Learning from an owner annual
Old May 15th 06, 01:04 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Learning from an owner annual
Robert M. Gary wrote:
Its quite depressing to see my plane in so many pieces. I've also discovered that its extreamly irritating that the aircraft parts places are closed on weekends.
Agree with your general premise that owner participation is a plus, in a
lot of ways.
The "parts places closed on weekends" deal"....well, welcome to the
aviation industry mindset. I owned two airplanes, from the mid-80s till
last year, and I ran into that inconvenience repeatedly over the years,
when I became aware I needed stuff, but, the suppliers only were open
"banker's hours". So, even though they want usurious prices for what
they sell, they'll only do it when it's convenient. I find that
attitude quite arrogant.
They get away with it, obviously, because they, like all the rest of the
aviation "service" industry, are acutely aware that unless you source,
procure, and *PAY THROUGH YOUR *NOSE* FOR" all those items necessary for
"airworthiness", your airplane is GROUNDED. And, they *know* you don't
want to ground your airplane. It's a federally-sanctioned racket.
I sold my last airplane. I don't need that frustration. I haven't
missed it.
  #32
Old May 15th 06, 02:13 AM posted to rec.aviation.piloting,rec.aviation.owning
If it has a aircraft part number such as AN, NAS and such.
The materials and treatment [strength] must be in
conformance with the standard. Torx, Phillips, Reed-Prince
[looks like a Phillips but is sharp pointed] plain slot can
all meet the standard.
James H. Macklin
ATP,CFI,A&P
"Jay Honeck" wrote in message
| I strip a fair number of screws every year -- but I've
NEVER had to
| drill any out on either of the planes we've owned.
| Can you replace them with Torx screws?
| I don't know.
| In the "real world" that is a no-brainer. In the bizarro
world of the
| FAA, I have no idea if Torx screws are legal...
| Toecutter? Jim Weir? Jim Macklin? Can we, as owners,
use any old
| fasteners we want for all those access panels?
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
| www.AlexisParkInn.com
| "Your Aviation Destination"
  #33
Old May 15th 06, 02:17 AM posted to rec.aviation.piloting,rec.aviation.owning
There are some parts suppliers who are open 5-1/2 days and
have 24/7 phone service and AOG parts out 24/7.
You do have to look for them.
James H. Macklin
ATP,CFI,A&P
"CriticalMass" wrote in message
is a plus, in a
| lot of ways.
welcome to the
the mid-80s till
over the years,
only were open
prices for what
find that
the rest of the
you source,
necessary for
*know* you don't
racket.
I haven't
| missed it.
  #34
Old May 15th 06, 02:44 AM posted to rec.aviation.piloting,rec.aviation.owning
You know what? I've been through this one so many times, but it's been
a few years, and I just don't have the energy to fight this fight
again.
There is NO "torque-limiting" power screwdriver-type tool that has both
the ability to prevent over-tightening, and allow sufficient "torque"
to be applied to screws installed into aircraft nutplates.
A slightly boogered screw or nutplate will NOT be tightened
sufficiently, or else other screws will be over-tightened-there is NO
middle ground.
In most cases, a quality torque-limiting screwdriver set at minimal
torque can be used by an experienced operator to run screws and
initially secure panels. The final "ginch" needs to be performed by a
human that knows what the **** he/she is doing.
There is a large portion of the "certified technician" population that
isn't smart enuff to use the proper bit for the type of screw to be
r/r'd, let alone to use power to drive it. It's not much of a stretch
to say that this applies to owner-performed maintenance also.
TC
  #35
Old May 15th 06, 03:28 AM posted to rec.aviation.piloting,rec.aviation.owning
Yes and bits are cheap, use new Phillips bits regularly.
Once the screwdriver is damaged it will destroy all the
screw slots afterward.
If the screws have paint in the slot, clean it out before
you try to unscrew the fastener.
James H. Macklin
ATP,CFI,A&P
some support
but it's been
this fight
| again.
that has both
sufficient "torque"
tightened
| middle ground.
at minimal
screws and
performed by a
population that
screw to be
of a stretch
also.
| TC
  #36
Old May 15th 06, 03:55 AM posted to rec.aviation.piloting,rec.aviation.owning
again.
But... a power screwdriver set below the specified torque for a screw and
then torqued by hand with a calibrated torque wrench set to the proper
setting will work just fine, or am I wrong?
I believe that I am restating your paragraph below, but in a way that my son
or mother could read it.
middle ground.
We were taught in A&P school not to reuse fasteners. I doubt very seriously
that this actually happens in the real world, but in the schools perfect
world, this should eleminate *most* of the "boogered" fastener problems.
TC
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0619-3, 05/12/2006
Tested on: 5/14/2006 9:55:47 PM
avast! - copyright (c) 1988-2006 ALWIL Software.
http://www.avast.com
  #37
Old May 15th 06, 04:00 AM posted to rec.aviation.piloting,rec.aviation.owning
New fasteners are cheaper than the labor to inspect and
clean old fasteners.
James H. Macklin
ATP,CFI,A&P
"C. Massey" wrote in message
. net...
| wrote in message
but it's been
this fight
| again.
tool that has both
sufficient "torque"
nutplates.
for a screw and
to the proper
a way that my son
tightened
| middle ground.
schools perfect
fastener problems.
at minimal
screws and
performed by a
population that
screw to be
of a stretch
also.
| TC
  #39
Old May 15th 06, 07:06 AM posted to rec.aviation.piloting,rec.aviation.owning
Could it not also be that there just isn't enough business for them to
justify keeping the same hours that the auto parts stores do?
Chris W
KE5GIX
Gift Giving Made Easy
Get the gifts you want &
give the gifts they want
One stop wish list for any gift,
from anywhere, for any occasion!
http://thewishzone.com
  #40
Old May 15th 06, 07:11 AM posted to rec.aviation.piloting,rec.aviation.owning
Kyle Boatright wrote:
Exactly right. If you look through the Aircraft Spruce catalog
you'll find
several different strengths of screws. Some are 30,000 lb/square inch, some
are 55,000/square inch, etc. In some applications (probably the Navion, as
pointed out above), it makes a difference which screw you use. If you go
down to the local hardware store and buy Torx fasteners, you'll probably
never know if the fastener you chose has the correct strength.
That's one of the reasons I get all my hardware for any project form
McMaster.com. They tell you what material is used and what the strength
is. BTW I just looked on their 18-8 stainless steel screws, it looks
like they are 70,000 or 80,000 psi. They don't seem to have any flat
head torx screws in stainless steel for some reason though.
Chris W
KE5GIX
2006 Annual -- My 8th Owner Assisted -- Update Jay Honeck Owning 14 March 27th 06 07:11 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
