mags were off and fuel
valve was in the off position. The hangar door was closed. The tires were
not chocked. As the pilot was leaving he moved the prop to the horizontal
(or vertical?) position. The pilot was standing in front of the prop. The
engine fired and the pilot was pinned against the door and placed his hand
on the spinner to stop the aircraft from moving forward until the engine ran
out of vapor.
It did not seem impossible to me but could be urban legend?
"Brian" wrote in message
Brian
  #38
Old May 20th 05, 06:14 AM
Roger
On Thu, 19 May 2005 00:20:04 -0400, "Morgans"
stolen
just frequencies.
And when you get two on the same frequency is it possible for one to
swamp the other. If you use something like WiFi to set off an alarm,
or call home, that's different as the networking *should* take care of
collissions and multiple systems can coexist on the same frequency.
www.rogerhalstead.com
  #39
Old May 22nd 05, 03:00 AM
RST Engineering
http://www.theroopouch.com/house_airport.htm
Tell them I sent you. They've offered me (unsolicited) a 5% finders fee.
I'll either split the fee with you or we can donate the whole thing to EAA
Young Eagles. Your call
"Tom Fleischman" k wrote in
message
news:2005052117531616807%bodhijunkoneeightyeightju nkatmacdotcom@junkjunk...
On 2005-05-16 20:29:52 -0600, "RST Engineering"
said:
40 acres, 3500 square foot house, 2000 square foot heated garage, heated
workshop, horse corral, hangar, private airport. $350K asking price.
Hanna WY.
Where can I get more information about THAT!!??
  #40
Old May 22nd 05, 03:03 AM
George Patterson
Head over to Google and check out two threads in R.A.O. on the subject, both
started by Jim. Here's part of one that may give you some incentive.
"Here are photos of the place I told you about that is up for grabs.
If I had 350K, I'd buy it in a pair of seconds."
George Patterson
Reading back altimeter settings? Paul Tomblin Piloting 31 April 12th 05 04:53 PM
FAA Mandatory Pilot Retirement Rule Challenged Larry Dighera Piloting 0 March 20th 05 08:56 PM
The Internet public meeting on National Air Tour Standards begins Feb. 23 at 9 a.m. Larry Dighera Piloting 0 February 22nd 04 03:58 PM
One door PaulaJay1 Owning 17 January 1st 04 12:02 AM
Hei polish moron also britain is going to breach eu deficit 3% rule AIA Military Aviation 0 October 24th 03 11:06 PM
