Bad fuel gauges?
Old February 24th 08, 12:18 PM posted to rec.aviation.piloting
Bob Noel
Default Bad fuel gauges?
Andy Hawkins wrote:
And if you've left the fuel cap off in your pre flight, and your fuel has
gradually been ****ing all over the wing, how will you know?
In a low wing Piper, you look over and see the fuel flowing out of the hole.
You don't need a gauge to detect that hazard. (Perhaps this is another
advantage of flying a cherokee)
Bob Noel
(goodness, please trim replies!!!)
Old February 24th 08, 02:01 PM posted to rec.aviation.piloting
Peter Clark
On Sun, 24 Feb 2008 07:18:25 -0500, Bob Noel
And at night?
Old February 24th 08, 08:15 PM posted to rec.aviation.piloting
Andrew Sarangan
On Feb 24, 7:18 am, Bob Noel
Bob Noel
I have flown airplanes with a fuel sump drain that would not close
properly. This always happened when I took a fuel sample from the
sump, so it was was easy to notice it and fix it. But if it can happen
on the ground, it could also happen during flight.
An accurate fuel gauge is long overdue in aviation. It doesn't have to
be fancy gadgetry, fuel flow integrators or capacitive sensors. One of
the experimental guys had installed a simple pressure sensor under the
fuel tank which measured the total weight of the fuel tank. While not
perfect, it was far better than anything else I have seen, including
sight gauges.
Old February 24th 08, 01:01 AM posted to rec.aviation.piloting
On Feb 23, 7:10*pm, "Bob Gardner" wrote:
The best fuel gauge is a watch.
The best fuel gauge is a watch IN CONJUNCTION with an actual fuel
gauge. Neither suffices by itself.
Time, running out of fuel and fuel gauges Dylan Smith Piloting 29 February 3rd 08 07:04 PM
Russian Airplane Instrument Gauges Steve Restoration 1 October 2nd 06 10:50 PM
Fuel Level Sight Gauges DonMorrisey Home Built 5 August 10th 06 05:00 AM
Need the temp and oil pressure gauges for a J3, where do I get them? Eduardo B. Restoration 0 December 5th 03 12:59 PM
FA: Vintage aircraft gauges Randal Peterson Aviation Marketplace 0 November 13th 03 02:05 AM
