#31
Emily wrote:
I think most pilots have problems with strobes in IMC at night. I don't run them then or on the ground but I know a few who do. An beacon is sufficient to meet the regs in both those cases, although I'm sure there are some pilots who think strobes are required at all times. The nature of the anticollision lights is a certification (the rules changed over the years progressively) issue. There's no need to operate a beacon to meet the regs in any of the cases you describe. If the pilot decides that there is conditions warrant they should be off, he can turn them off. If conditions are not such that they need to be off, they should be on while operating the aircraft. I don't have a beacon. I'm not even required to have any anti-collision lights, but I have an STC for strobes. I don't use the strobes in dim or dark conditions on the ground. I'm also careful where I point my not required by the regs landing light as well at night. |
#32
On Sat, 14 Oct 2006 15:34:12 +0200, Mxsmanic
wrote: Emily writes: Can't he just read the regulations? He's obviously got access to internet. ... (b) Operate an aircraft that is equipped with an anticollision light system, unless it has lighted anticollision lights. However, the anticollision lights need not be lighted when the pilot-in-command determines that, because of operating conditions, it would be in the interest of safety to turn the lights off. Nothing in this quoted section mentions engines, so it doesn't answer my question. Yes it does. In the excerpt here, "Operate" means running the engines. That means all conditions, day or night, except for the exclusion. That's also mentioned in section 3 of the AIM, "Airport Operations." In that section, they mention the risk from jet/prop blast. I've read other FAA articles that discuss the risk of propeller accidents, which might be prevented with lighted anti-collision lights. A spinning propeller may not be immediately evident to someone walking across the ramp. Walking into a propeller can not only cause serious injury or death, but even worse, may require an expensive engine teardown to inspect for damage. Any measure that helps prevent that can only be a good thing. RK Henry |
#33
RK Henry writes:
Yes it does. In the excerpt here, "Operate" means running the engines. According to whom? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#34
"A Lieberma" wrote in message
. 18... Anybody know of a better newsgroup reader (freeware) then what I am using? 40tude, Free Agent, Thunderbird, Outlook Express, to name a few. I use OE and it works fine. Filtering via anything more complicated than just ignoring an entire thread or blocking a particular poster is a pain, but at least OE doesn't break URLs when you post them, even if they are longer than the normal line length limit you've set. It's a standard component that comes with IE, so it's almost certainly already installed on any Windows computer you might be using. Others will swear up and down OE is a piece of junk. Those people are blinded by their own prejudice. But that said, there are plenty of non-Microsoft choices available if you'd rather not use OE, for whatever reason. Pete |
#35
Mxsmanic wrote:
I understand that one normally turns on beacons or anticollision lights whenever an aircraft's engines are running. Is this a regulation, or just a polite custom? Turning on the Beacon prior to engine start is taught from the beginning. It is visual warning that something is about to or is happening. Engine running or aircraft moving. It is common sense. Strobes go on at the end of the runway. So not to blind others on the ground. Michelle P |
#36
... [...] I'm not even required to have any anti-collision lights Why not? |
#37
Mxsmanic wrote: I understand that one normally turns on beacons or anticollision lights whenever an aircraft's engines are running. Is this a regulation, or just a polite custom? NO! You turn them on after your runup and when you are ready to take the runway. In fact, it is bad form to operate the strobes on the ground when near other aircraft. |
#38
![]() "A Lieberma" wrote Anybody know of a better newsgroup reader (freeware) then what I am using? Xnews just drives me nuts sometimes esepcially with word wrapping. Most will do that. Try putting a at the beginning (no space and at the end (no space) and see if that helps. As in this: http://ecfr.gpoaccess.gov/cgi/t/text/text-idx?&c=ecfr&tpl=/ecfrbrowse/Title14/14tab_02.tpl -- Jim in NC |
#39
granfather'ed
"Peter Duniho" wrote in message ... | "Ron Natalie" wrote in message | ... | [...] I'm not even required to have any anti-collision | lights | | Why not? | | |
#40
On Sat, 14 Oct 2006 20:52:59 +0200, Mxsmanic
wrote: RK Henry writes: Yes it does. In the excerpt here, "Operate" means running the engines. According to whom? 1. In FARs part 1.1, Definitions, "Operate" is defined: "Operate, with respect to aircraft, means use, cause to use or authorize to use aircraft, for the purpose (except as provided in §91.13 of this chapter) of air navigation including the piloting of aircraft, with or without the right of legal control (as owner, lessee, or otherwise)." If you're planning on using the airplane for flying, I'd interpret that as beginning with the moment you turn the key 'til the airplane is back in the hangar. I suppose it could exclude running the engine at the shop, since that's not for the purpose of air navigation, but the mechanics usually turn on the beacon too. 2. The mention in the AIM about lights isn't regulatory, but it may as well be. It's good operating practice, and a pilot ignoring good operating practice could conceivably be caught by the catch-all regulation, FAR 91.13, Careless or reckless operation. Especially if someone got hurt. And of course, none of us wants anyone to get hurt. Running the anti-collision system is low-cost insurance. Except for cases like not operating strobes around people, it's better to just go ahead and use it. It could save someone's life. RK Henry |
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. | [email protected] | Aviation Marketplace | 0 | June 10th 06 10:51 PM |
Landing lights | Robert Barker | Owning | 20 | May 11th 06 02:33 AM |
Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 08:06 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
36HP VW Engine | Claton Cadmus | Home Built | 12 | October 24th 03 05:18 AM |
