#31
On Jan 26, 4:12 pm, Stealth Pilot
wrote: On Fri, 25 Jan 2008 19:15:13 -0800 (PST), D Ramapriya wrote: Since the CL can be altered by the wing configuration - deployment/ retraction of flaps for a given pitch, e.g., I'm not sure that the CG and CL need to necessarily coincide for stable flight. Also, for a body such as an aircraft, I think the CG would theoretically be somewhere within it while the CL is a point on the fuselage, so their coincidence may even be an impossibility. Ramapriya totally wrong. Stealth Pilot While the CG is unchanging - ignoring CG travel due to fuel burn and pax moving around - the CP (CL) changes with the AoA. I think it keeps moving forward as the AoA increases. Thus, so long as the CP (CL) is close to the CG, stable flight should be possible and their coincidence isn't a sine qua non. Still all wrong? ![]() Ramapriya |
#32
"Jim Logajan" wrote in message ...
Phil J wrote: Imagine that you had a couple of tall jack stands that you could place under the wings to elevate the airplane a foot or so off the ground. Let's say you place the stands under the wings just back from the CG such that you have to press down on the tail to keep the nosewheel off the ground. This is similar to the condition of flight since the center of lift is aft of the center of gravity. Now if you push down on the tail, the airplane will rotate about the center of lift. Wouldn't it work the same way in the air? They aren't equivalent situations, mechanically speaking. As I understand it, the force of the tail plane's elevators typically moves the center of lift forward and backward along the airplane's axis as the elevators are moved up and down (as well as changing the lift magnitude a little - though that is secondary). One presumably enters stable flight when the center of lift is moved to coincide with the center of gravity. You are in stable flight when the forces are balanced. You do not want the CG and CP to coincide if you want positive stability on the airframe. With a conventional aircraft, the CG is forward of the CP and the horiz tail provides a down force to hold the nose up. The elevator is a wing adjuster and basically sets the AOA. At a high AOA the CP moves forward and at a low AOA the CP moves back. The rotation still occurs around the CG. This is why the nose pitches down during a 'stall'. The C/L deteriorates in the stalled condition so it is no longer holding the nose up, and the up force from the horiz tail pulls it up and the nose rotates down... When the CG and CL coincide, the elevator forces are very light and the airplane is at best neutrally stable. Because the CP moves with AOA (therefore C/L) if a gust upsets the aircraft and pitches it up for instance, the CP moves forward, the plane rotates around the CG as the tail goes down, and there is no self stabilizing force to bring the tail back up. If left uncorrected the wing will stall. This movement of the CP is just one of the Wright brothers many insights that allowed them to make an airplane that could be maneuvered. Now, if you want to be efficient, you load the airplane so the CG is at or just forward of the aft cg limit (and make sure it will be there as the flight progresses). This way the down force is minimized ands you can fly at a lower AOA, lower C/L, and therefore drag. I think some of the airliners put fuel in the horiz tail so the CG can be tweaked while in flight to keep the CG back and maintain higher efficiency. A canard design is just the opposite. The CG is behind the CP, and when the canard stalls, the nose drops because their is no longer any lift to hold it up. This is why canards must always stall the front wing first. |
#33
"Stealth Pilot" wrote in message ...
On Fri, 25 Jan 2008 19:33:58 -0800 (PST), Tina wrote: There's a physics issue here called 'frame of reference.' Think about an external stationary (with respect to the air mass) observer, and the airplane is made to fly a loop. The center of rotation to that obsever is the center of the loop. Or, if the observer tracks the airplane, or even its CG (assume it's marked on the airplane) he'll see it move laterally at airspeed, then at the start of the climb will probably see it dip a little bit, then start assending. I'm having a hard time imagining a frame of reference where the airplane would appear to rotate about its CG, where I take 'rotate' to mean a point about which the tail end goes down and the other end goes up, because the CG itself will be moving, first down a little (I think) then up. Down first because the elevator is adusted so it loses upward lift of increases downward thrust, effectively making the airplane heavier. As the aoa increases the wings (making a huge number of assumptions (assume a spherical cow?) increase lift. Note also that the 'center of lift' of a wing may change with aoa, so even that model -- all effective lift concentrated at a fixed point -- may fail. You are confusing the forces here. The CG is the center of mass, period. The only way it moves is if the masses on the aircraft physically change position (burning or transferring fuel, PAX moving, etc). Moving the elevator does not change the CG, it changes the AOA (if the plane is flying) and that change in AOA causes and change in C/L which moves the CP. A more minor point, (but why not pick nits?) is that it's unlikely the CG, center of lift of the wing, and center of lift of the elevator are all in a straight line. In a high winged airplane the center of lift, about a third of the way back from the front of the wing, and probably pretty close to the wing's underside skin, is well above the CG. That vertical displacement will not affect computing moments for horizontal flight, but will as directions of flight different from horizontal take place. Think for a moment or two about a helocopter in horizontal flight transitioning to a nose up attitude. When I've seen that, it appears the center of rotation is well above the hellcopter. When watching the Blue angels perform in hte F-18, it becomes apparent that the aircraft is rotating around the CG, and the movement of the CG defines the flight path. You can see the controls wiggling and the nose moving up and down, but the plane stays in the same relative position to the others. All those aerodynamic effects do not change the CG of the aircraft. This is one of the reasons I liked watching them fly trhe A4s better. The F-18 has negative stability and needs to always be seeking controlled flight, while the A4 was a positive stability craft and looked like it was on rails... I know, there's nothing like adding some mud to the water. no mud at all. consider another situation that may provide some insight. when an aircraft is falling in a spin what does it spin about? If the plane was moved out of the atmosphere it would tumble around the CG. Same answer here... |
#34
On Jan 26, 5:19 am, Stealth Pilot
wrote: On Fri, 25 Jan 2008 17:03:04 -0800 (PST), wrote: And if the CG is moving horizontally at 100 knots, where is the rotation point now? As soon as rotation starts, the aircraft begins to change its flight path, and any determination of rotation point, whether it's the CG or CP or any other point, becomes very hard to determine and might be irrelevant. I would prefer to think of the fixed end of the flight path radius (which is also changing) as the airplane rotates, just like one of those complicated cabinet door hinges that has two arms and four pivot points. Where is the rotation point of that door? There is no fixed point. Dan clueless. you'd never have understood the propeller like the wrights did because you cant simplify situations until the problem becomes solveable. finding a solution to a problem is often a matter of thinking about it with just the relevant factors at play. the answer to your door problem lies in understanding that there are multiple hinge points that each act in a simple manner. the frame of reference is moving at 100 knots. the aircraft rotates about it's centre of gravity (centre of mass). You are assuming that the aircraft rotates about its CG as it would in space. But we're NOT in space, and lift and drag and various vectors all come into play here. As the aircraft rotates nose-up, CL (coefficient of lift) increases; CP shifts forward; the relationship between CG and CP changes because of the CP shift, and especially so if the CG is well above or below the CP; the tail's downforce increases, adding another vector to the whole thing. Then we have thrust and drag trying to rotate the airplane around some other point. We can't consider mass alone if we're trying to figure a rotational point. If mass is all you're concerned with, then the CG is good enough. I'd rather have more than mass acting on my airplane; it flies better that way. Kerschner likely has something to say on it. I'll have a look. Dan |
#35
On Jan 25, 7:31*pm, Jim Logajan wrote:
Phil J wrote: Imagine that you had a couple of tall jack stands that you could place under the wings to elevate the airplane a foot or so off the ground. *Let's say you place the stands under the wings just back from the CG such that you have to press down on the tail to keep the nosewheel off the ground. *This is similar to the condition of flight since the center of lift is aft of the center of gravity. *Now if you push down on the tail, the airplane will rotate about the center of lift. *Wouldn't it work the same way in the air? They aren't equivalent situations, mechanically speaking. As I understand it, the force of the tail plane's elevators typically moves the center of lift forward and backward along the airplane's axis as the elevators are moved up and down (as well as changing the lift magnitude a little - though that is secondary). One presumably enters stable flight when the center of lift is moved to coincide with the center of gravity. Actually as I understand it in stable flight the CL is aft of the CG. The airplane remains level not because these two are in line, but because the tail is pressing down to counterbalance the offset of the CL. After thinking about this question some more, it strikes me that this situation is equivalent to a lever and fulcrum. The lever doesn't rotate around it's CG, it rotates around the fulcrum point. In an airplane, this point is the center of lift. Regarding the CL moving around, I think even given that complication the airplane would still rotate around the CL. Phil |
#36
On Jan 26, 5:19 am, Stealth Pilot wrote: On Fri, 25 Jan 2008 17:03:04 -0800 (PST), wrote: And if the CG is moving horizontally at 100 knots, where is the rotation point now? As soon as rotation starts, the aircraft begins to change its flight path, and any determination of rotation point, whether it's the CG or CP or any other point, becomes very hard to determine and might be irrelevant. I would prefer to think of the fixed end of the flight path radius (which is also changing) as the airplane rotates, just like one of those complicated cabinet door hinges that has two arms and four pivot points. Where is the rotation point of that door? There is no fixed point. Dan clueless. you'd never have understood the propeller like the wrights did because you cant simplify situations until the problem becomes solveable. finding a solution to a problem is often a matter of thinking about it with just the relevant factors at play. the answer to your door problem lies in understanding that there are multiple hinge points that each act in a simple manner. the frame of reference is moving at 100 knots. the aircraft rotates about it's centre of gravity (centre of mass). You are assuming that the aircraft rotates about its CG as it would in space. But we're NOT in space, and lift and drag and various vectors all come into play here. As the aircraft rotates nose-up, CL (coefficient of lift) increases; CP shifts forward; the relationship between CG and CP changes because of the CP shift, and especially so if the CG is well above or below the CP; the tail's downforce increases, adding another vector to the whole thing. Then we have thrust and drag trying to rotate the airplane around some other point. We can't consider mass alone if we're trying to figure a rotational point. If mass is all you're concerned with, then the CG is good enough. I'd rather have more than mass acting on my airplane; it flies better that way. Kerschner likely has something to say on it. I'll have a look. Dan All those aerodynamic forces act on the CG (center of mass) to move it in a different direction, but it is still that center of mass that needs to move, so the aircraft (or any other free body for that matter) will move around that point. |
#37
clueless. you'd never have understood the propeller like the wrights did because you cant simplify situations until the problem becomes solveable. I believe you have just stated (magnificently I might add :-))) the antithesis of Occam's Razor, which is most certainly a "can" and not a "can't. :-)) In other words, it is a basic principle of mathematics to reduce the problem to it's simplest form and then solve it. :-)) -- Dudley Henriques |
#38
Bertie the Bunyip wrote:
Jim Logajan wrote: As I understand it, the force of the tail plane's elevators typically moves the center of lift forward and backward along the airplane's axis as the elevators are moved up and down (as well as changing the lift magnitude a little - though that is secondary). One presumably enters stable flight when the center of lift is moved to coincide with the center of gravity. That's exactly the case if you include the stab in the CL equation. If you're just referring to it on the wing itself, providing the AoA and speed remain the same it doesn;t shift. It's a matter of definition. Just checked one of my references[*] for proper terminology - where I used "center of lift" it uses the phrase "total lift" with the symbol L. For the lift of the main wings it uses Lw and for the lift of the tail it uses Lt. [*] "Aerodynamics, Aeronautics, and Flight Mechanics" by Barnes W. McCormick. |
#39
An object's motion can surely be described as the translation of its
center of gravity and rotation around it, but the point many are missing is, those simplifications hold best when there are no external forces acting on the body. In the case of an airplane entering a climb, there are external forces. If allowed to specify those forces I can make it rotate around any point. Consider a modification of an example given earlier -- with supports under the wings. Of course if you then rock the airplane it will rotate around that pivot point. If you put the support under the engine, it will rotate around that point. That support is applying an external force. If the elevator is applying a force, and the wings are applying forces, as is gravity, with the correct application of those forces the center of rotation can be anywhere! On Jan 26, 9:40*am, "Blueskies" wrote: "Stealth Pilot" wrote in messagenews:sc9mp3hsojk4d6dluj7pe5q4h2l1hrgfb9@4ax .com... On Fri, 25 Jan 2008 19:33:58 -0800 (PST), Tina wrote: There's a physics issue here called 'frame of reference.' Think about an external stationary (with respect to the air mass) observer, and the airplane is made to fly a loop. The center of rotation to that obsever is the center of the loop. Or, if the observer tracks the airplane, or even its CG (assume it's marked on the airplane) he'll see it move laterally at airspeed, then at the start of the climb will probably see it dip a little bit, then start assending. I'm having a hard time imagining a frame of reference where the airplane would appear to rotate about its CG, where I take 'rotate' to mean a point about which the tail end goes down and the other end goes up, because the CG itself will be moving, first down a little (I think) then up. Down first because the elevator is adusted so it loses upward lift of increases downward thrust, effectively making the airplane heavier. As the aoa increases the wings (making a huge number of assumptions (assume a spherical cow?) increase lift. Note also that the 'center of lift' of a wing may change with aoa, so even that model -- all effective lift concentrated at a fixed point -- may fail. You are confusing the forces here. The CG is the center of mass, period. The only way it moves is if the masses on the aircraft physically change position (burning or transferring fuel, PAX moving, etc). Moving the elevator does not change the CG, it changes the AOA (if the plane is flying) and that change in AOA causes and change in C/L which moves the CP. A more minor point, (but why not pick nits?) is that it's unlikely the CG, center of lift of the wing, and center of lift of the elevator are all in a straight line. In a high winged airplane the center of lift, about a third of the way back from the front of the wing, and probably pretty close to the wing's underside skin, is well above the CG. That vertical displacement will not affect computing moments for horizontal flight, but will as directions of flight different from horizontal take place. Think for a moment or two about a helocopter in horizontal flight transitioning to a nose up attitude. When I've seen that, it appears the center of rotation is well above the hellcopter. When *watching the Blue angels perform in hte F-18, it becomes apparent that the aircraft is rotating around the CG, and the movement of the CG defines the flight path. You can see the controls wiggling and the nose moving up and down, but the plane stays in the same relative position to the others. All those aerodynamic effects do not change the CG of the aircraft. This is one of the reasons I liked watching them fly trhe A4s better. The F-18 has negative stability and needs to always be seeking controlled flight, while the A4 was a positive stability craft and looked like it was on rails... I know, there's nothing like adding some mud to the water. no mud at all. consider another situation that may provide some insight. when an aircraft is falling in a spin what does it spin about? If the plane was moved out of the atmosphere it would tumble around the CG.. Same answer here...- Hide quoted text - - Show quoted text - |
#40
Phil J wrote:
Actually as I understand it in stable flight the CL is aft of the CG. The airplane remains level not because these two are in line, but because the tail is pressing down to counterbalance the offset of the CL. I should have used the term "total lift" so as to avoid confusion with the lift generated only by the main wings. What you state above appears internally consistent and correct with the definitions you are using. After thinking about this question some more, it strikes me that this situation is equivalent to a lever and fulcrum. The lever doesn't rotate around it's CG, it rotates around the fulcrum point. In an airplane, this point is the center of lift. Whether you are talking about center of total lift (that generated by the main wings, tail or canards, and fuselage) or center of lift of the main wings, what you state above is _incorrect_. I know that what you wrote sounds plausible, but the problem is that the main wings are no more a fulcrum than the tail wings. Suppose the main wing and the tail wing are very nearly the same size and produce nearly the same lift and all have elevator controls? Which line is the fulcrum point now about which the airplane rotates? Regarding the CL moving around, I think even given that complication the airplane would still rotate around the CL. Here's a NASA web link that explains where the rotation point is: http://www.grc.nasa.gov/WWW/K-12/airplane/acg.html Try to find some books on flight mechanics and look for the chapters or sections that appear to discuss longitudinal static stability of aircraft. They should all say that the aircraft rotates about the center of gravity. |
| Thread Tools | |
| Display Modes | |
| a question for the aeronautical engineers among us | Tina | Piloting | 10 | November 4th 07 01:56 PM |
| Are flight engineers qualified to fly? | Mxsmanic | Piloting | 14 | January 23rd 07 08:39 PM |
| Aerodynamic Drag | Kyle Boatright | Home Built | 7 | September 26th 05 04:34 AM |
| Aerodynamic Simulation of Standard Cirrus Glider | Jim Hendrix | Soaring | 13 | November 10th 04 12:38 AM |
| Airfoil aerodynamic simulator... | Thomas J. Paladino Jr. | Piloting | 4 | May 17th 04 03:41 PM |
