#41
On Jun 20, 4:30*am, Wingnut wrote:
On Fri, 18 Jun 2010 16:11:10 -0700, Dudley Henriques wrote: All this is just a fancy way of saying that prior experience in a Cessna 150 might not matter in a 767 Who said anything about a Cessna? The original post said she had experience as a *commercial* pilot. That tends to mean something a bit bigger than just a personal aircraft. I believe the lady herself said during a TV interview that her experience was restricted to light aircraft. The type "Cessna" was mentioned. DH |
#42
"Wingnut" wrote in message ... Who said anything about a Cessna? The original post said she had experience as a *commercial* pilot. That tends to mean something a bit bigger than just a personal aircraft. Not so. The training and testing for the Commercial certificate is normally done in single engine aircraft; often very simple single engine aircraft. To take a step down from that, I hold a Commercial glider pilot certificate and have taken hundreds of paying passengers up in sailplanes. Vaughn |
#43
In rec.aviation.piloting Mxsmanic wrote:
Wingnut writes: Consider who would have been landing the plane if something had caused the pilot to also conk out, though. Then her prior flight experience would have become quite relevant indeed. Not necessarily. In a situation like that, what would be most important would be her ability to follow instructions precisely, and the availability of a qualified pilot to guide her over the radio. These two things would override any piloting experience she might have. Nope. In a situation like that, what would be most important would be her ability to stay calm, not panic and fly the airplane. Look around at the average non-pilots in an airliner when a sudden noise like the gear coming up happens and you will see lots of faces with momentary fear and it gets worse with even the mildest of turbulence. The reality is the average non-pilot is afraid of flying to some extent or other and becomes frightened at just about every bump or sudden change in the background noise. My opinion is all the sensory inputs (of which those only "flying" sims have no clue) along with the the huge responsibility of flying an aircraft full of other people would likely overwhelm the average non-pilot. And since all pilots are trained "to follow instructions precisely", that becomes two reasons that a random pilot has better chances of success than a random non-pilot. -- Jim Pennino Remove .spam.sux to reply. |
#44
#45
Mxsmanic wrote:
writes: In a situation like that, what would be most important would be her ability to stay calm, not panic and fly the airplane. She'll need to be able to follow instructions to fly the airplane. Most people won't panic in a situation like that, although they may be very anxious. Delusional. Most average people would be scared ****less in such a situation and likely panic at the first bump. Look around at the average non-pilots in an airliner when a sudden noise like the gear coming up happens and you will see lots of faces with momentary fear and it gets worse with even the mildest of turbulence. When I look around at passengers in an airliner cabin, I usually don't see anyone who even notices the noise of the gear retracting, and most ignore turbulence as well unless it spills their drinks. Delusional. I've heard people shrieking in terror when a steeper than normal for an airliner bank was made. snip The sensory inputs are the same for pilots as they are for passengers. True, but irrelevant, as pilots are used to them but non-pilots aren't and for them it is scary. snip Pilots are trained to take responsibility and fly the airplane themselves. Taking instructions is secondary to that. Babble. Have you ever heard of a CFI or ATC? -- Jim Pennino Remove .spam.sux to reply. |
#46
On Jun 20, 12:38*pm, wrote:
My opinion is all the sensory inputs (of which those only "flying" sims have no clue) along with the the huge responsibility of flying an aircraft full of other people would likely overwhelm the average non-pilot. And since all pilots are trained "to follow instructions precisely", that becomes two reasons that a random pilot has better chances of success than a random non-pilot. EXACTLY. Case in point. I flew a Cessna for the first time in 8 years. I was told the avionics was similar to my Garmin 430 so I should not have ANY problem adopting to the plane. Sadly that was wrong and had I not had a pilot with me, I would still be scratching my head trying to tune the frequency. Radio was such to get odd numbers on the last two digits of the frequency, you had to PULL the knob out and twist. 117.9, I had to pull the knob out to dial in the 7. I didn't have to do that. I cannot imagine the NON pilot even setting the altimeter since you have to know to look for the kohlsman window to set it (if they find the thing at all in the myriad of instruments on a jet) Experience of the FA having pilot background was just one less step. She probably didn't even have to be told where the PTT was on the yoke AND that it's not a two way function like a telephone. I wouldn't expect the non pilot to know this if they had to step up to the plate on an emergency situation. Yeah, anybody can read a check list, but when it comes to the rubber meeting the road, I just don't see a non pilot doing the simple tasks inside a cockpit of a 767. It's a visual sensory overload for a passenger when I had the Sundowner, and I know it would be the same for me trying to find things in a 767. MX has no clue about sensory overload, the flat screen monitor twain't the real world since everything can be seen without turning one's head. Try that in a 767. |
#47
#48
#49
Mxsmanic wrote:
/snip/To fly an airliner, you need experience and/or training in flying airliners, not Piper Cubs. /snip/ Sadly, the task is even more limiting: it is necessary to get flight training in a PARTICULAR aircraft type. It's the systems know-how that has to be built. Let's see: would I know to turn on the two hydraulics control breakers, the FMS1 and the FMS 2 breakers, spin up the APU , turn on the pneumatic manifold to spin up one main engine, select radio frequencies via the FMS CDU, initialize the INS - and on and on..... Brian W p.s. I cut out the entertainment NGs. |
#50
"vaughn" wrote Not so. The training and testing for the Commercial certificate is normally done in single engine aircraft; often very simple single engine aircraft. To take a step down from that, I hold a Commercial glider pilot certificate and have taken hundreds of paying passengers up in sailplanes. Best to ignore this wingnut, as the knowledge of aviation is only slightly above MX. 'Nuff said. -- Jim in NC |
| Thread Tools | |
| Display Modes | |
| Pilot nearly crashes in IMC, Controller helps | pimenthal | Piloting | 32 | September 27th 05 02:06 PM |
| Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather | Bill Mulcahy | General Aviation | 24 | August 19th 05 11:48 PM |
| 2 pilot/small airplane CRM | Mitty | Instrument Flight Rules | 35 | September 2nd 04 12:19 AM |
| non-pilot lands airplane | Cub Driver | Piloting | 3 | August 14th 04 01:08 AM |
| Home Builders are Sick Sick Puppies | pacplyer | Home Built | 11 | March 26th 04 01:39 AM |
