#31
![]() "Steven P. McNicoll" wrote in message ink.net... "Jay Honeck" wrote in message oups.com... So why is the airport called "YIP"? It isn't. It's called Willow Run Airport So that is the identifier for Willow Run Airport. Nice nit. Took your A**hole pills today, I see, Stephen? That is the second backhand I have seen from you today. -- Jim in NC |
#32
In article , Pascal wrote:
When going to a new airport, the AD would have sometimes something like : Monroe County Airport, Bloomington, IN What call should I do ? Monroe County tower, Cessna XXXX ... or Bloomington tower, Cessna XXXX ... One thing you can do is look at the airport diagram available at: http://www.naco.faa.gov/index.asp?xml=naco/online/d_tpp In the case of Monroe County Airport, the airport diagram indicates the tower name is Bloomington Tower. -- Bob Noel Looking for a sig the lawyers will hate |
#33
"Peter Duniho" wrote: [snip] Of course you did. You certainly didn't state any sort of actual reliable method for determining an answer to the original question. One thing you can do is look at the airport diagram (available at http://www.naco.faa.gov/index.asp?xml=naco/online/d_tpp) In the case of Monroe County Airport, the airport diagram indicates the tower name is Bloomington Tower. Note that at least one tower I know will answer to different names (KBED's diagram indicates Hanscom tower, but they answer to Bedford tower as well). -- Bob Noel Looking for a sig the lawyers will hate |
#34
"Bob Noel" wrote in message
... In article , "Peter Duniho" wrote: [snip] Of course you did. You certainly didn't state any sort of actual reliable method for determining an answer to the original question. One thing you can do is look at the airport diagram (available at http://www.naco.faa.gov/index.asp?xml=naco/online/d_tpp) That's an excellent point. That reference is a reliable place to find the information originally asked for, and the airport diagrams are now available in the A/FD as well as in the FLIP charts where they always were. For that matter, the A/FD has the correct name to use printed in the "Communications" section. Now that you mention it, I'm a little puzzled as to why this thread exists at all. Obviously, I (along with apparently everyone else) have internalized the information in the A/FD so thoroughly that I (along with everyone else) forgot that they print the correct name to use in there? I mean, the original poster even seems to be referencing the A/FD specifically (though he wrote "AD", I agree with Jose that it's a good guess he really meant A/FD). How did this question even come up, when the correct information is right there? I think that collectively, the entire newsgroup needs to go sit in the corner with our dunce caps on. Thanks Bob. In the case of Monroe County Airport, the airport diagram indicates the tower name is Bloomington Tower. As does the A/FD entry. Note that at least one tower I know will answer to different names (KBED's diagram indicates Hanscom tower, but they answer to Bedford tower as well). I imagine that pretty much any tower will answer to pretty much any radio call on their frequency, regardless of what you call them, as long as you're polite anyway. I'm sure that Paine Tower, for example, will respond to Everett Tower, Snohomish County Tower, and Snohomish Tower. They will probably tell you the correct designation (Paine) in their response, but no real harm will come from using the wrong name. Pete |
#35
specifically (though he wrote "AD", I agree with Jose that it's a good guess he really meant A/FD). How did this question even come up, when the correct information is right there? Maybe the AF/D is not correct. I've come across errors in it before; reality trumps theory. One of the more irksome errors is the TPA - if it is not listed in the AF/D, it's supposed to be "standard". Well, standards have changed, but practices haven't, so (for example) GBR (Great Barrington) had the TPA unlisted, I assumed 1000 feet, but the locals use the old standard of 800 feet. Another aircraft right where I was got my attention real fast, but I couldn't find her. The AF/D gets its info from the airport manager, who may not even know to supply it (after all, it's standard - it's been 800 feet since he was a little boy). I'm certain that there are airports where the locals call it one thing, but the Feds call it something else. Jose -- The monkey turns the crank and thinks he's making the music. for Email, make the obvious change in the address. |
#36
"Jose" wrote in message
. net... Maybe the AF/D is not correct. I've come across errors in it before; reality trumps theory. While I agree with your observation, the A/FD is the best resource available absent first-hand knowledge. There is no substitute for knowing what the reality is, but if you can't get that, the A/FD is the next best thing. One of the more irksome errors is the TPA - if it is not listed in the AF/D, it's supposed to be "standard". Different people fly different TPAs for different reasons, and there is no FAR that requires them to do otherwise. While each airport may have one or more recommended TPAs, it would be unwise to expect each and every aircraft operating at that airport to be using the published TPA, whether accurate or not. [...] I'm certain that there are airports where the locals call it one thing, but the Feds call it something else. Possible. For towered airports (which is the question here) I would guess that's exceedingly uncommon. But even so, the A/FD is still a great resource and the one pilots should be relying on if they don't have personal first-hand knowledge or access to someone with that first-hand knowledge. Pete |
#37
![]() Jose wrote: Maybe the AF/D is not correct. I've come across errors in it before; reality trumps theory. There's a lot of places to look if you care. If you're not sure just use "tower." One of the more irksome errors is the TPA - if it is not listed in the AF/D, it's supposed to be "standard". Well, standards have changed, but practices haven't, so (for example) GBR (Great Barrington) had the TPA unlisted, I assumed 1000 feet, but the locals use the old standard of 800 feet. Another aircraft right where I was got my attention real fast, but I couldn't find her. TPA is non regulatory, a suggestion only. I never bother to look at TPA. I'm going to 1000 AGL at every airport unless there's some reason not to. |
#38
Peter,
I apologize, it was "A/FD" that I meant. The purpose of my question was actually more based on something that happened to me the other day. I should have given a better example I always fly from KBMG ( Bloomington, IN ) and it is true that the A/FD states that it is "Blomington tower". There's a small airport in the vicinity that is not a towered airport, where I practice touch and goes sometimes. It is KBFR ( Befdord, IN ). There's an AWOS that states "Grissom Municipal airport". However most of the people when flying around call "Bedford traffic" and I do too since this is what I had been told by my CFI. If the AWOS doesn't work ( it has happened at that airport ), how would I figure out that I should call "Bedford traffic" instead of "Grissom traffic". There's usually noone at the Unicom on the ground to answer calls. Of course, all of this is not a big deal and choosing one or the other from the airport directory shouldn't make much difference usually but I was just wondering how I could do the thing right at first. Based on the multiple posts on this thread there doesn't seem to really be a rule of thumb, so I guess and will try to choose the easier one to pronounce until I hear something different from somone else. Thanks Peter Duniho wrote: "Bob Noel" wrote in message ... In article , "Peter Duniho" wrote: [snip] Of course you did. You certainly didn't state any sort of actual reliable method for determining an answer to the original question. One thing you can do is look at the airport diagram (available at http://www.naco.faa.gov/index.asp?xml=naco/online/d_tpp) That's an excellent point. That reference is a reliable place to find the information originally asked for, and the airport diagrams are now available in the A/FD as well as in the FLIP charts where they always were. For that matter, the A/FD has the correct name to use printed in the "Communications" section. Now that you mention it, I'm a little puzzled as to why this thread exists at all. Obviously, I (along with apparently everyone else) have internalized the information in the A/FD so thoroughly that I (along with everyone else) forgot that they print the correct name to use in there? I mean, the original poster even seems to be referencing the A/FD specifically (though he wrote "AD", I agree with Jose that it's a good guess he really meant A/FD). How did this question even come up, when the correct information is right there? I think that collectively, the entire newsgroup needs to go sit in the corner with our dunce caps on. Thanks Bob. In the case of Monroe County Airport, the airport diagram indicates the tower name is Bloomington Tower. As does the A/FD entry. Note that at least one tower I know will answer to different names (KBED's diagram indicates Hanscom tower, but they answer to Bedford tower as well). I imagine that pretty much any tower will answer to pretty much any radio call on their frequency, regardless of what you call them, as long as you're polite anyway. I'm sure that Paine Tower, for example, will respond to Everett Tower, Snohomish County Tower, and Snohomish Tower. They will probably tell you the correct designation (Paine) in their response, but no real harm will come from using the wrong name. Pete |
#39
There's a small airport in the vicinity that is not a towered airport, where I practice touch and goes sometimes. It is KBFR ( Befdord, IN ). There's an AWOS that states "Grissom Municipal airport". However most of the people when flying around call "Bedford traffic" and I do too since this is what I had been told by my CFI. If the AWOS doesn't work ( it has happened at that airport ), how would I figure out that I should call "Bedford traffic" instead of "Grissom traffic". There's usually noone at the Unicom on the ground to answer calls. Look at the beginning of the AFD, specifically the Directory Legend. You'll see: CITY NAME Airport Name (Alternate Name) It would seem that using the Airport Name (or alternate) from the AFD is a perfectly reasonable thing to do. No one could fault you for that. -- Bob Noel Looking for a sig the lawyers will hate |
#40
"Pascal" wrote in message
... I apologize, it was "A/FD" that I meant. The purpose of my question was actually more based on something that happened to me the other day. I should have given a better example Boy, I'll say. ![]() about towered airports. [...] If the AWOS doesn't work ( it has happened at that airport ), how would I figure out that I should call "Bedford traffic" instead of "Grissom traffic". There's usually noone at the Unicom on the ground to answer calls. Especially for uncontrolled airports, there really is no good answer. At least when there's a tower to address, you can ask them what they'd like to be called. But there are no rules for non-towered airports. Furthermore, just as with controlled airports, an uncontrolled airport may have more than one name. For example, one uncontrolled airport I frequent around here goes by "Pierce County Airport" as well as "Thun Field". Traffic is almost always called out as "Pierce County" but one needs to be alert for either that or "Thun" (but not, oddly enough ![]() the airport serves). In the case of your Grissom airport, I think that for long-term operational knowledge, you just listen to what's going on. But even though using "Grissom" would turn out to be the wrong guess, it's not a bad guess and people operating in the vicinity ought to know that "Grissom" is the same as "Bedford". Of course, all of this is not a big deal and choosing one or the other from the airport directory shouldn't make much difference usually but I was just wondering how I could do the thing right at first. Well, I think we've answered it for controlled airports. For uncontrolled, I think that there just is not any one true answer. For any rule you might think of, other than simply listening to hear what is the local standard, there are going to be exceptions. I think it's best to start with the information from the A/FD (airport name, specifically) and then modify as needed once you hear what the other pilots in the area use. If you use the airport name, they will still know what you're talking about. Based on the multiple posts on this thread there doesn't seem to really be a rule of thumb, so I guess and will try to choose the easier one to pronounce until I hear something different from somone else. Heh...I guess that's one way to make the choice. ![]() the airport name, or always using the municipality, will not cause any serious problems, I think you'll be just fine using the name that's easiest to pronounce. Pete |
terminology questions: turtledeck? cantilever wing? | Ric | Home Built | 2 | September 13th 05 09:39 PM |
I Hate Radios | Ron Wanttaja | Home Built | 9 | June 6th 05 05:39 PM |
VOR/DME approach radio calls | Derek Fage | Instrument Flight Rules | 12 | December 8th 04 11:36 PM |
1944 Aerial War Comes to Life in Radio Play | Otis Willie | Military Aviation | 0 | March 25th 04 10:57 PM |
Ham Radio In The Airplane | Cy Galley | Owning | 23 | July 8th 03 03:30 AM |
