Slow Flight
Old September 10th 07, 10:58 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
Default Slow Flight
Robert M. Gary wrote:
On Sep 8, 11:03 am, Ol Shy & Bashful wrote:
There is little doubt in my mind that the ability to do slow flight at
the very edge of stall speed will do more to prevent accidents than
1000 hours of cruise speed flight. Is there anyone here who is
proficient that lands their aircraft more than 10kts above stall
speed?
I teach all my students to slow fly with the entire range of
configurations for the particular aircraft they are flying. Gear up/
down, flaps up/down/in-between. I want them to be comfortable flying
at the very edge of the stall speeds and spend a lot of time
maneuvering right on the edge of a stall "nibble". It does more for
pilot confidence and ability than anything else I can think of. They
learn proper control useage and how their particular aircraft responds
while in the low speed areas. Playing with different angles of bank
while at low speeds and flying with a modicum of accuracy does a lot
for proper control use.
If you think about it, how many accidents occur in the low speed
spectrum? Either from a stall, or from a high sink rate on approach,
or poor control use during an emergency or off airport landing, or
something similar?
In my opinion, the pilot who is comfortable throughout the entire
speed range of their aircraft is a properly trained pilot and one who
will not get into an inadvertant stall, or spin.
What are your thoughts?
I agree with you on the importance of slow flight but for a slightly
different reason. I think slow flight and stalls end up being seen by
student's as more of a rite-of-passage more than anything else. My
approach is to place an intense concentration on the indicators of
stall in their aircraft (stall horn, sloppy ailerons, buffeting, nose
drop, more buffet, then break). Therefore, I see slow flight more as a
way to ensure that students have enough experience with these
sensations to recognize them when they need to. In addition, I think
most CFI's teach slow flight at WAY to high of a speed. If the student
doesn't accidently stall on occasion its almost guaranteed that their
slow flight is too fast. In your standard Cessna/Piper type products
the plane should be bucking like a wild horse during slow flight.
I also approach slow flight and stall in this manner.
On the "right of passage" issue;
I believe instructors should be specifically tuned into this issue and
address it as 101 with every student they teach.
The mindset that learning to fly is simply to surmount the obstacles
placed in front of the student then reach out and accept the PPL is a
concept that I personally would like to see driven out of aviation.
Instructors should from the first meeting with a new student,make every
effort possible to down play the "steeping stones" required on the way
to the PPL and instead impart on the student the critical importance
connected with the actual learning involved.
The problem with the "right of passage" mindset is that students and
instructors alike have a tendency to consider these "accomplishments" as
the pinnacle of the learning curve for the area affected with learning
decreasing on the backside of that subject's pinnacle as learning on the
next required "step" proceeds.
Learning to fly an airplane is a process that begins the first day you
climb into an airplane and ends as you take the last breath of your
life. If you have been taught properly by a good CFI, there is a very
good chance that this last moment and breath you take as the learning
stops won't be in an airplane.
Dudley Henriques
Old September 11th 07, 02:29 AM posted to rec.aviation.piloting
john hawkins
Default Slow Flight
Damn!! Dudley you have a way with words! What a great concept.
"Dudley Henriques" wrote in message
snip
.. If you have been taught properly by a good CFI, there is a very
Dudley Henriques
Old September 11th 07, 03:19 AM posted to rec.aviation.piloting
Default Slow Flight
snip
Dudley Henriques
Comes in handy when my wife appears at the head of the stairs and asks me,
"Do I look fatter in the red dress or the blue one hon?"
Dudley Henriques
Old September 11th 07, 10:05 AM posted to rec.aviation.piloting
Roger (K8RI)
Default Slow Flight
On Mon, 10 Sep 2007 22:19:06 -0400, Dudley Henriques
snip
Dudley Henriques
That's when your survival training and judgemental ability complement
each other. :-))
Roger (K8RI)
Old September 11th 07, 12:29 PM posted to rec.aviation.piloting
B A R R Y[_2_]
Default Slow Flight
You couldn't be more right.
I was fortunate to have several instructors who imparted that the PPL
and additional ratings simply meant you met the minimum standards on the
check ride day. At that point, it's time to continually learn and
improve as experience is gained.
Overweight? Out of CG? Stalled? Too slow? Flyingmonk Piloting 41 June 25th 06 07:08 PM
Running slow Jamie Nicholl Simulators 2 February 16th 06 09:57 PM
why so slow??!! Heino & Deanne Weisberg Home Built 6 November 6th 05 06:22 PM
Flightgear really this slow on XP? [email protected] Simulators 6 May 9th 05 02:55 PM
Flying Slow [email protected] Piloting 61 January 17th 05 05:23 PM
