New House Thermal
Old June 26th 17, 09:23 AM posted to rec.aviation.soaring
Default New House Thermal
The Treasure Coast Soaring Club will soon have a new house thermal. Florida Power And Light is in the process of building a 400 acre solar power plant within 3/4 mile from our airport. Heat from this type of farm should make for a great house thermal. Anyone out there with experience flying over solar farms? Thanks, Bob
Old June 26th 17, 02:57 PM posted to rec.aviation.soaring
Dan Marotta
I tried the solar panel farm between Jean and Primm, NV during one of
the ground launch weekends off of Roach Dry Lake and found nothing
though that could have simply been due to the airmass that day. I did
thermal nicely over one of those solar plants which directs solar energy
onto a tower containing, I think, liquid sodium which is used to heat
water to steam and thence to spin generators. Glad I didn't get low there...
Dan, 5J
Old June 26th 17, 03:21 PM posted to rec.aviation.soaring
6PK
One would think it should but it's hit and miss like most spots that should or could.....:-)
Old June 26th 17, 04:43 PM posted to rec.aviation.soaring
Tango Whisky
Le lundi 26 juin 2017 16:21:43 UTC+2, 6PK a écritÂ*:
Well, there is an issue with physics ... ;-) A good part of the sunlight is absorbed by the solar panels and transformed into electricity, and *not* into heat.
Bert "TW"
Old June 26th 17, 04:58 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Surely that depends on the overall reflectivity of the solar farm
averaged over its area and over all wavelengths: if its less reflective
than the surrounding area then it will be warmer. But that is only when
its not generating. If the system is generating and exporting electricity
that reduces the energy available for warming the system, so its average
temperature should be reduced as a result.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old June 26th 17, 05:33 PM posted to rec.aviation.soaring
Dave Nadler
Really now Bert.
This is R.A.S. - best not to annoy the inmates with facts...
Old June 26th 17, 11:14 PM posted to rec.aviation.soaring
PVT solar panels produce electricity and heat at the same time. It would be very unusual that a 400 acre PVT facility would not produce a constant boomer during solar absorption.
Old June 26th 17, 11:39 PM posted to rec.aviation.soaring
Roy B.
Sorry to disappoint, but I have a glider in South Africa and fly regularly over the Letsatsi solar park which is a 247 acre solar farm north of Bloemfontein SA (on the Dealsville Road). It was built 3 years ago but really doesn't contribute much to thermal activity in the area.
What I have found does work (both in SA and around the world) are the big metal grain silos found on most large farms which (especially when full) get very hot and seem to consistently focus thermals either right over or just downwind of them. That's where I want to be when I am low and scratching.
ROY
Old June 27th 17, 01:43 AM posted to rec.aviation.soaring
lets make this somewhat simple, the temp of the solar panes on top of the hangar today was in excess of 115 degrees F. I measured the temp reading with a heat gun. The panels number about 16, and the output is a max 8kw. I don't have the output capacity of this project, but I would guess that 100 acres of solar farm could produce 20 MW therefore 400 acres would be 80MW. I would think that if those panels produced the same amount of heat as the ones on the hangar roof and heat travels up, I would assume that we would get some thermal activity from the project.
Old June 27th 17, 06:01 AM posted to rec.aviation.soaring
[email protected][_2_]
Bert "TW"
No. Only a miniscule amount of the sunlight is turned into electricity.
At this level, (electricity out / total solar energy in) the efficiency
of PV panels is *buggerall*.
The solar farm will probably not only not produce thermals, it will
increase your energy costs. Shift to France where they have cheap
nuclear AND you can go gliding in the alps!
GC
Thermal Forcasting -Thermal index gldrgidr Soaring 6 November 27th 10 10:26 PM
Byron Airport's Proposed House Thermal sisu1a Soaring 8 August 7th 10 04:22 PM
Where is the next thermal? danlj Soaring 36 September 28th 09 12:12 AM
Which Way is That Thermal? ContestID67 Soaring 26 September 9th 06 08:30 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
