#31
George Patterson wrote:
I used to after first startup, but it's an unpleasant feeling to be flying around near New York and realize that the xpndr has been on standby for the last half hour. Rumor has it that many a NY-based CFI would do just that to avoid getting busted when their students crossed over into the NY class B airspace. A pilot mentor of mine used to fly corporate into Teterboro in an MU-2 and he told me he was always nervous on approach into TEB for fear of the GA aircraft with the transponder turned off. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
#32
I have had landing aircraft report a near miss when I left my
transponder on accidentally.. At my little Class D airport our rule is standby to warm it up - it does take a few minutes (at least mine does) - and on upon takeoff. Tony C-GICE In article , Maule Driver wrote: I don't. It stays on 24/7 (you know what I mean). 1200 unless given a code. It effectively prevents "Maule, check your transponder" unless using the wrong code. I make no attempt to turn it off or go to standby while taxiing or anything else. I've never been asked to go to standby or otherwise questioned. This has been discussed before but I'd suggest the everyone can do this without causing a problem for anyone. -- Tony Roberts PP-ASEL VFR OTT Night Cessna 172H C-GICE |
#33
![]() Mine is on standby during taxiing and when I'm flying below Amsterdam TMA1. The moment I line up I switch it to Alt. -Kees |
#34
Orval,
Most TXP antennae are belly-mounted. They send out a rather strong EM signal that can reflect off the pavement and overwhelm the receiver portion of the TXP, possibly damaging it. I have never heard of that and find it implausible (unless possibly taxiing on a bowl of concave sheet metal (PSP, anyone?)). Do you have any examples of transponders actually damager by this? -- Thomas Borchert (EDDH) |
#36
Judah wrote: I had heard that while it doesn't interfere with ATC radar services, TCAS systems don't filter it out, and you could be causing distractions for other planes on approach if you leave your transponder on all the time. what TCAS II system gives RA below 1000' agl? -- Bob Noel no one likes an educated mule |
#37
![]() Judah wrote: Newps wrote in news:gKydnTb27tVqe7TeRVn- : The change was made eons ago. There's no reason to turn the transponder to STBY anymore. I had heard that while it doesn't interfere with ATC radar services, TCAS systems don't filter it out, and you could be causing distractions for other planes on approach if you leave your transponder on all the time. You heard wrong. |
#38
My avionics guy told me that the encoder (older ones, at least) have
a heater in them to stabilize altitude readings, and that the standby function warms up the heater and the cavity tube in the transponder that generates the return signal. The transponder won't go to work until it's ready. The transponder puts out a very brief 400-watt signal, at radar freqencies, and I could see this being reflected off pavement and entering the receiver directly (not through the antenna) except that the box is aluminum and should constitute good shielding. I haven't heard of any transponders being damaged this way, but then I've had quite a few of them fixed over the years without knowing why they failed. Maybe that signal damages navcoms instead. Dan |
#39
Andrew Sarangan wrote:
In fact I would recommend to turn the transponder on before even getting on the runway. Same here. I'll run through the "lights, camera, action" checklist as I start the taxi roll over the hold short line. I've never had to wait more than a minute or so between a "position and hold" and "takeoff", so it's never been a problem. The only "non-flying" thing I do when starting the actual t/o roll is to start the timer, and I do that before the throttle. I don't want my hand to be near the transponder or strobe switch when I decide to abort a t/o. - Andrew |
#40
Jay Honeck wrote:
I make no attempt to turn it off or go to standby while taxiing or anything else. I've never been asked to go to standby or otherwise questioned. Standby gets used only: a) At OSH, per the NOTAM. and b) When flying as a flight of two. Otherwise, it may as well be soldered "on"... That's what I'm saying! |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Operation without a transponder | flyer | Piloting | 11 | September 14th 04 08:48 AM |
Transponder test after static system opened? | Jack I | Owning | 6 | March 14th 04 03:09 PM |
Transponder petition | Ian Cant | Soaring | 11 | February 28th 04 06:38 AM |
More on transponder petition | Ian Cant | Soaring | 1 | February 27th 04 06:37 PM |
