Supercooled Water - More on Icing
Old December 9th 03, 01:21 AM
Tarver Engineering
ink.net...
There has never been a case of rudder reversal caused by icing.
Wrong. Flow seperation due to icing is normal.
  #32
Old December 9th 03, 01:27 AM
Matthew S. Whiting
Julian Scarfe wrote:
"Matthew S. Whiting" wrote in message
However, keep in mind that most thermometers have some error in them.
So, even though ice doesn't form above 0C, it may form above 0C as
indicated on your airplane thermometer.
Absolutely true, but remember that your thermometer is one of the easiest
instruments in the aircraft to calibrate. The ATIS gives the temperature on
the ground before flight -- it's well worth a check.
Julian Scarfe
Yes, but where is their thermometer? On the ground near the level of
your plane, or on top of the tower? Makes a lot of difference. Also,
the error may be a slope error, not just a offset. It may be off by 2
degrees at 70 degrees, but less than that at 32 (or more, but typically
error gets less at lower temps).
I prefer to watch things very carefully when the temp is between about 0
and 35F. Most ice I've picked up was between 26 and 32 as indicated by
my Skylane thermometer. No idea how accurate it was, but I think it was
within a couple of degrees which is close enough for most purposes. I
make decisions based on what is happening on the wing, not what the
thermometer says, generally anyway.
Matt
  #33
Old December 9th 03, 01:30 AM
Matthew S. Whiting
Bob Gardner wrote:
That is the icing rule all pilots should remember: There are no
hard-and-fast rules with regard to airframe icing.
Well, I think there is one ... get out of the condition causing the
airframe icing ASAP!
Matt
  #34
Old December 9th 03, 03:02 AM
Mike Rapoport
Please cite a single reference of rudder reversal caused by icing.
MU-2
"Tarver Engineering" wrote in message
ink.net...
  #35
Old December 9th 03, 03:43 AM
Hilton
Julian Scarfe
on
Although the temperature at the ATIS station and the temperature where you
thermometer is located may quite a few degrees off. Kinda like setting your
Heading Indicator when lined up on the runway.
Hilton
  #36
Old December 9th 03, 04:20 AM
Roy Smith
In article . net,
"Hilton" wrote:
Julian Scarfe
on
Hilton
Not to mention that:
1) The ATIS could be up to an hour old
2) The ATIS temperature was taken with a thermometer in a carefully
designed enclosure which keeps it out of direct sun and wind. Your OAT
probe has none of those protections.
On the other hand, a slurry of crushed ice and water makes a pretty good
home-made 0C temperature reference. If you wanted to, I suppose you
could use that to calibrate your OAT-o-meter.
  #37
Old December 9th 03, 06:07 AM
Tarver Engineering
ink.net...
It is all part of the FAA's results from their icing study. Brownlee
expressed FAA's surprise that the results of their experiment were the
opposite of what their expectations had been. If you mean that you want me
to do a google search for you, I think you know better than that.
  #38
Old December 9th 03, 07:46 AM
Julian Scarfe
Fair point. At least in my part of the world, reported temps are supposed
to be 2 metre temps (measured about 6 ft above the ground). But as others
have pointed out there may be differences because of the local measurement
environment.
I still think it's well worth making a comparison between your OAT and the
reported temperature. It's not difficult to spot consistent deviations of a
couple of degrees.
Julian Scarfe
  #39
Old December 9th 03, 12:33 PM
Dan Luke
LOL
  #40
Old December 9th 03, 03:09 PM
Mike Rapoport
No, I want you to provice a single reference of rudder reversal caused by
icing which you are contending is a major problem. Not only is it not a
major problem, it has never occured
MU-2
ink.net...
me
Removing water repelent from fiberglass lay-up? Roger Home Built 2 December 2nd 04 11:15 PM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
water bombers Stew Hicks Home Built 2 September 8th 03 11:55 PM
water bombers Stew Hicks Home Built 0 September 7th 03 04:27 PM
Need help with Fluid Mechanics equation Doug Home Built 4 August 16th 03 03:13 AM
