Hyabusa flat 8
Old March 6th 09, 08:38 PM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Peter Dohm
Default Hyabusa flat 8
"Maxwell" #$$9#@%%%.^^^ wrote in message
"platypus" wrote in message
Wicked Uncle Nigel wrote:
Using the patented Mavis Beacon "Hunt&Peck" Technique, "TOG@Toil"
typed
On 6 Mar, 11:03, bod43 wrote:
On 5 Mar, 21:57, "Morgans" wrote:
snip interesting stuff
Maybe someone on uk.rec.motorcycles might have an
idea as to the expected life span of a hyabusa engine
when operated in a constant load regime,
say at 130bhp.
You'd need to boost the low and midrange torque to swing a prop, as
props rotate relatively slowly, don't they? I think a 'Busa engine
would last forever is detuned to 130bhp.
Depends on the prop, but I would think that gearing down would be the
way to go.
The thing that everyone seems to forget when promoting automotive engines
for aircraft is that most piston aero engines have a very hard life.
Take-off and climb is full power or very nearly, then they throttle back
to cruise at 75% or thereabouts. The only roadgoing vehicles that
approach that sort of use are in motorsports, and how long do they last?
Not true at all.
Ever driven a gas powered motor home, pulling a boat trailer. I drove a
6500 series Chevy dump truck years ago, always pulling a Case 580C back
hoe. It was 100% power almost all the time, and always at lease 75% on the
highway. I have seen lots of auto engines successfully suffer MORE abuse
than aircraft engines in many circumstances, and most often do it without
proper maintenance. Some school bus and UHaul truck engines deserve to be
in the Motor Sports Hall of Fame.
But that doesn't solve all the propeller and PSRU issues.
Nicely said.
  #32
Old March 7th 09, 12:16 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Ace[_2_]
m...
Not true at all.
I drove a 6500
series Chevy dump truck years ago, always pulling a Case 580C back hoe. It
was 100% power almost all the time, and always at lease 75% on the highway.
But that;s true of nearly all agricultural vehicles, which is why they
tend to use understressed, low-revving, low-tech motors. And just
because you can drive them on the road doesn't make the road-going
vehicles.
  #33
Old March 7th 09, 12:17 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Morgans[_2_]
"TOG@Toil" wrote
Which was what I was thinking. I mean, what was max revs for a Merlin?
Googles
Hm. About 3000rpm. Just off tickover for a 'Busa.
But all the high power Merlins and such had gear reducing for their props.
They had to, to keep tip speed down for their gigantic props.
Gear reducing is doable. Even more used, and very, very reliable, are belt
PSRU units. Replace the belt at 200 hours or so, and fly with confidence,
if the bearings and such are properly designed.
  #34
Old March 7th 09, 12:32 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Maxwell[_2_]
"Ace" wrote in message
om...
engines
Not true at all.
I drove a 6500
highway.
vehicles.
These were not ag vehicles. Passenger car engines were popular back then in
all the class C motor homes, school buses, and light weight dump trucks. My
Chevy was a 350-2v with probably nothing more than the heavy duty 4 bolt
main block. It also had a 4 speed manual transmission, and 2 speed rear. I
would commonly shift the low gears as high a 4000-5000 rpm. The gross weight
on the entire package was around 30,000 lbs.
  #35
Old March 7th 09, 01:23 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Brian Whatcott
Champ wrote:
... automotive engines
for aircraft ... have a very hard life.
Take-off and climb is full power or very nearly, then they throttle back to
cruise at 75% or thereabouts. The only roadgoing vehicles that approach
It's perfectly possible to tune and engine to the load you describe
*and* achieve high reliability.
SW Oklahoma is arid, so there is plenty of business for engine
rebuilders, dealing with the farmers who run (ex-) auto engines
at high load - day and night - for the irrigation season. The hours rack
up fast.
I talked to one builder 2 or 3 years ago. Details escape me now, but the
approach was not that dramatic, to produce a 10 thousand hour engine BMO
That's when an engine doing 2000 hours in a season, lasts several years.
They use auto cutouts for low oil, and hot cooling water of course.
Oh yes, they tend to run them on natural gas. That's quite a favorable
factor, apparently.
The load is relatively kind, it's true - a water pump: kinda like the
fluid flywheel on an automatic. The bores are hard chrome, the valves
are metal cooled, the seats are hard-faced inserts(If I remember...)
some other details of that kind.
The oil changes are a religious ceremony.
Brian W
  #36
Old March 7th 09, 01:30 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Brian Whatcott
TOG@Toil wrote:
... I mean, what was max revs for a Merlin?
Googles
I THINK that was the prop shaft - like many other aero recips
it's limited by 0.9 c at the prop tips at the top end of the tach.
But the crank was driven by pistons breathing gas though a duplex
compressor system - driving a PRU.
Then again - in War mode its overhaul time was measured
in the hours you can count on one to two hands.
Low compression heads on the Merlin
were the choice for civil airliners post war.
Brian W
  #37
Old March 7th 09, 03:12 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
bildan
On Mar 6, 1:10*pm, Catman wrote:
bildan wrote:
On Mar 6, 10:26 am, Catman wrote:
Grimly Curmudgeon wrote:
We were somewhere around Barstow, on the edge of the desert, when the
drugs began to take hold. I remember Catman
saying something like:
bildan wrote:
snip
Keep in mind how the motorcycle works. *The bike has a 6-speed gearbox
whereas the airplane engine would have only one. *The standard sport
bike shift technique, approved by the factory, is to apply a large
force to the shift lever and then tap the clutch lever when the rider
wants to shift.
I don't think it is, you know. ISTBC of course.
Some people just like rebuilding gearboxes.
I must confess I'm not massively keen on it. I tend to stick with the
'pull clutch, change gear, release clutch' technique. Unless I'm doing
clutchless upshift, of course.
Catman MIB#14 SKoGA#6 TEAR#4 BOTAFOF#38 Apostle#21 COSOC#3
Tyger, Tyger Burning Bright (Remove rust to reply)
116 Giulietta 3.0l Sprint 1.7 145 2.0 Cloverleaf 156 V6 2.5 S2
Triumph Sprint ST 1050: It's blue, see.www.cuore-sportivo.co.uk
Of course! You're thinking of ENGLISH bikes - that's different. *We
all know how reliable those are. *If the tranny can be shifted without
a clutch, it's not a Japanese sport bike.
Oh dear.
My Kawasaki can't be shifted without the clutch but it shifts great
with the pre-load & clutch method and has done so reliably since '86.
Can't afford a newer one?
Don't need a new one - It's a Japanese motorcycle and they run
forever. However, my old Triumph Bonneville wasn't safe to ride
further than I was prepared to push it - something about the Lucas
electrics. You know, Joe Lucas, Prince of Darkness.
  #38
Old March 7th 09, 03:15 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
bildan
On Mar 6, 6:30*pm, Brian Whatcott wrote:
TOG@Toil wrote:
... *I mean, what was max revs for a Merlin?
Googles
* Low compression heads on the Merlin
Brian W
..9C!!!! I've heard of a Warp Drive propeller but 90% the speed of
light! Wow.
  #39
Old March 7th 09, 08:10 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Ace[_2_]
I drove a 6500
But that's true of nearly all agricultural vehicles,
*Whhhooooooosh*
  #40
Old March 7th 09, 08:18 AM posted to rec.aviation.homebuilt,uk.rec.motorcycles
Catman
I drove a 6500
*Whhhooooooosh*
This isn't going well, is it?
There I was, flat on my back... Kyle Boatright Home Built 5 August 16th 07 05:34 AM
Flat tire Viperdoc[_4_] Piloting 11 June 4th 07 02:57 PM
Flat Tires? Jay Honeck Owning 40 August 31st 05 01:59 AM
Wrinkly flat panels [email protected] Home Built 27 March 6th 04 02:12 PM
Flat Spin JJ Sinclair Soaring 34 February 10th 04 05:57 PM
