About Stall Psychology and Pilots
Old February 16th 08, 10:21 PM posted to rec.aviation.piloting
Default About Stall Psychology and Pilots
Are you familiar with what Derrik Piggott has written about some peoples
sensitivity to reduced G forces? It used to be on-line but I can't find
a copy anymore.
I haven't heard of this study but will suggest a technique recommended
by an instructor who was also a downhill skiier -- instead of tensing
up and "backing away" from the "fall", lean forward and go with it.
As Dudley said, prepare for it in your head. The physical corollary is
to lean forward a tiny bit.
Try it next time you're on a roller coaster.
Dan
  #32
Old February 16th 08, 10:39 PM posted to rec.aviation.piloting
Ken S. Tucker
On Feb 16, 2:08 pm, "Private" wrote:
"Ken S. Tucker" wrote in ...
As much as I like the "dud" his post is the
most completely idiotic thing I had to read.
On Feb 16, 12:10 pm, Dudley Henriques wrote:
It's interesting to note that although stall recovery should be thought
of as something done with a minimum loss of altitude, the emphasis on
recovery should always be placed on the regaining of angle of attack as
PRIME to recovery.
NUTZ. You need airspeed, it's called kinetic
energy that is needed to suck off, using the
wings (you know, those little things that
protude out the side of airplanes).
I am one instructor who strongly believes that instructors should
consider altering their approach to teaching stall to focus more
strongly on recovering angle of attack than recovering in minimum
altitude.
See KIAS, Dud, you'd last 2 minutes in the RHS
of my plane, after that you'd be lickin' pavement,
from my shoe on your ass.
Stalls entered at low altitude have many times resulted in
secondary stall entry or a mushed recovery followed by ground impact by
pilots who COULD have lowered the nose and held it down there a bit
longer than they did, using the air under them to better advantage and
giving themselves the needed time to regain angle of attack and smooth
airflow as they attempted a recovery. But because they had been taught
that ALTITUDE rather than AOA was the killer, they recovered trying to
save altitude, when in reality what was needed was to USE THE AVAILABLE
ALTITUDE CORRECTLY....and save the airplane.
Toward this goal, I strongly encourage all CFI's to reference AOA in
stall recovery. This doesn't mean INSTEAD of altitude, but it does mean
that to recover the airplane, you absolutely HAVE to restore AOA, and at
low altitude that might very well mean using available altitude to the
last foot of air to do that.
I have always taught stall recovery both with and without power. The FAA
requires power. I want the student to see the difference and at the same
time be able to stress that it's the ANGLE OF ATTACK that saves your
butt. The strong lesson here is that you USE altitude......you don't try
to minimize it at the expense of angle of attack.
Dud, you're clueless, you have not a clue about KIAS,
spiral dives or g-force recovery's. In short I see NO
evidence you have even been in an airplane with your
focus on AoA.
I can get a good AoA at 10 KIAS or 200 KIAS,
what are going to do?
Regards
Ken
Ken,
With respect, I think you must have missed my reply in another thread. I am
enclosing it here for your convenience and consideration.
"Private" wrote in message
"Ken S. Tucker" wrote in message
I was out paying taxes, to get some coin for the
piggy bank, I shook it 3 times and still didn't hear
any rattling, that's simple accounting to tell me
when I'm broke, works every time!
Ken
Some here would suggest that you apply the same strategy to your head
before
posting.
I am somewhat embarrassed to be entering this thread, but I just can't
resist swinging at a soft pitch like that.
Happy landings,
To elaborate, my suggestion was that before posting you should give your
head a shake to determine if there is anything inside and to consider
whether you really wished to make the fact public.
Happy landings,
If I were you, I'd ****-off and read.
You're swinging at screw-balls...
Me and the "dud" ****ed your mush mind.
Get a ****in life, crack a book.
Best Regards
Ken
xxxx
  #34
Old February 16th 08, 10:42 PM posted to rec.aviation.piloting
Bertie the Bunyip[_24_]
"Ken S. Tucker" wrote in news:1f25eddb-4c7f-
thought
as
PRIME to recovery.
altitude.
by
and
smooth
taught
to
AVAILABLE
mean
at
FAA
same
try
focus on AoA.
Again with the bank rattling.
Bertie
  #35
Old February 16th 08, 10:43 PM posted to rec.aviation.piloting
"Private" wrote in :
"Dudley Henriques" wrote in message
thought of as something done with a minimum loss of altitude, the
emphasis on recovery should always be placed on the regaining of
angle of attack as PRIME to recovery.
Agreed, I have always thought of myself as flying a wing to which is
attached a fuselage rather than the reverse.
Xactly right IMO. All you need is a wing to fly, after all.
Bertie
  #37
Old February 16th 08, 10:48 PM posted to rec.aviation.piloting
Peter Dohm
"Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote in message
news:nfWdnZsrSOkXpiranZ2dnUVZ_g2dnZ2d@wideopenwest .com...
You're right. Power on stalls have a natural tendency to make newbies
more nervous than power off. The nose attitude is generally higher, it's
louder, (this is a factor BTW), the break is cleaner and more sudden, and
the recovery can seem hurried to a newbie who is experiencing the
recovery under stress.
sensitivity to reduced G forces? It used to be on-line but I can't find a
copy anymore.
But his theory is that some people react very poorly to reduced G and will
can attempt to "brace" themself to avoid falling which can result in an
accident when stalling at a low altitude...
I'll have to keep looking - it was an interesting read for me since my
youngest just HATES even things like elevators or driving over a bit of a
hill (reduced G situations)
Geoff
I think that Google found it for me and the spelling of the author's first
name is Derek The article is at:
http://www.danlj.org/~danlj/Soaring/Clues/SDO.html
Peter
  #38
Old February 16th 08, 10:56 PM posted to rec.aviation.piloting
messagenews:1f25eddb-4c7f-4bde-a4fa-3cc5d7844522
@e23g2000prf.googlegro
altitude.
impact by pilots who COULD have lowered the nose and held it down
there a bit longer than they did, using the air under them to
better advantage and giving themselves the needed time to regain
angle of attack and smooth airflow as they attempted a recovery.
But because they had been taught that ALTITUDE rather than AOA was
the killer, they recovered trying to save altitude, when in
reality what was needed was to USE THE AVAILABLE ALTITUDE
in stall recovery. This doesn't mean INSTEAD of altitude, but it
does mean that to recover the airplane, you absolutely HAVE to
restore AOA, and at low altitude that might very well mean using
available altitude to the last foot of air to do that.
The FAA requires power. I want the student to see the difference
and at the same time be able to stress that it's the ANGLE OF
ATTACK that saves your butt. The strong lesson here is that you
USE altitude......you don't try to minimize it at the expense of
angle of attack.
focus on AoA.
Regards
Ken
Ken,
thread. I am enclosing it here for your convenience and
consideration.
news:64fb5517-76cc-49df-8db1-
m...
Ken
head before
posting.
can't resist swinging at a soft pitch like that.
Happy landings,
your head a shake to determine if there is anything inside and to
consider whether you really wished to make the fact public.
Happy landings,
Some people read 'em. Others write them..
Well, I certainly am.
Bertie
  #39
Old February 16th 08, 11:31 PM posted to rec.aviation.piloting
WingFlaps
Cuniform tablets are quite outdated ...
Cheers
  #40
Old February 16th 08, 11:36 PM posted to rec.aviation.piloting
WingFlaps
On Feb 17, 11:41*am, Bertie the Bunyip wrote:
wrote :
On Feb 15, 6:37 pm, Bertie the Bunyip wrote:
"Robert M. Gary" wrote in
news:ebb74b75-9910-4c50-ae86-
Dudley Henriques wrote in
Man there are a lot of posts on this topic. Too much newsgrouping,
people need to do more flying
When my airplane is finished!
Bertie
Watchu building?
A Hatz, but it's a Citabria being restored I'm waiting to fly.
Are you building alone? How far along is it? Where is it -I'd like to
see it if I got the chance.
Cheers
Stall Recovery Danny Deger Piloting 12 January 30th 07 01:01 AM
stall strips ??? Tri-Pacer Owning 6 December 8th 06 06:18 PM
Bad place to stall Stubby Piloting 23 June 21st 05 04:10 PM
Wing Stall PaulaJay1 Owning 18 December 11th 03 07:46 PM
Stall resistant 172? Roger Long Piloting 19 October 18th 03 11:48 PM
