#31
![]() Guys, I think we're all stressed from lack of flying and need to calm down a bit and stop over-analyzing this one. Yes, the point of the "front half" business is to further discourage starting out the back or back of the top and bumping gaggles along the top edge of the start cylinder. Yes, the area in which you get full credit for distance is described by a gentle semicircle defined by the first turn fix. Therefore, yes, you don't know exactly where the area is before you get to the first turnpoint. However, nothing terrible happens to you if you start outside of the "front half." No penalties, no invalid starts, nothing. You just don't get full credit for distance. In typical starts out the top, a half knot of extra thermal strength will be much more important than even being a mile outside of the extra credit area. Remember, people used to start out the top back when they got no credit at all for extra distance. Knowing the exact location of the "extra credit" area is just not that important. Thus, if you want to start out the top, the right strategy is to look for the best possible thermal in the front half to two thirds of the start cylinder. Programming semicircles into your flight computer and staring at that isn't going to do any good compared to looking for a good thermal. In these extreme situations such that you might be heading 30 degrees to the left or right of "courseline" into a huge first turn area, let me suggest that if you have no idea before start whether you're going to head 30 degrees to the left or 30 degrees to the right, you need to do some better pre-start thinking rather than worry about start geometry! Yes, this means that the very back of the start cylinder is disadvantaged for starts out the top. The RC is very worried about the "bump the gaggle" business, especially if the first leg is downwind. We judged that at least to start with the benefit outweighs the cost. In the future, we can remove or relax this rule if it is proving too constraining. Another possibility is to remove some of the "last valid start" language and let this simple rule alone police the "bump the gaggles" problem. But clearly if we see bump the gaggles behavior, or heaven forbid a crash, the whole start anywhere concept will be in danger. Hence, we thought it better to start conservatively. Let us know your experiences this year John Cochrane BB |
#32
On Jan 8, 12:15�pm, wrote:
On Jan 8, 10:41�am, Tim Taylor wrote: �What you describe can still happen with the new rules so I guess I don't see the point in trying to make the rule more complex. �I can climb up right at the center of the cylinder and dive through the gaggle five miles ahead as long as I don't stay in the cylinder longer than 2 minutes. �Maybe we need to shorten that time to 1 minute so they are likely to get a new start time and make the whole idea of hitting the front edge worthless. Good points Tim. �It feels like an attempt to solve a problem that doesn't happen much and in doing so negates some of the benefits of the original rule change while only halfway meeting the objective of making the "bump and run" strategy hard to pull off when it is an option. Andy's suggestion of a fixed front half should work - with the understanding that under the worst case scenario a pilot could technically line up a course line that ran for 10 miles along the straight edge of the half-cylinder - just the way the angles work out. Would it happen very often? Who the heck knows? It would be simpler to understand. The other possible approach would be to make the start cylinder smaller (like 3 miles) - no software re-programming required. I like the bigger cylinder, but it would be an easier experiment to run in 2009. 9B The rules are written as an agreement between several parties. This agreement requires all entrants to be in agreement with the rules and each other. All entrants must be on equal ground and must not be required to have special, expensive software which only a few can afford. If one wishes to start anywhere within the defined start circle, or turn anywhere they choose within the defined turn area, they must not have the fear that if they don't have the new and expensive software they might not recieve their flown distance. The problem is trying to make something work that has these restrictions which has been pointed out by several of you. I do believe the rules committee has seen this and is working on it. If starting out the top is what is normally not done by almost all the entrants, has not been normally seen, then simply stop it. Most contest managers that I have spoken with, starting out the top is their worst fear for possible problems. This one point of starting out the top was the underlying reason why the NSF closed its doors in Hobbs. They were very concerned about one hot jock starting out the top and bouncing his way thur the gaggles. I was their, I saw the IGC files, and became very involved with this topic. We finally got a finish which you can't pull up into. I, and another, almost got knifed in half, when someone pulled up right in front of us inside the circle, during the finish. We were at 500 agl. and chutes don't work from 500 ft. agl. How can this "new start anywhere" be a "start anywhere" when you can't do that? That's the crazest dang thing I ever heard. Almost all of us forgot their geometry 101 in high school. New entrants (or any entrants) flying in any class should be able to understand the rules and not feel they are at a disadvange before they even get to the contest. They won't even come. The contest, yes, the contest, should not start before the start. The start must be fair and equal to all entrants. Not just to a few who have more knowledge than most of us. Many thanks to both Andy's on bring this up. I do believe the rules committee is working on this, because BB hasn't shown up yet and told us different. I do believe what the rules committee is trying to do is stop the starting out the rear half, why? because if the first leg is downwind, its best to start as far upwind as you can, as it makes the last leg home into the wind shorter, which saves time. Remember well that XX talks about saving seconds. By starting up near one side of the circle you can again use the wind, maybe a quartering tail wind, to fly to the far otherside of the first turn circle, again saving time. Remember, even on blue days, streets of lift do line up, reread A J Smith on this. Now, new folks don't read RAS and most of you already knew this, so I feel safe in talking about this. But, is this fair to all entrants? As long as I win, it sure is..........cause I will tell them they could of read it on RAS............. Thermal tight, Soar high, Fly safe........#711. |
#33
I'm confused about the "bouncing start gaggles" issue? If I start out
the top (at the back, for sake of argument), and stay above the MSH, I'm on course. If I see a gaggle above MSH in front, I would be stupid not to take advantage of their thermal - but unlikely to be high enough to aggressively "bounce" it. If I drive down into a start gaggle and drop back below MSH, then I should be penalized if I don't hang around for 2 minutes - which would pretty much waste the advantage of starting out the top earlier. So, take away the option of the earlier start if you subsequently clip the edge of the start cylinder - It would force you to either fly conservatively enough to be sure not to drop back below MSH, or make you hang around for 2 more minutes if you misjudge your out-the-top start. I don't like the proposal as stated - the start area should not be variable, in any way - that's poor rule making, IMHO. I would prefer to use the 2008 start anywhere rule as is, and see if gaggles get bounced. Out west, of course. Not likely where I'm racing these days! Kirk 66 |
#34
Captain Kirk:
We will gather good notes at Parowan (and elsewhere) this summer and forward them to the RC. Hopefully it will take us back to the 2008 version, but let's belly up to the bar and follow the process. -Scotty |
#35
On Jan 8, 2:45*pm, wrote:
Guys, I think we're all stressed from lack of flying and need to calm down a bit and stop over-analyzing this one. Yes, the point of the "front half" business is to further discourage starting out the back or back of the top and bumping gaggles along the top edge of the start cylinder. Yes, the area in which you get full credit for distance is described by a gentle semicircle defined by the first turn fix. *Therefore, yes, you don't know exactly where the area is before you get to the first turnpoint. However, nothing terrible happens to you if you start outside of the "front half." No penalties, no invalid starts, nothing. You just don't get full credit for distance. In typical starts out the top, a half knot of extra thermal strength will be much more important than even being a mile outside of the extra credit area. Remember, people used to start out the top back when they got no credit at all for extra distance. Knowing the exact location of the "extra credit" area is just not that important. Thus, if you want to start out the top, the right strategy is to look for the best possible thermal in the front half to two thirds of the start cylinder. Programming semicircles into your flight computer and staring at that isn't going to do any good compared to looking for a good thermal. In these extreme situations such that you might be heading 30 degrees to the left or right of "courseline" into a huge first turn area, let me suggest that if you have no idea before start whether you're going to head 30 degrees to the left or 30 degrees to the right, you need to do some better pre-start thinking rather than worry about start geometry! Yes, this means that the very back of the start cylinder is disadvantaged for starts out the top. The RC is very worried about the "bump the gaggle" business, especially if the first leg is downwind. We judged that at least to start with the benefit outweighs the cost. In the future, we can remove or relax this rule if it is proving too constraining. Another possibility is to remove some of the "last valid start" language and let this simple rule alone police the "bump the gaggles" problem. But clearly if we see bump the gaggles behavior, or heaven forbid a crash, the whole start anywhere concept will be in danger. Hence, we thought it better to start conservatively. Let us know your experiences this year John Cochrane BB John, If the rules committee has already made up its mind, why ask for input? Your comments in one of your earlier threads eluded to the prestart issues at Uvalde under the old rules. 1. I don't see how the new rules prevents the bump and run (there is still 5 miles from the center to the edge). I can climb up 1500 feet over the top, and hit the edge at 90 knots and bump any thermal there and be gone before I have spent two minutes below height to get a new start. If I am 10 miles back at the back edge I am likely going to be going at an angle away from the front edge and I would have to be significantly higher so that I would not spend two minutes back in the cylinder during the crossing. 2. It encourages everyone to start at the front edge like before. The arc of the eventual first turn point the center of the start cylinder limits where you should start in the start cylinder. Anyplace else takes a distance penalty like before. 3. If the goal is to minimize the bump and run, cut the time under altitude to a lower number or set a speed limit in the cylinder. 4. Anyone crazy enough to bump and run a prestart gaggle should be hit with an "unsafe flying" penalty if they go through the middle of a gaggle without working in from the outside. I think that rule already deals with the issue. As a engineer we work on the KISS principle of design (and rules). Tim (TT) |
#36
On Jan 8, 1:45*pm, wrote:
Guys, I think we're all stressed from lack of flying and need to calm down a bit and stop over-analyzing this one. Yes, the point of the "front half" business is to further discourage starting out the back or back of the top and bumping gaggles along the top edge of the start cylinder. Yes, the area in which you get full credit for distance is described by a gentle semicircle defined by the first turn fix. *Therefore, yes, you don't know exactly where the area is before you get to the first turnpoint. However, nothing terrible happens to you if you start outside of the "front half." No penalties, no invalid starts, nothing. You just don't get full credit for distance. In typical starts out the top, a half knot of extra thermal strength will be much more important than even being a mile outside of the extra credit area. Remember, people used to start out the top back when they got no credit at all for extra distance. Knowing the exact location of the "extra credit" area is just not that important. Thus, if you want to start out the top, the right strategy is to look for the best possible thermal in the front half to two thirds of the start cylinder. Programming semicircles into your flight computer and staring at that isn't going to do any good compared to looking for a good thermal. In these extreme situations such that you might be heading 30 degrees to the left or right of "courseline" into a huge first turn area, let me suggest that if you have no idea before start whether you're going to head 30 degrees to the left or 30 degrees to the right, you need to do some better pre-start thinking rather than worry about start geometry! Yes, this means that the very back of the start cylinder is disadvantaged for starts out the top. The RC is very worried about the "bump the gaggle" business, especially if the first leg is downwind. We judged that at least to start with the benefit outweighs the cost. In the future, we can remove or relax this rule if it is proving too constraining. Another possibility is to remove some of the "last valid start" language and let this simple rule alone police the "bump the gaggles" problem. But clearly if we see bump the gaggles behavior, or heaven forbid a crash, the whole start anywhere concept will be in danger. Hence, we thought it better to start conservatively. Let us know your experiences this year John Cochrane BB We do turn into tire-biters in the winter don't we? Now, back at it: John - I take your points on the scenarios probably being relatively low probability If risk of traffic conflict in the start cylinder is the big concern I can totally understand the RC taking a conservative approach - the last thing you'd want to do is make a rule change that gets somebody hurt or their glider broken. It's a big responsibility. The conundrum is that the conservative approach is kind of like the old joke about clapping your hands to keep the elephants away - the only way to know if it works is to stop clapping, but who wants to risk it? Inch by inch we add little complexities into the rules because we can imagine something that might not be right about the simple version. That of course means that it can be hard to work these things out of the rules because you never know at what point the elephants come back. But what if the elephants are just in our imagining? It's not an easy question and please don't take this discussion as criticism of what you guys do. I, for one, am just trying to figure out what it means so I don't have to deal with in on the fly next year. Tuno's recommendation is a good one - which is to look at a reasonable sample of 2007, 2008 and 2009 contests from the east and west, big and small (especially big), with MSHs in all the various relationships to top of lift and cloud base to see what pilots actually do differently. The RC may do this already in some form. Obviously individual feedback is the only way to know how people feel about the operational and workload aspects of it. Andy |
#37
On Jan 8, 2:45�pm, wrote:
Guys, I think we're all stressed from lack of flying and need to calm down a bit and stop over-analyzing this one. Yes, the point of the "front half" business is to further discourage starting out the back or back of the top and bumping gaggles along the top edge of the start cylinder. Yes, the area in which you get full credit for distance is described by a gentle semicircle defined by the first turn fix. �Therefore, yes, you don't know exactly where the area is before you get to the first turnpoint. However, nothing terrible happens to you if you start outside of the "front half." No penalties, no invalid starts, nothing. You just don't get full credit for distance. In typical starts out the top, a half knot of extra thermal strength will be much more important than even being a mile outside of the extra credit area. Remember, people used to start out the top back when they got no credit at all for extra distance. Knowing the exact location of the "extra credit" area is just not that important. Thus, if you want to start out the top, the right strategy is to look for the best possible thermal in the front half to two thirds of the start cylinder. Programming semicircles into your flight computer and staring at that isn't going to do any good compared to looking for a good thermal. In these extreme situations such that you might be heading 30 degrees to the left or right of "courseline" into a huge first turn area, let me suggest that if you have no idea before start whether you're going to head 30 degrees to the left or 30 degrees to the right, you need to do some better pre-start thinking rather than worry about start geometry! Yes, this means that the very back of the start cylinder is disadvantaged for starts out the top. The RC is very worried about the "bump the gaggle" business, especially if the first leg is downwind. We judged that at least to start with the benefit outweighs the cost. In the future, we can remove or relax this rule if it is proving too constraining. Another possibility is to remove some of the "last valid start" language and let this simple rule alone police the "bump the gaggles" problem. But clearly if we see bump the gaggles behavior, or heaven forbid a crash, the whole start anywhere concept will be in danger. Hence, we thought it better to start conservatively. Let us know your experiences this year John Cochrane BB John Cochrane, the below is your post from DEC. 24, 2008............ More options Dec 24 2008, 1:37 pm Newsgroups: rec.aviation.soaring From: Date: Wed, 24 Dec 2008 12:37:40 -0800 (PST) Local: Wed, Dec 24 2008 1:37 pm Subject: Start Anywhere Reply | Reply to author | Forward | Print | Individual message | Show original | Report this message | Find messages by this author Maybe we can convince John to write us a nice explanation of the various tactical advantages/disadvantages of side vs top starts with high or low MSH and strong/weak lift! Alas, there's not much to say. The RC is very determined not to introduce rules that require lots of strategizing and have secret tricks to them. I can't think of anything clever to do with this one. Much of the attraction is that it removes a lot of tactics and geometry. In most contests, thermals are weak near the top of the start cylinder, or the top is near cloudbase, so there really isn't much to be gained by going out the top. Then, the most important consideration is to pick a start position that lines up well to clouds or lift sources on course. If there is wind, being on the upwind side of the cylinder is advantageous. Other things equal, the optimal start point is directly into the wind. Other things aren't equal of course. It will take a howling wind to get me away from a good looking cu that seems to line up with energy on course. ...................Now, can we have a public explaination, as to why on Dec. 24th, you tell us ( yes, in the above quote) what the rules committee doesn't want to do, BUT JUST DID, with this new half cylinder start. We are asked to debate the issue and then told by you not to worry about the flaws, as its only a few points??? Present day transparence should be required for all entrants, just not a few selected indiviuals. If you knew of these flaws when the half cylinder was designed, why didn't you speak then and why did you wait till now???? We are given an short notice on the review and when the flaws are discovered, we are then told not to worry about them, as its only a few points?? I want those few points, so why take them away and not give me them, oh, your doing it because of a flawed rule? Sounds like TARP all over again............. Talking around the issue doesn't solve the problem. If the concern is about starting out the top, then stop it. If their is NO proof of starting out the top as being a problem, then stop "thinking" of ways it could become one. Address the problem, if theirs been one to begin with, and stop creating new ones. |
#38
I asked in my initial post "How, with the proposed rule change, is the pilot expected to know whether the selected start cylinder exit point will result in a devalued first leg distance?" and part of your reply was However, nothing terrible happens to you if you start outside of the "front half." No penalties, no invalid starts, nothing. You just don't get full credit for distance. I'm surprised the RC thinks that not getting full credit for distance flown is of no consequence. In the past pilots have worked thermals away from the optimum start point and then lost altitude to exit at the optimum start point just so they are not timed on a mile or less that didn't earn any score. How is this different? I see no reason why a pilot that chooses to exit from the back of the cylinder cannot work any gaggle on route to the first turnpoint. Why does joining a gaggle in the vicinity of the start have a higher risk than joining one on course? I just don't see that the proposed rule, with its hidden complexity, is justified. Unsafe flying has always been subject to a severe penalty and anyone flying dangerously in, or above, the start cylinder is subject to that rule. Andy |
#39
On Jan 9, 9:30*am, Andy wrote:
I see no reason why a pilot that chooses to exit from the back of the cylinder cannot work any gaggle on route to the first turnpoint. *Why does joining a gaggle in the vicinity of the start have a higher risk than joining one on course? Traffic density near top of gate/cloud base, for starters. There's also the issue of blending on course traffic with pre-start traffic. From my point of view, the potential increase in opposing traffic near cloud base/top of gate would justify the rule by itself. More broadly, the rules strategy seems to be to take the incentive for competitive flying out of the gate area and move it out on course where it belongs. -T8 |
#40
On Jan 9, 8:43*am, wrote:
On Jan 9, 9:30*am, Andy wrote: I see no reason why a pilot that chooses to exit from the back of the cylinder cannot work any gaggle on route to the first turnpoint. *Why does joining a gaggle in the vicinity of the start have a higher risk than joining one on course? Traffic density near top of gate/cloud base, for starters. *There's also the issue of blending on course traffic with pre-start traffic. From my point of view, the potential increase in opposing traffic near cloud base/top of gate would justify the rule by itself. *More broadly, the rules strategy seems to be to take the incentive for competitive flying out of the gate area and move it out on course where it belongs. -T8 I'm still trying to work out in my mind how going with a 50% smaller start area DEcreases traffic density. I think the only relevant scenarios here are ones where you can start out the top of the cylinder - but can't climb high enough to clear the edge of the cylinder. That means the top of useable lift has to be within around 1,500' of MSH. Lower than that and pilots will find thermals closer to the edge of the cylinder or start out the side. Higher than that and any thermals you hit post-start will be with gliders that also have already started, which is basically indistinguishable from entering a thermal 5 miles out on course. That wouldn't appear to me to happen all that often and the CD could certainly try to avoid setting MSH close to the forecast top of lift. TT made the point that even with the proposed modification you still have 5 miles of radius to find a great start thermal that's somehow lined up with a gaggle on your intended course line. I don't think I can reliably see a glider from more than 5 miles away anyway so I don't think offering the full cylinder will do much to increase instances of people trying to do this in a premeditated way. I think it's safe to say that the main scenario is someone starting out the top who suddenly sees a gaggle along the way. BB made the point that some pilots may elect to start from behind the arc where they get distance credit if there's a good thermal to be had since they can still get a legitimate start. They will just fly a mile or two without getting credit for it. I'm thinking that would only really make sense it the lift were really awesome (to save the lost two minutes of on-course time you'd need to climb the fifteen hundred feet at 15 knots rather than at 5 knots for example), or you might do it if you were a dedicated pre-start gaggle bumper (the advantage here seems minimal - I don't think I can save 2 minutes - or 1 minute by bumping gaggles). In either case it would mean the rule change wasn't very effective. I get that the very back of the cylinder narrows a bit and so starters from way back there would tend to overfly the middle of the cylinder. I also get that traffic can fan out a bit on course - particularly if you have a short first leg with a very big turn area. But a 10-mile diameter start cylinder is pretty darn big - so the amount of fan-out on course seems to be small for most TATs and all ASTs and MATs with a first turn specified. My perception is that a factor in gaggling is pilots who wait for the post-start radio calls of other pilots and start right after them. Under the old rule you had a good sense of where they'd be because the optimal start point was at the edge of the cylinder near course line. Under the original start anywhere rule a starter could be anywhere in a 10 mile distance along course line and was a lot less likely to be near MSH if the lift was going higher, so it became pretty hard to time your start to reliably make a marker out of another pilot. Under the modified rule it may become a more manageable strategy. 9B |
FAA publishes proposed changes to amateur-built rules. | Jim Logajan | Home Built | 19 | July 28th 08 08:30 AM |
2009 U.S. Contest Locations/Dates | Tim[_2_] | Soaring | 2 | February 28th 08 05:48 PM |
2008 Proposed US Competition Rules Changes | [email protected] | Soaring | 18 | December 31st 07 07:21 PM |
US Contest Rules Proposed Changes for 2006 | Ken Sorenson | Soaring | 18 | January 12th 06 04:30 PM |
Proposed 2005 Rules On SRA Site | Ken Kochanski (KK) | Soaring | 79 | January 27th 05 06:51 PM |
