#31
Luke Skywalker wrote:
On May 7, 4:33 pm, Mike Hunt postmaster@localhost wrote: Luke Skywalker wrote: But if she has any doubts she can just call the Tower and we'll talk her through it. Patroni Both Doris Day and Lauren Holly did that quite well! Robert Striker....... THE SARGE.... What was the L. Bridges line..."It is a bad day to give up glue sniffing!" both those were just well done...I was sort of amazed that I laughed as hard at the second one as I did on the first one... "You can tell me, I am a Doctor" What can you make of this? |
#32
The Sperry series autopilots on the 7-deuce had a largish knob in the center
of the autopilot control panel on the pedestal to force the aircraft into a coordinated turn. The knob was about the diameter of a beer can and about a cigarette pack high. THey were indented about the center arrow so that your had fit onto the knob nicely. The flight director (Collins FD-108/109 series) simply showed the result of the autopilot input, not a control for it. Jim "Mxsmanic" wrote in message ... I recall seeing, long ago, a sort of large knob on the pedestal of a jet (I can't remember which kind) that, when turned, put the aircraft into a coordinated turn ... |
#33
RST Engineering writes:
The Sperry series autopilots on the 7-deuce had a largish knob in the center of the autopilot control panel on the pedestal to force the aircraft into a coordinated turn. The knob was about the diameter of a beer can and about a cigarette pack high. THey were indented about the center arrow so that your had fit onto the knob nicely. That sounds like it! Thanks. Except I don't know what a 7-deuce is. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#34
727
7-deuce 3-holer All the same airplane Jim "Mxsmanic" wrote in message ... RST Engineering writes: That sounds like it! Thanks. Except I don't know what a 7-deuce is. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#35
"d&tm" wrote in
: "Bertie the Bunyip" wrote in message . 130... "d&tm" wrote in : "Bertie the Bunyip" wrote in message . 130... Mxsmanic wrote in : I recall seeing, long ago, a sort of large knob on the pedestal of a jet (I can't remember which kind) that, when turned, put the aircraft into a coordinated turn ... at least if I recall correctly. No modern jets seem to have anything like this. You're an idiot. Send me $500 and I'll tell you all about it. Bertie Do you have any reason for reading this newsgroup other than to make repeated juvenile comments about mxsmanic? ie do you fly yourself? are you an interested wannabe? , do you have anything to contribute aviation wise? If the answer to the last 3 questions is no, would you **** off if we sent you $500? BTW, you must be an Aussie! BTW you are a jerk. Yes I am an Australian and proud of it , but a little less proud knowing you probably are an Australian also. Does it occur to you that your stalking behaviour ( I think thats a valid description for someone whoes only intent is to reply to one single poster) is obviously water off a ducks back to mxs.. he clearly sees you as an intellectual inferior not even worthy of acknowledgement that you exist. I'll be sharing that sentiment after this post. And BTW I dont believe for 1 minute you are a pilot. Believe what you like arsehole. BTW, Aussie, moi? Bwahwhahwhahwhahwhhahw! But I spotted yu as one right away! Bertie |
#36
Your Better wrote in
: "d&tm" wrote in : "Bertie the Bunyip" wrote in message . 130... "d&tm" wrote in : "Bertie the Bunyip" wrote in message . 130... Mxsmanic wrote in : I recall seeing, long ago, a sort of large knob on the pedestal of a jet (I can't remember which kind) that, when turned, put the aircraft into a coordinated turn ... at least if I recall correctly. No modern jets seem to have anything like this. You're an idiot. Send me $500 and I'll tell you all about it. Bertie Do you have any reason for reading this newsgroup other than to make repeated juvenile comments about mxsmanic? ie do you fly yourself? are you an interested wannabe? , do you have anything to contribute aviation wise? If the answer to the last 3 questions is no, would you **** off if we sent you $500? BTW, you must be an Aussie! BTW you are a jerk. Yes I am an Australian and proud of it , but a little less proud knowing you probably are an Australian also. Does it occur to you that your stalking behaviour ( I think thats a valid description for someone whoes only intent is to reply to one single poster) is obviously water off a ducks back to mxs.. he clearly sees you as an intellectual inferior not even worthy of acknowledgement that you exist. I'll be sharing that sentiment after this post. And BTW I dont believe for 1 minute you are a pilot. terry I say, I say, son...you're even dumber than you look! impossible. Bertie |
#37
Mxsmanic wrote in
: RST Engineering writes: The Sperry series autopilots on the 7-deuce had a largish knob in the center of the autopilot control panel on the pedestal to force the aircraft into a coordinated turn. The knob was about the diameter of a beer can and about a cigarette pack high. THey were indented about the center arrow so that your had fit onto the knob nicely. That sounds like it! Thanks. Except I don't know what a 7-deuce is. of course you don't fjukktard. You don't even know what an autopilot or a co-ordinated turn is. Fjukkwit. Bertie |
#38
Mike Hunt wrote:
Luke Skywalker wrote: On May 7, 4:33 pm, Mike Hunt postmaster@localhost wrote: Luke Skywalker wrote: But if she has any doubts she can just call the Tower and we'll talk her through it. Patroni Both Doris Day and Lauren Holly did that quite well! Robert Striker....... THE SARGE.... What was the L. Bridges line..."It is a bad day to give up glue sniffing!" both those were just well done...I was sort of amazed that I laughed as hard at the second one as I did on the first one... "You can tell me, I am a Doctor" What can you make of this? This? Why, I can make a hat or a brooch or a pterodactyl |
#39
![]() d&tm" wrote in : "Bertie the Bunyip" wrote in message . 130... Mxsmanic wrote in : I recall seeing, long ago, a sort of large knob on the pedestal of a jet (I can't remember which kind) that, when turned, put the aircraft into a coordinated turn ... at least if I recall correctly. No modern jets seem to have anything like this. You're an idiot. Send me $500 and I'll tell you all about it. Bertie Do you have any reason for reading this newsgroup other than to make repeated juvenile comments about mxsmanic? I do now, fjukkwit. Bertie |
#40
"Mike Hunt" wrote:
Striker....... "Striker! Striker! Striker! Striker! STRIKER!!" man in controlroom hits woman in controlroom "Ted Striker?" Marcel |
FA: One-Day-Left: 3 Books - JETS JETS and JETS - AIRPORT - 30 Seconds Over Tokyo | Alan | Aviation Marketplace | 0 | August 14th 05 01:11 PM |
FA: 3 Books - JETS JETS and JETS - and Aviation Classics | Millie | Aviation Marketplace | 0 | August 9th 05 03:48 AM |
DIY DF device | John | Home Built | 15 | May 4th 04 11:32 PM |
You Want Control? You Can't Handle Control! -- Was 140 dead | ArtKramr | Military Aviation | 0 | March 2nd 04 08:48 PM |
Rate of turn indicator on commercial jets (Boeing / Airbus) | Mark | Simulators | 1 | November 1st 03 10:35 AM |
