Flightgear really this slow on XP?
Old May 6th 05, 05:23 PM
Default Flightgear really this slow on XP?
Don't tell me to install Linux. I know that. It's currently not an
option.
I downloaded and installed FG on a fairly capable XP system (1.6ghz AMD
256 RAM and a good video card) and was blown away by the frame rate.
Like
one second per frame even in the lower resolution modes?
I shut down all the background tasks I can, task manager shows 99% free
resources, but hey... this is windows.
I've got to be doing something wrong (besides using XP). What is it?
It's
got to work better than this. How do you get it to run so that it's not
just a big joke?
Old May 7th 05, 02:08 PM
jmiguez
option.
AMD
Like
free
It's
not
just a big joke?
I agree with Epi. You need more RAM. 256k is only enough to run XP
and Word. I think you will find that 512k RAM will do a lot for the
frame rate.
That MB should be able to use the older 2100 or 2400 RAM. You can get
a 512 stick for about $50 or less. A 256k stick can be had for cheap,
cheap.
John
Old May 8th 05, 05:35 PM
Thanks, there may be something to that. I should have mentioned that
everything is slow, even when the plane is not flying. It looks like a
DOS program, and I was wondering if it might be all the overhead of
running in an XP window, that there might be a boot disk I could make
or something. It does seem to be something other than just RAM.
Old May 9th 05, 04:05 AM
Roger
option.
AMD
Like
free
It's
not
just a big joke?
frame rate.
cheap.
With XP and the apps that run in the back ground I'd want a minimum of
512 and preferably one gig.
To the OP. Bring up the "Task manager" and see what you have for
memory use and page file swapping. I'd bet it's doing a tremendous
amount of page file swapping. (swapping chunks of programs and data
from RAM to the HD and working piecemeal).
On this machine, several upgrades back, going from 512 to 1 Gig made
an unbelievable difference. I do a lot of photo processing. It went
from 20 to 30 seconds on loading a 65 meg image to about a second. I
can run the scanner, the canner software, Photoshop CS AND process 4
to 6 images at a time AND run Word too.
www.rogerhalstead.com
John
Old May 9th 05, 02:55 PM
James Hodson
On Sun, 8 May 2005 11:09:05 +0000 (UTC), "Quilljar"
I think your difficulty lies in your definition of fairly capable.
For running MS word perhaps, but for flight simming that amount of RAM and
that chip, would have not been capable even three years ago. The problem all
along with MS Flight Sim is that the requirements of the players have forced
Microsoft to put in capabilities such as more and more realistic weather and
scenery that only a top rated PC will run it properly and that has meant
1024Mb RAM and 2.6Ghz CPU for the last two years. As for video cards, there
seem to be only one or two around that people are truly pleased with. My 128
Mb Matrox Parhelia is now very old hat I gather.
Hi Quilly
S'funny you mention three-year-old PCs as my own machine is just about
that age.
AMD XP1800+ (1.54G clock speed, I beleive), 512 MB DDR RAM, GeForce3
Ti 200 video - and all else pretty much as one would expect for a
machine three years old.
On the plus side, I use FS8 which, I'd guess, requires a lesser PC
than FS9. FS8 runs acceptably well. The only problems I have (other
than forgetting that my AV does its daily check at 18:00) is when
landing at a large airport and when I have all sliders set well
towards max.
James
Wingtip Vortex: Heavy, Clean, Slow - Why? Eric Nospam Piloting 23 January 21st 05 03:09 AM
Flying Slow [email protected] Piloting 61 January 17th 05 05:23 PM
Deployments Slow Fire Training For Military Pilots Otis Willie Military Aviation 0 July 8th 04 12:19 AM
Military Slow Routes R22AV8R Rotorcraft 0 April 17th 04 01:51 AM
Problème de lancement de Flightgear Nicolas Bernier Simulators 0 September 22nd 03 10:10 AM
