Feds Want to Equipe Gliders With Transponders and Radios
Old April 29th 08, 09:59 AM posted to rec.aviation.piloting,rec.aviation.soaring
Peter Dohm
Default Feds Want to Equipe Gliders With Transponders and Radios
"Cats" wrote in message
On Apr 28, 7:44 pm, Larry Dighera wrote:
snip
The issue in equipping gliders with transponders, the way I see it, is
the high power consumption required by transponders. Here's a typical
glider transponder:http://www.airplanegear.com/becker.htm
It seems to draw 175W to 250W. That's not insignificant, and way more
than the comm radio consumes. Then there's the weight and antenna
that reduce performance, not to mention the cost of the equipment,
installation, and maintenance.
You need to find the overall consumption, not what is used when it is
squawking.
As to weight - since we frequently put water in gliders to improve
performance, I can't see a problem there, and the antenna will be
inside the glider so won't increase drag.
But you are right that buying and installing a transponder isn't a
cheap thing.
-------------new message begins-------------
I 'm confident that the installation is the biggest part of it--especially
when you include enough solar panels to power it all reliably.
Peter
Old April 30th 08, 05:27 AM posted to rec.aviation.piloting,rec.aviation.soaring
Morgans[_2_]
Why solar cells? A 7 amp hour lead acid gel cell can be had for about 20 bucks,
and would run a solid state transponder for a whole flight.
Old April 30th 08, 12:08 AM posted to rec.aviation.piloting,rec.aviation.soaring
BT
You can't put the antenna on the inside of a carbon fiber fuselage, well,
you could, but it would not work.
Not all gliders have excess usable weight available to carry water.
BT
_____________
squawking.
cheap thing.
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Piloting 155 May 10th 08 02:45 PM
Feds Want to Equipe Gliders With Transponders and Radios Larry Dighera Soaring 12 May 1st 08 03:42 PM
Gliders, transponders, and MOAs Greg Arnold Soaring 2 May 26th 06 05:13 PM
Transponders and Radios - USA Ray Lovinggood Soaring 1 February 27th 04 06:10 PM
Transponders, Radios and other avionics procurement questions Corky Scott Home Built 5 July 2nd 03 11:27 PM
