GPS instead of turn and bank
Old February 5th 07, 09:04 PM posted to rec.aviation.piloting
Mxsmanic
Default GPS instead of turn and bank
Newps writes:
So now you're changing the subject? Good one.
No. I'm trying to illustrate, in multiple ways, why a GPS receiver
alone cannot serve to measure banking or turning.
  #32
Old February 5th 07, 09:07 PM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
All you care about is that you're actually turning. Or not turning.
The GPS does very well at that.
No, it does not. The GPS knows only your ground track. Nothing else.
If you are flying straight and level, and the wind changes, your
ground track may show a turn, even though you haven't turned in the
air. If you turn as the wind changes, your ground track may show no
change, even though you are turning and banking in the wind.
Thus, a GPS alone cannot serve as a turn and bank indicator. QED.
  #33
Old February 5th 07, 09:08 PM posted to rec.aviation.piloting
Mxsmanic
Nomen Nescio writes:
Well, just for s**ts & grins, I just did a flight on MSFS....In IMC........1000ft
ceiling, where I took off, climbed to 3000 ft, flew over another airport (20nm
away), turned around, flew back, and landed at the same airport. I did
this using NOTHING but the altimeter and GPS. It wasn't pretty......but I did it.
Oh, and I enabled the "real weather" option....kinda windy here in the NE, today.
All well and good ... but how did you determine your bank angle and
rate of turn with the GPS?
  #35
Old February 5th 07, 09:14 PM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
Newps writes:
And you fail utterly. As usual.
  #36
Old February 5th 07, 09:16 PM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
Newps writes:
Nothing else is needed, as has been pointed out before. If you had any
actual flying experience you would know the wind is irrelevant. Even
flying thru a front is irrelevant.
Not relevant in the real world.
  #37
Old February 5th 07, 09:44 PM posted to rec.aviation.piloting
On Feb 5, 3:10 pm, Mxsmanic wrote:
writes:
How do you know and allow for the wind speed?
For real practical purposes it really does not matter a lot. Note
that I am interested in the RATE of turn. Of course if the wind
direction and speed changes every second by a very large amount you
may have false "temporary attitudes", now that would constitute pretty
severe turbulence and wind sheer I would imagine. I can go through my
calculations but as I recall a standard rate turn 3 degrees /second
turn at 120kts will yield a 17 degree horizon (coordinated) I think.
An example:Let's say that my magnetic compass shows due North (Mag
Var = 0) I am going at 100kts TAS wind is 10kts from the west 270.
This means that my ground track is appr 006 Magnetic. I don't care,
what I care about is that the rate of change to my ground track (first
derivative) is the same when I do a left coordinated bank versus a
right coordinated turn, obviously my ground track profile will be
different but I don't care, I am not doing turns around a point.
That's the premise and it seems to work fairly reasonably well,
believe me if everything else failed ...
  #38
Old February 5th 07, 10:12 PM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
In any communication system, failures can occur at either the
transmitting or the receiving ends.
  #39
Old February 5th 07, 10:13 PM posted to rec.aviation.piloting
Mxsmanic
Newps writes:
Explain how you distinguish between wind changes and turns by looking
at a ground track alone.
  #40
Old February 5th 07, 10:29 PM posted to rec.aviation.piloting
Newps
Mxsmanic wrote:
Newps writes:
What we're trying to do here is keep the plane flying safely straight
and level after the loss of certain instruments. Altitude is much less
important than right/left. As long as the GPS is steady on a ground
track I'm safely upright. No amount of crosswind or frontal passage
wind shift will alter that. I may in fact be in a very slight bank to
maintain a ground track, doesn't matter as it on the order of a degree
or less. So I don't care what the drift is, the primary importance is
keeping the plane upright. I'll also eliminate drift by selecting a
waypoint to go to. Stay on the line drawn by the GPS and the heading is
irrelevant. I hand fly hundreds of miles on cross countries without
getting more than a tenth of a mile off the straight line between the
two points. All this and never looking at the heading indicator. Don't
need it, just look at the line.
Air Force One Had to Intercept Some Inadvertent Flyers / How? Rick Umali Piloting 29 February 15th 06 05:40 AM
WTB 2 1/4" Turn and Bank Bill Batesole Soaring 3 October 18th 05 03:43 AM
Turn & Bank Indicator and 2 gallons of poyester resin [email protected] Instrument Flight Rules 0 February 12th 05 08:52 PM
Parachute fails to save SR-22 Capt.Doug Piloting 72 February 10th 05 06:14 AM
Turn and Bank - RC Allen vs Electrical Gyro Corp Kevin Horton Home Built 0 December 1st 03 01:46 AM
