Greetings!
Summer has begun down under, and my first flight with an iPaq reminded me just how bad the reflections are in bright light . . . sooo hard to read, especially when wearing sunglasses. Were there any solutions that worked well for you Northerners this season?? I have noted a film from Brando at: http://shop.brando.com.hk/screenprotector.php (not much reference to stopping reflections though) .. . and ClearTouch as sold by Richard at CraggyAero: http://www.craggyaero.com/screen_protectors.htm http://www.boxwave.com/products/clea...t3_ipaq_39.htm Perhaps Paul Remde, and others have solutions too? Anything found to work REALLY well?? Any comments?? Thanks. Best regards, Jim Kelly |
The ClearTouch is easy to apply and works better than the WriteRight by
Fellows. I use blue blocking sunglasses and the bluish backlight from my 3955 is attenuated somewhat. It is functional, but frankly I was disappointed in the overall image. I like my 1550 better but Winpilot stopped supporting it. I have had a few flights with the SN10-the screen visibility is very good, but the overall unit would take some time to learn. Overall, it is not as pretty as I wished, but it is useable, and the ClearTouch does cut the reflections, by spreading them out and 'defocusing' them. A slight tilt of the swivel mount helps somewhat. (Mine is mounted in the center of the panel and close to it) I am considering a black velvet 'bib' as the next step, to cut reflections from the shirt and chute hardware. -- Hartley Falbaum ASW27B "KF" USA "Jim Kelly" wrote in message u... Greetings! Summer has begun down under, and my first flight with an iPaq reminded me just how bad the reflections are in bright light . . . sooo hard to read, especially when wearing sunglasses. Were there any solutions that worked well for you Northerners this season?? I have noted a film from Brando at: http://shop.brando.com.hk/screenprotector.php (not much reference to stopping reflections though) . . and ClearTouch as sold by Richard at CraggyAero: http://www.craggyaero.com/screen_protectors.htm http://www.boxwave.com/products/clea...t3_ipaq_39.htm Perhaps Paul Remde, and others have solutions too? Anything found to work REALLY well?? Any comments?? Thanks. Best regards, Jim Kelly |
![]() | ClearTouch does cut the reflections, by spreading them out and 'defocusing' | them. A slight tilt of the swivel mount helps somewhat. (Mine is mounted in | the center of the panel and close to it) Sounds like ClearTouch "sort of" works, ie 'better than nothing'. Anyone found a better product?? | I am considering a black velvet 'bib' as the next step, to cut reflections | from the shirt and chute hardware. This has proven to work by one of our Aussie WinPilot gliding gurus. Black is not the coolest choice to wear though!! Thanks, Jim |
Jim Kelly wrote:
Sounds like ClearTouch "sort of" works, ie 'better than nothing'. Anyone found a better product?? I had a quick look at an iPaq with ClearTouch in direct sunlight, and it was noticeably better than the screen protectors I have been using (Micro Writeguards), which in turn were better than anything else I'd found... Marc |
I hear there will be a shift in displays tech in the next few months that
should make these current kits obsolete. "Marc Ramsey" wrote in message . com... Jim Kelly wrote: Sounds like ClearTouch "sort of" works, ie 'better than nothing'. Anyone found a better product?? I had a quick look at an iPaq with ClearTouch in direct sunlight, and it was noticeably better than the screen protectors I have been using (Micro Writeguards), which in turn were better than anything else I'd found... Marc |
F.L. Whiteley wrote:
I hear there will be a shift in displays tech in the next few months that should make these current kits obsolete. Organic LED (OLED) and/or electronic ink technology has been supposed to take over "real soon now" for a number of years. OLEDs use discrete light emitters at each pixel, giving good contrast with no backlight needed. Electronic ink uses tiny particles for pixels, electrically flipping them between light and dark sides, which supposedly provides contrast comparable to ink on paper. As I remember, exactly one cellphone briefly made it onto the market last spring with an OLED display. Apparently, OLEDs and e-ink still have problems which need to be solved... Marc |
Didn't someone develop an "eye piece", worn over one eye and linked to
the visual output of a PDA? The article, (long since lost in the bowels of this computer), portrayed a view of the countryside as seen by the pilot and, overlaid on this, was the GPS data and output from an electrical Artificial Horizon. If anyone remembers this, could they post the link? Steve -----Original Message----- From: Glider Pilot Network ] Sent: Tuesday, December 02, 2003 1:05 AM To: Steve Hopkins Subject: [r.a.s] iPaq screen reflections - anyone really happy with their solution? ------------------------------------------------------------ Newsgroup: rec.aviation.soaring Subject: iPaq screen reflections - anyone really happy with their solution? Author: Jim Kelly Date/Time: 01:00 02 December 2003 ------------------------------------------------------------ Greetings! Summer has begun down under, and my first flight with an iPaq reminded me just how bad the reflections are in bright light . . . sooo hard to read, especially when wearing sunglasses. Were there any solutions that worked well for you Northerners this season?? I have noted a film from Brando at: http://shop.brando.com.hk/screenprotector.php (not much reference to stopping reflections though) .. . and ClearTouch as sold by Richard at CraggyAero: http://www.craggyaero.com/screen_protectors.htm http://www.boxwave.com/products/clea...t3_ipaq_39.htm Perhaps Paul Remde, and others have solutions too? Anything found to work REALLY well?? Any comments?? Thanks. Best regards, Jim Kelly ------------------------------------------------------------ |
These things are known as 'enhanced reality' displays. Much more practical
than HUDIS ( Fixed colimator projected head up display ) since in a sailplane one needs to be looking about all the time. I have seen a few at shows. Most are a complete waste of time in terms of resolution, power drain and interface capabilities or are simply too large to get onto your head with the canopy closed! http://www.crd.ge.com/esl/cgsp/projects/er/ Ian |
I started using my Ipaq last spring and had a lot of trouble with
glare. Definitely not as good a view as with my Compaq Aero. Tried a black glare shield, not much help. Then the ClearTouch Richard suggested. Much better. But in order to use the Ipaq effectively and easily I had to turn off the color. In B&W it is easy to read. Too bad, spent all that money on an Ipaq..... "tango4" wrote in message ... These things are known as 'enhanced reality' displays. Much more practical than HUDIS ( Fixed colimator projected head up display ) since in a sailplane one needs to be looking about all the time. I have seen a few at shows. Most are a complete waste of time in terms of resolution, power drain and interface capabilities or are simply too large to get onto your head with the canopy closed! http://www.crd.ge.com/esl/cgsp/projects/er/ Ian |
Hi,
How did you "turn off the color"? Paul Remde "JohnD" wrote in message om... I started using my Ipaq last spring and had a lot of trouble with glare. Definitely not as good a view as with my Compaq Aero. Tried a black glare shield, not much help. Then the ClearTouch Richard suggested. Much better. But in order to use the Ipaq effectively and easily I had to turn off the color. In B&W it is easy to read. Too bad, spent all that money on an Ipaq..... "tango4" wrote in message ... These things are known as 'enhanced reality' displays. Much more practical than HUDIS ( Fixed colimator projected head up display ) since in a sailplane one needs to be looking about all the time. I have seen a few at shows. Most are a complete waste of time in terms of resolution, power drain and interface capabilities or are simply too large to get onto your head with the canopy closed! http://www.crd.ge.com/esl/cgsp/projects/er/ Ian |
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). | Phillip Rhodes | Military Aviation | 0 | September 7th 04 01:30 PM |
Ipaq - GPS_Log Help needed (Long) | Steve B | Soaring | 1 | September 27th 03 06:00 AM |
iPAQ h2210/h2215 Review | Paul Remde | Soaring | 0 | September 3rd 03 03:45 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
iPaq screen viewability | Raphael Warshaw | Soaring | 7 | July 27th 03 06:02 PM |
