what are they (if anything) "rolling out"
@ OSH this year? Anything exciting? Any upgrades to the 396 I should know about b4 purchasing?......thanx!!! richard colorado c172rg / 2V2 |
Dunno about exciting, but I just downloaded the latest operating system yesterday on the 296, ver 4.2, and then down loaded a fresh database... Upon restart the box cheerfully announced that it has NO terrain database to be found... hmmm, durned gremlins... Called Garmin, the tech allowed as how he had never heard of that one... We downloaded a fresh $150 terrain database on Garmin's nickle and all is well in Mudville tonight... Ya gotta be careful when you depend upon boxes that run on magic smoke... If the magic leaks out on a dark and stormy night you are in trouble... denny |
Or in IMC.... on our trip back from Michigan I needed to shoot the GPS 3
into STE, so I loaded it up in the KLN94 and thought I'd follow along on my FlightPrep system on my laptop. So I switched from the XM weather page to the approach plate but was still too far out for the little magic airplane to appear on the plate. Ok, switch back to the XM weather just to make sure we'd be on the north side of the approaching thunderstorms, yep, plenty of room to get around them... switch back to the approach plate..... You guessed it.... crash... darn Microsoft... so I had to put the toys away, get serious, and fly the approach "for real". So, until the plates come in an affordable panel mount system, there will always be paper in my airplane. Jim "Denny" wrote in message oups.com... Dunno about exciting, but I just downloaded the latest operating system yesterday on the 296, ver 4.2, and then down loaded a fresh database... Upon restart the box cheerfully announced that it has NO terrain database to be found... hmmm, durned gremlins... Called Garmin, the tech allowed as how he had never heard of that one... We downloaded a fresh $150 terrain database on Garmin's nickle and all is well in Mudville tonight... Ya gotta be careful when you depend upon boxes that run on magic smoke... If the magic leaks out on a dark and stormy night you are in trouble... denny |
"Jim Burns" wrote: Or in IMC.... on our trip back from Michigan I needed to shoot the GPS 3 into STE, so I loaded it up in the KLN94 and thought I'd follow along on my FlightPrep system on my laptop. So I switched from the XM weather page to the approach plate but was still too far out for the little magic airplane to appear on the plate. Ok, switch back to the XM weather just to make sure we'd be on the north side of the approaching thunderstorms, yep, plenty of room to get around them... switch back to the approach plate..... You guessed it.... crash... darn Microsoft... so I had to put the toys away, get serious, and fly the approach "for real". So, until the plates come in an affordable panel mount system, there will always be paper in my airplane. Though I'm not Windows fan, I believe that Avidyne and others use Windows as the foundation for their avionics systems. However, they strip out all of the junk that normally accumulates on a PC and are left with a fairly stable (and hardened) system. I suspect that you could approach that level of reliability if you did the same--stripped the system of everything but the FlightPrep, WxWorx, etc. But then, that would remove most of the non-aviation utility from the system. JKG |
Jonathan Goodish wrote: Though I'm not Windows fan, I believe that Avidyne and others use Windows as the foundation for their avionics systems. I don't believe that Avidyne uses windows in any form for their PFD or MFD products. -- Bob Noel Looking for a sig the lawyers will hate |
Bob Noel wrote: In article , Jonathan Goodish wrote: Though I'm not Windows fan, I believe that Avidyne and others use Windows as the foundation for their avionics systems. I don't believe that Avidyne uses windows in any form for their PFD or MFD products. If they don't, it must have been a recent change. It has been a poorly kept secret over the years that the Avidyne systems run a stripped-down version of Windows. I believe the same is true for the MX20, though I'm not sure how much for the MX20 Garmin retained in the new GMX200. JKG |
"Jonathan Goodish" wrote in message ... ... Though I'm not Windows fan, I believe that Avidyne and others use Windows as the foundation for their avionics systems. However, they strip out all of the junk that normally accumulates on a PC and are left with a fairly stable (and hardened) system. I suspect that you could approach that level of reliability if you did the same--stripped the system of everything but the FlightPrep, WxWorx, etc. But then, that would remove most of the non-aviation utility from the system. As I understand it, Avidyne uses Embedded Windows NT (a Microsoft product) in their EX5000 MFD. I suspect they also use it in their EX500 MFD. This was one reason why it took a long time for them to introduce USB flash memory compatibility for data upload/download. The original version only supported USB Zip drives, since that was the only USB drivers available for Embedded Win NT. Starting with Version 6.x on the Cirrus (EX5000C) MFDs, they now support Zip drives and USB "keychain" drives. You are correct that Embedded Win NT is "stripped down". That's one reason why it is much more reliable than the desktop versions. As to the Entegra PFD, it's an entirely different (although externally similar-looking) product. It does not use any Windows operating system. I believe they do use an RTOS (real-time operating system), but they would not tell me if they used an off-the-shelf RTOS or wrote their own. -Mike |
about b4 purchasing?......thanx!!! Someone just sent me an email with "insider information". Don't know if it's true. It talked about a 496 being unveiled a OSH. I deleted it and will ask him to send me the link again. It talked about having AOPA Directory installed, Airport Taxiway guidance for 600 airports, a faster processor and a pre-installed CitySelect software. 2,795.00. Is this true? I don't know, but...they would have to add a LOT more to make me trade in the 396. What was shown was way too little and unnecessary. AFAIK, what most pilots are screaming for are all the features of the 396 plus... a.. TOUCH SCREEN...HELLO...TOUCH SCREEN!!!! b.. Airways (so you can enter airways for your route instead of each fix on the airway) c.. The FULL IFR approach d.. ALTITUDES shown for the IFR approaches as well as the MEA's on the airways e.. ALL taxiways with GPS navigation on ALL the airports f.. I won't mind a graphical representation of the airport's traffic patterns with the 45 entry shown. I hope the rumor of the above mentioned new features is not true...I have had MUCH higher hopes for the 496. Kobra |
"Kobra" wrote: a.. TOUCH SCREEN...HELLO...TOUCH SCREEN!!!! No way do I want a touch screen! Who wants to wear holes in an LCD screen? Replacement costs would be prohibitive. |
| Thread Tools | |
| Display Modes | |
| Zero-Zero Landings In The Works (For Military Flyers) | Otis Willie | Naval Aviation | 0 | December 6th 05 03:01 AM |
| crazy but it works, espcially good if you need money | happyone | Piloting | 0 | July 24th 05 05:14 PM |
| New GPS from Honeywell/Bendix-King in the works | Jim Burns | Owning | 8 | June 21st 05 11:18 PM |
| Handheld GPS Works Fine, Except in One Particular Aircraft | jls | Home Built | 3 | July 5th 04 03:35 AM |
