#31
#32
On Dec 26, 11:55 am, Bertie the Bunyip wrote:
Control surface flutter is caused by a lack of rigidity in the wing. Control surface flutter probably won't fail the surface itself, it wll fail the surface it's attatched to. Your elevators prolly won't fall off, but your stab will probsbly fail, or even the fuselage, long before th ehinge lets go. Here's a case to think about: http://www.flyingmag.com/article.asp...print_pag e=y "It's hard to understand how a coat of paint can add three-quarters of a pound to a surface area of only around 15 square feet, but the National Transportation Safety Board's (NTSB) report on the accident passes over this oddity without comment. Apparently, however, investigators hypothesized that the other control surfaces, including the mostly vanished rudder, might have been similarly overweight and underbalanced, and Grob's analysts affirmed that rudder flutter was possible under these conditions. The probable cause of the accident, the NTSB concluded, was "failure of maintenance personnel to rebalance the flight controls after the airplane had been repainted, which resulted in rudder flutter and inflight breakup of the airplane." The hinge allowed the rudder to drop off first followed by other bits. Cheers |
#33
Yipes.. *The only thing I don;t like about those Zenairs is they are
very light indeed. That 6061 is beer can stuff really, but the airplanes have a good record, so... You might not need the STOL performance unless you're flying out of your own driveway, though. they're pretty slow.... Yup, slow. Check this out. If you could have a "favorite" NTSB accident report, then this would be my favorite: "As the pilot approached the vicinity of the destination airport, he noted that the winds were about 35 to 40 miles per hour (mph). In order to land into the wind he opted to perform a landing on a ramp area of the airport. The airplane touched down on the ramp's surface with a forward groundspeed of about 3 mph. A side load was placed on the left main landing gear, and the tire subsequently deflated. The airplane veered to the left and pitched forward, resulting in damage to the firewall. A weather reporting station in the area reported winds at 24 mph, gusting to 28 mph." There's a lot of these flying and they have been around since something like 1985 or so. Not many NTSB reports and no fatals. Anyway it just looks like good plain fun. |
#34
It's more common than you think. A lot of WX accidents, for instance, where
there is loss of control due to disorientation in cloud *often ended up in an inflight breakup precipitated by a spiral dive or other stressful flight condition. Next time you see an airplane scattered across several fields, you can be relatively certain that flutter did at least some of the damage on the way down. And it even happens to people like Scott Crossfield. |
#35
a pound to a surface area of only around 15 square feet, but the National Transportation Safety Board's (NTSB) report on the accident passes over this oddity without comment. Apparently, however, investigators hypothesized that the other control surfaces, including the mostly vanished rudder, might have been similarly overweight and underbalanced, and Grob's analysts affirmed that rudder flutter was possible under these conditions." Hell. Why paint? |
#36
Here's a case to think about:http://www.flyingmag.com/article.asp...cle_id=112&pri...
From this same article: Flutter is usually associated with high speed, but low-speed aircraft can also flutter if they are sufficiently flexible. In 1991 a homebuilt amphibian crashed during an early test flight after one of its external-airfoil flaperons fluttered, causing the left wing to separate from the airplane. The builder-pilot was wearing a parachute, but he bailed out at such a low altitude that there was insufficient time for it to open. In this case, the builder had elected not to install the "strongly recommended" balance weights on the flaperons because they would make the airplane heavier, and he "felt that they were not needed." This makes me remember something I read in William Wynne's Corvair conversion manual: "It's not the probability of being right, it's the cost of being wrong." I think I'll stick to the plans and have it checked by a third party. |
#37
![]() "Stefan" wrote in message ... Bravo Two Zero schrieb: What is rudder flutter ? This is rudder flutter. (Actually, it's aileron flutter, but the principle is the same.) http://www.youtube.com/watch?v=kQI3AWpTWhM I should add that this was a test flight done by the factory test pilot and the wings were reinforced for this test. Standard wings would have fallen off pretty quickly, as you can see in related videos. Thanks Guys espec. Bertie the Bunyip. So the next question would be, if you experience rudder flutter in flight, what would you do ( apart from prey !!!) |
#38
On Dec 26, 7:38 pm, "Bravo Two Zero" wrote:
"Stefan" wrote in message ... Bravo Two Zero schrieb: What is rudder flutter ? This is rudder flutter. (Actually, it's aileron flutter, but the principle is the same.) http://www.youtube.com/watch?v=kQI3AWpTWhM I should add that this was a test flight done by the factory test pilot and the wings were reinforced for this test. Standard wings would have fallen off pretty quickly, as you can see in related videos. Thanks Guys espec. Bertie the Bunyip. So the next question would be, if you experience rudder flutter in flight, what would you do ( apart from prey !!!) Reduce speed ASAP Cheers |
#39
WingFlaps wrote in
: On Dec 26, 11:55 am, Bertie the Bunyip wrote: Control surface flutter is caused by a lack of rigidity in the wing. Control surface flutter probably won't fail the surface itself, it wll fail the surface it's attatched to. Your elevators prolly won't fall off, but your stab will probsbly fail, or even the fuselage, long before th ehinge lets go. Here's a case to think about: http://www.flyingmag.com/article.asp...article_id=112 _page=y "It's hard to understand how a coat of paint can add three-quarters of a pound to a surface area of only around 15 square feet, Pick up a can of paint sometime! This is a relatively common problem, believe it or not. There have been lots of accidents over the years on repainted aicraft. When Bonanazas started to come apart in numbers large enough to catch the NTSB's attention, at least a few of them were down to repaints without correct balancing done afterwards. but the National Transportation Safety Board's (NTSB) report on the accident passes over this oddity without comment. Apparently, however, investigators hypothesized that the other control surfaces, including the mostly vanished rudder, might have been similarly overweight and underbalanced, and Grob's analysts affirmed that rudder flutter was possible under these conditions. The probable cause of the accident, the NTSB concluded, was "failure of maintenance personnel to rebalance the flight controls after the airplane had been repainted, which resulted in rudder flutter and inflight breakup of the airplane." The hinge allowed the rudder to drop off first followed by other bits. Yeah, but it probably fractured the fuselage just before it departed the aircraft.. I remember reading the report on a lass glider that got flutter momentarily in the elevator. The pilot managed to land it to find the aft half of the fuselage was almost completely gone, the tail held on only by threads. I had a low freq tye of flutter once. I was flying a Twin Beech on a sched pax service and after airborne on the second sector a hinged inspection panel on the outboard section of the top wing opened (the airplane had been on an inspection) and the panel, probably about 10"X6" flapped up and down and caused a sympathetic motion in the aileron, probably a couple of Hz or so. There's a name for this kind of flutter, but I can't remember it. We slowed down and the freq decreasd, but I don't think it ever went away. It was more than a bit disturbing, but fortunately the flight was relatively short. Bertie |
Can Washout Cause Flutter?? | DonMorrisey | Home Built | 12 | January 19th 07 02:32 AM |
WTD. SGS 2-33 Rudder | [email protected] | Soaring | 0 | December 20th 06 04:31 AM |
Counterweighting to prevent flutter | [email protected] | Home Built | 11 | June 10th 05 03:51 AM |
rudder cable question | Bob Loer | Home Built | 7 | November 26th 03 08:34 AM |
Tail flutter! | I Can Computer Services | Home Built | 3 | November 24th 03 12:56 AM |
