Beacons/anticollision lights and engines
Old October 14th 06, 01:39 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Beacons/anticollision lights and engines
I understand that one normally turns on beacons or anticollision
lights whenever an aircraft's engines are running. Is this a
regulation, or just a polite custom?
Old October 14th 06, 02:18 PM posted to rec.aviation.piloting,rec.aviation.student
Kingfish
Hmmm. Do you turn on your virtual strobe before you start your virtual
engine, so as not to endanger anyone with your virtual prop?
Old October 14th 06, 02:27 PM posted to rec.aviation.piloting,rec.aviation.student
Emily
Can't he just read the regulations? He's obviously got access to
internet.
§ 91.209 Aircraft lights.
No person may:
(a) During the period from sunset to sunrise (or, in Alaska, during the
period a prominent unlighted object cannot be seen from a distance of 3
statute miles or the sun is more than 6 degrees below the horizon)—
(1) Operate an aircraft unless it has lighted position lights;
(2) Park or move an aircraft in, or in dangerous proximity to, a night
flight operations area of an airport unless the aircraft—
(i) Is clearly illuminated;
(ii) Has lighted position lights; or
(iii) is in an area that is marked by obstruction lights;
(3) Anchor an aircraft unless the aircraft—
(i) Has lighted anchor lights; or
(ii) Is in an area where anchor lights are not required on vessels; or
(b) Operate an aircraft that is equipped with an anticollision light
system, unless it has lighted anticollision lights. However, the
anticollision lights need not be lighted when the pilot-in-command
determines that, because of operating conditions, it would be in the
interest of safety to turn the lights off.
Old October 14th 06, 02:34 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Emily writes:
internet.
No person may:
Nothing in this quoted section mentions engines, so it doesn't answer
my question.
Old October 14th 06, 03:21 PM posted to rec.aviation.piloting,rec.aviation.student
Neil Gould
Recently, Mxsmanic posted:
Emily writes:
internet.
No person may:
the period a prominent unlighted object cannot be seen from a
distance of 3 statute miles or the sun is more than 6 degrees below
the horizon)-
night flight operations area of an airport unless the aircraft-
(3) Anchor an aircraft unless the aircraft-
or
my question.
Then, go read the rest of the regs to discover what "Operate and
aircraft..." means.
Neil
Old October 14th 06, 03:44 PM posted to rec.aviation.piloting,rec.aviation.student
Emily
Emily writes:
internet.
No person may:
the horizon)-
or
my question.
aircraft..." means.
No good deed, it appears....
Old October 14th 06, 05:05 PM posted to rec.aviation.piloting,rec.aviation.student
Ron Natalie
my question.
Those are the regulations. As it doesn't mention engines, there
is no requirement having anything to do with engines. Many people
put the beacon on when the master (not the engine) is turned on.
I used to do that as well (it's also a good reminder that your
master is on after you get out of the plane). However, I only
have strobes now, and I don't run those until I'm on the runway
now.
Old October 14th 06, 05:15 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Ron Natalie writes:
OK, thanks.
Old October 14th 06, 07:31 PM posted to rec.aviation.piloting,rec.aviation.student
RK Henry
On Sat, 14 Oct 2006 15:34:12 +0200, Mxsmanic
Emily writes:
internet.
my question.
Yes it does. In the excerpt here, "Operate" means running the engines.
That means all conditions, day or night, except for the exclusion.
That's also mentioned in section 3 of the AIM, "Airport Operations."
In that section, they mention the risk from jet/prop blast. I've read
other FAA articles that discuss the risk of propeller accidents, which
might be prevented with lighted anti-collision lights. A spinning
propeller may not be immediately evident to someone walking across the
ramp. Walking into a propeller can not only cause serious injury or
death, but even worse, may require an expensive engine teardown to
inspect for damage. Any measure that helps prevent that can only be a
good thing.
RK Henry
Old October 14th 06, 07:52 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
RK Henry writes:
According to whom?
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. [email protected] Aviation Marketplace 0 June 10th 06 10:51 PM
Landing lights Robert Barker Owning 20 May 11th 06 02:33 AM
Jet sailplane update Bob C Soaring 0 April 13th 06 08:06 AM
Buying an L-2 Robert M. Gary Piloting 13 May 25th 04 04:03 AM
36HP VW Engine Claton Cadmus Home Built 12 October 24th 03 05:18 AM
