How to get IFR Clearance enroute?
Old May 21st 04, 01:20 AM
Snowbird
(Stimbo) wrote in message . com...
I, of course, know that I can simply FILE IFR from the get-go and just
not activate it until I need it.
Well, let's clarify a bit here what you can and can't readily do.
Suppose you're flying from NJ to FL and you expect to hit poor
weather about VA.
You *can* file an IFR flight plan originating from an airport,
navaid, or intersection in N. Va. Just give an estimated departure
time of approximately when you think you'll get there (+ 1/2 hr).
You *can't* file an IFR flight plan originating from NJ, and expect
to activate it in N. Va. Your flight plan will not be accessible
to controllers in N. Va until it is activated ("departed") by ATC
in NJ.
However NJ to FL is a 9-hour flight
in a Cessna 172 plus 2 stops totalling 10 to 12 hours. I don't
remember how long the IFR plan stays active in the system (3 hours?)
It varies depending upon how busy the area is. It's usually something
like 1/2 hr before to 1 hr after the estimated departure time. It might
be as long as 3 hrs in some places, or even shorter than 1 1/2 hrs if
the system is busy.
I guess this procedure makes me file every time I make a
fuel/potty stop.
Well, not necessarily. You could file all your legs at home, using
the estimated departure times you calculate from your ETEs. Just file
several flight plans.
OTOH, I get a weather briefing every time I make a fuel stop -- the
airports with the best fuel prices don't necessarily have the best
computerized wx. Once you're on the phone talking to FSS, filing
a new flight plan only adds a minute.
Thanks to SNOWBIRD (Sydney) for such great detail and your anecdotes.
You're welcome
My eventual goal is to the Bahamas.
Been there, loved it. Chicken to fly back SE since our child was
born. If you fly over 10k you can typically minimize the time
you're out of glide to a few minutes. We did the "out islands"
(Eleuthera, Harbor Island among others) and flew back from Marsh
Harbor (the busiest non-towered airport I ever encountered -- made
me want to kiss the next 10 ATCS I talked to). AOPA has a pretty
good package on it, and Pilot's Guide was pretty helpful.
Cheers,
Sydney
  #33
Old May 21st 04, 02:02 AM
Jeff
Stimbo
in your case, filing on the ground will not work for you. the problem is
that when you leave the sector of your FSS then the flight plan you filed
is gone. After you enter the new sector, you either have to call the FSS
and file again, or if you had done a composite then it will be available
at where you wanted to pick it up. In this case, you would need to use an
intersection or some type of navaid as the place to pick it up. to
activate it, when your near th espot you chose, you just call center and
tell them you have a IFR flight plan you would like to open.
but if your expecting good weather, it may be easier to file in the air if
you find you need to do it.
Stimbo wrote:
Thanks to EVERYONE for such great suggestions!
You provided me some new ideas, and some that were just plain common
sense, I must admit.
not activate it until I need it. However NJ to FL is a 9-hour flight
before it's dropped. I guess this procedure makes me file every time
I make a fuel/potty stop.
I like the COMPOSITE flight plan idea. I had sorta forgotten about
it. I need to read more about it. Is this easy to
implement/activate?
Yes - I should have originally stated that if VFR it would be with
Flight Following. That's too long of a flight without help of some
kind - especially these days (TFR's etc.)
My eventual goal is to the Bahamas. I may start a new thread for some
tips.
Thanks again!
Stimbo
Medford, NJ
  #34
Old May 21st 04, 02:05 AM
Jeff
Around here, especially in SoCal, this is what I always do, I file at home, when
I get near the HEC VOR (the start of ziggy3) and if it looks like its below VFR
I call and tell them I have a ifr flight plan I would like to activate, they get
my N number, then come back with my clearance. Painless.
Maule Driver wrote:
"Stimbo" wrote in message
om...
Well, not really. If you file, you need to open at departure. Otherwise,
down the line they won't know who you are and may not go look.
  #36
Old May 22nd 04, 02:15 PM
Roy Smith wrote:
Of course, it's utterly absurd that we should have to go to these
contortions to get flight plans in the system when we want them. We've
passed the point where desktop PC's have more memory than the FAA
computers. We're now at the point where iPods have more.
The FAA is out of money for modernization. They can barely keep up with
maintenance and their GIANT payroll.
They couch their failures in obtuse concepts of "performance or customer
based programs."
Meanwhile the STARS TRACON system is slowing down, the Data-Link "promise"
(first made in the early 1970s) is once again slowing down, and WAAS seems
to be going nowhere.
In that scheme of events, the processing of G/A flight plans isn't exactly
on the top of the pile. Keep in mind that the airlines and biz jets don't
have flight plan issues.~
  #38
Old May 22nd 04, 02:38 PM
Steven P. McNicoll
wrote in message ...
I can't recall ever having a bizjet file enroute. I'm certain I've never
had an airliner do it.
  #39
Old May 22nd 04, 04:44 PM
Exactly. Airline flight plans are filed by dispatchers directly into the
system. Biz jets are ground filers as well.
  #40
Old May 22nd 04, 04:50 PM
Steven P. McNicoll
So what were you trying to make with your comparison? Private pilots that
file on the ground don't have any more flight plan issues than bizjets and
airliners.
No SID in clearance, fly it anyway? Roy Smith Instrument Flight Rules 195 November 28th 05 10:06 PM
Clearance: Direct to airport with /U Judah Instrument Flight Rules 8 February 27th 04 06:02 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
Big John Bites Dicks (Security Clearance) Badwater Bill Home Built 27 August 21st 03 12:40 AM
