New House Thermal
Old June 29th 17, 07:29 PM posted to rec.aviation.soaring
Default New House Thermal
Per, your pompous post implies that no heat will be exerted from the 800 acres of black panels. I guess my 40 years of soaring and a two plus thousand hours of hp glass time have proven me wrong before, but I would bet on a good thermal from that huge array of panels. Bob
  #42
Old June 29th 17, 11:06 PM posted to rec.aviation.soaring
Stephen Haley[_2_]
These started appearing in the uk big time last year. My experience so far
is
that like wind farms they are good thermal generators.
Not sure it has anything to do with the solar bit per se as that would
imply
inefficiency but i would think may have the same effect as a busy asphalt
car
park in that it allows the hot air to cling to the ground a bit longer due
to the
panels being on a 30-45 deg slant.
ac=
thousand=
g=
  #44
Old June 30th 17, 01:02 AM posted to rec.aviation.soaring
JS
Just got off the roof, where I measured my installation with an IR thermometer. Believe that's what Bob meant by heat gun.
Exposed roof: 135 to 140F, 57 to 60C
Shaded roof: 100F, 38C.
PV panels: 120F, 49C
On Wednesday, June 28, 2017 at 8:56:15 AM UTC-7, Dan Marotta wrote:
How did the temperature of the roof surrounding the PV panels compare?
Dan, 5J
  #45
Old June 30th 17, 12:13 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Exposed roof: 135 to 140F, 57 to 60C Shaded roof: 100F, 38C.
Do you know what the electrical output from your panels was at that time?
Watts/m^2 would be v.interesting.
Just curious. I thought about fitting solar electric and/or water heating
panels to my roof a while back, but its a non-starter because the town
council owns a row of very large oaks just over my southern fence (10m
from the house), and I haven't a cats chance in hell of getting them
trimmed.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
  #46
Old June 30th 17, 04:07 PM posted to rec.aviation.soaring
JS
trimmed.
org |
Didn't look, Martin.
The system has been in so long that as a rule I don't think about it any more. This was a test for the temperatures, for anyone who'd like to calculate if thermals would be better or worse.
  #47
Old June 30th 17, 06:02 PM posted to rec.aviation.soaring
time?
heating panels to my roof a while back, but its a non-starter because
the town council owns a row of very large oaks just over my southern
fence (10m from the house), and I haven't a cats chance in hell of
getting them trimmed.
martin@ | Martin Gregorie gregorie. | Essex, UK org |
Yes, understood, Jim. I was just curious to see if it was possible to see
how much of the roofanel temp difference was due to generated power
and how much was down to albedo difference.
Just wish I was in a better position both w.r.t latitude (51.779N) and
oak trees to consider adding some solar stuff to my roof.
org |
  #48
Old June 30th 17, 07:45 PM posted to rec.aviation.soaring
The panels presumably are isolated from the roof with an air gap, thus their lower temperature. They passed some of the heat on to the air. The thermal-generating effect would depend on the flow of heat to the air, not the temperature of the sun-illuminated object. In a steady state equilibrium, that flow equals the solar input, minus the reflected light, and minus any power siphoned off in other forms (whether electricity from the PV panels, or evaporation of water from green plants).
  #49
Old July 21st 17, 05:02 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Per Carlin wrote on 6/29/2017 12:17 AM:
I see that some of you are physics and some know economics but no one understand thermodynamics.
The only way a solar plant could be useful for us is if the albedo of the panels are so small so it compensates for the power drain it is designed to do.
Solar panels are a deep black and do a superb job of absorbing the radiation from
the sun. The ones on my house and my motorhome feel significantly hotter than the
roof area without a solar panel on it.
What might keep them from getting hotter than the ground near a solar farm is the
wind cools BOTH sides of the panel - air circulation across the bottom of the
panel is an important design consideration, as a cooler panel is more efficient.
- "Transponders in Sailplanes - Dec 2014a" also ADS-B, PCAS, Flarm
http://soaringsafety.org/prevention/...anes-2014A.pdf
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Byron Airport's Proposed House Thermal sisu1a Soaring 8 August 7th 10 04:22 PM
Where is the next thermal? danlj Soaring 36 September 28th 09 12:12 AM
Which Way is That Thermal? ContestID67 Soaring 26 September 9th 06 08:30 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
