#31
Larry Dighera wrote: My example was in reference to cyanide gas generated by some upholstery materials when burnt, not Air Gizmo's products specifically. That was remedied by the FAA a while back, IIRC. Yes, for anything after the rule was written. It doesn't apply to anything produced before the rule went into effect. |
#32
![]() Larry Dighera wrote: Air Gizmo says a FAA Form 337 field approval is required. That's not Air Gizmo's call. That is your mechanics. |
#33
On Tue, 21 Aug 2007 10:31:27 -0600, Newps wrote
in : Larry Dighera wrote: Air Gizmo says a FAA Form 337 field approval is required. That's not Air Gizmo's call. That is your mechanics. I understand what you're saying; the A&P/IA puts his certificate on the line. But given the fact that the OP wasn't able to locate one who would install the Air Gizmo, do you see what I'm saying? |
#34
"Ray Andraka" wrote in message
... Jay, I will if that's what it takes. My first preference would be to install it myself under supervision of my A&P. I just have to make sure he's willing to sign it off rather than having me either not log it or sign it off as owner/pilot, neither of which is acceptable to me. No need to go that far Ray (despite the lure of staying at Jay's hotel). I was able to get a quote from Penn Avionics (www.pennavionics.com). Their FSDO isn't giving them a hard time and were willing to install it. I just haven't been able to schedule it yet. My quote is a couple of months old so hopefully things haven't changed. Marco |
#35
Air Gizmo says a FAA Form 337 field approval is required. On what are
you basing your "installation is properly logged" conclusion, the word of a motel operator? No, on the word of a hotel operator who HAS HAD THE AIR GIZMO LEGALLY INSTALLED AND SIGNED OFF IN THE PANEL OF HIS CERTIFICATED AIRCRAFT. (Loud and clear enough for you?) Have you had an AirGizmo installed, Larry? If not, your opinion here means precisely squat. -- Jay Honeck Iowa City, IA Pathfinder N56933 www.AlexisParkInn.com "Your Aviation Destination" |
#36
![]() Larry Dighera wrote: On Tue, 21 Aug 2007 10:31:27 -0600, Newps wrote in : Larry Dighera wrote: Air Gizmo says a FAA Form 337 field approval is required. That's not Air Gizmo's call. That is your mechanics. I understand what you're saying; the A&P/IA puts his certificate on the line. But given the fact that the OP wasn't able to locate one who would install the Air Gizmo, do you see what I'm saying? What's happening is a larger issue. Several years ago the FAA came out and said basically no more field approvals. Everybody groaned. But few read the fine print. What the FAA is doing is going back to the way the rules were intended to be interpreted. This is a good thing. They are intended to be interpreted by the mechanics. What happened over the years is the mechanics just got used to calling mother FAA for damn near everything. The FAA is not where the expertise is, it resides with the mechanics in the field. The FAA realized this and shifted the responsibility back where it belongs, with the mechanics. When Air Gizmo writes that you need a 337 that's just CYA. They have zero say in the matter. Just like some peoples desire to buy parts with a yellow tag. A yellow tag means exactly nothing. Only the mechanic installing the part is the one who can vouch for its airworthiness and he alone bears that responsibility. So mechanincs have been bitching for years how restrictive the FAA has been, which is entirely a situation of their own making and now the FAA has in reality turned them loose. Basically said read the damn rule book. Now grow some balls and get off our back. |
#37
On Tue, 21 Aug 2007 13:09:00 -0600, Newps wrote
in : Larry Dighera wrote: On Tue, 21 Aug 2007 10:31:27 -0600, Newps wrote in : Larry Dighera wrote: Air Gizmo says a FAA Form 337 field approval is required. That's not Air Gizmo's call. That is your mechanics. I understand what you're saying; the A&P/IA puts his certificate on the line. But given the fact that the OP wasn't able to locate one who would install the Air Gizmo, do you see what I'm saying? What's happening is a larger issue. Several years ago the FAA came out and said basically no more field approvals. Everybody groaned. But few read the fine print. What the FAA is doing is going back to the way the rules were intended to be interpreted. This is a good thing. They are intended to be interpreted by the mechanics. What happened over the years is the mechanics just got used to calling mother FAA for damn near everything. The FAA is not where the expertise is, it resides with the mechanics in the field. The FAA realized this and shifted the responsibility back where it belongs, with the mechanics. When Air Gizmo writes that you need a 337 that's just CYA. They have zero say in the matter. Just like some peoples desire to buy parts with a yellow tag. A yellow tag means exactly nothing. Only the mechanic installing the part is the one who can vouch for its airworthiness and he alone bears that responsibility. So mechanincs have been bitching for years how restrictive the FAA has been, which is entirely a situation of their own making and now the FAA has in reality turned them loose. Basically said read the damn rule book. Now grow some balls and get off our back. That's reasonable. Hence the inconsistency among Air Gizmo installers. What about the STC issue? |
#38
![]() "Jay Honeck" wrote Have you had an AirGizmo installed, Larry? If not, your opinion here means precisely squat. Oh, not just then, Jay. Larry's word ALWAYS means precisely squat! g -- Jim in NC |
#39
Nonsense. Larry made a salient point, once. I don't remember what it was, but he was agreeing with something I had posted... ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
#40
![]() Larry Dighera wrote: What's happening is a larger issue. Several years ago the FAA came out and said basically no more field approvals. Everybody groaned. But few read the fine print. What the FAA is doing is going back to the way the rules were intended to be interpreted. This is a good thing. They are intended to be interpreted by the mechanics. What happened over the years is the mechanics just got used to calling mother FAA for damn near everything. The FAA is not where the expertise is, it resides with the mechanics in the field. The FAA realized this and shifted the responsibility back where it belongs, with the mechanics. When Air Gizmo writes that you need a 337 that's just CYA. They have zero say in the matter. Just like some peoples desire to buy parts with a yellow tag. A yellow tag means exactly nothing. Only the mechanic installing the part is the one who can vouch for its airworthiness and he alone bears that responsibility. So mechanincs have been bitching for years how restrictive the FAA has been, which is entirely a situation of their own making and now the FAA has in reality turned them loose. Basically said read the damn rule book. Now grow some balls and get off our back. That's reasonable. Hence the inconsistency among Air Gizmo installers. What about the STC issue? That's something Air Gizmo would need to consider. It seems silly to get one since a cursory read of the requirements for a major modification don't support the need for one. |
Mounting cameras | keithw | Soaring | 2 | December 3rd 05 05:02 PM |
GPS mounting bracket | Michael Ware | Owning | 3 | November 5th 05 11:30 PM |
PDA mounting alternatives | Jack Glendening | Soaring | 15 | October 14th 05 08:03 PM |
Mounting my GPS | Charles Talleyrand | Owning | 8 | November 19th 03 11:51 AM |
Mounting my GPS | Charles Talleyrand | Piloting | 8 | November 19th 03 11:51 AM |
