Wow - heard on the air... (long)
Old July 21st 05, 09:39 PM
Mortimer Schnerd, RN
George Patterson wrote:
I learned very early how
to bring a 172 to the numbers at 120k (yes, it can be done at full
throttle with the nose pushed over) and get off on the first high speed.
My old Maule would've needed a JATO unit to land at that speed.
Your old Maule would have needed a JATO unit to *fly* at that speed. G
VE
  #42
Old July 21st 05, 09:49 PM
Jose wrote:
How does one discover a brake problem during the take-off roll?
The plane pulls to the right as you near takeoff speed. In any case,
you don't have to say it's a brake problem, just an equipment problem.
Not in this case. First off, the brake *failed*, not hung up. Secondly,
turning moments on takeoff roll are normally handled with slight variations of
differential power in a twin. You have no reason to touch your brakes until
you're trying to stop.
Now, when the brake failed on landing in Shelby, I just rolled out longer than
usual and taxied with opposite brake and engine. It's a real PITA. Tighter
maneuvering requires a 270 degree turn to the other side. Looks a bit goofy on
the ramp but it works.
I had to land with essentially no brakes in Charleston, WV, Cleveland, OH, and
then back to Charlotte, NC. I picked up a load of ice over WV. My attitude
indicator went out on takeoff out of Cleveland. It was a hard IFR departure to
an on-top cruise. By the time I got back to Charlotte, it was clear. All in
all, an interesting flight.
VE
  #43
Old July 21st 05, 10:30 PM
Jose
Not in this case.
Maybe not, but the point is that you can say "unable due to equipment
problems" without admitting anything, or even raising an eyebrow, and
unless you are already being watched for suspicious activity, I doubt
there would be any fallout.
Now whether in this case it was appropriate (i.e. everything was doable
until the surprise at the end) is another question.
Jose
Nothing takes longer than a shortcut.
  #45
Old July 21st 05, 10:50 PM
Matt Whiting
Jose wrote:
Would you admit on the air that you took off knowing that there was
an item of no-go equipment that didn't work?
No such admission is necessary. Equipment problems can develop or be
discovered during flight, including brake problems that showed up during
the takeoff roll but at a point where lifting the nose was reasonable.
Jose
Interesting. I've never hit my brakes right before lift-off. Is this a
new technique? :-)
Matt
  #46
Old July 21st 05, 11:08 PM
RST Engineering
No, but I regularly hit them at 100 agl or so just to stop the main wheel
noise.
new technique? :-)
Matt
  #48
Old July 21st 05, 11:56 PM
Ron Natalie
Doug wrote:
Guy is nuts to go into OHare. I can just imagine what happened when
they had him taxi in. Those taxiways are complicated and crowded. I
don't think I'd go into OHare without a copilot who had been there.
But what about O'Hara?
  #49
Old July 21st 05, 11:59 PM
Ron Natalie
Doug wrote:
One thing a LOT of pilots don't do right. When you call fligh****ch,
you should give your position on your initial callup. This is because
although it's all the same frequency, there are different transmitters.
If you don't give your position, he has to reply on ALL the
transmitters he has becuase he doesn't know WHERE YOU ARE!
I hear this mistake time and time again.
Have you been to a flight circus station in the last decade?
They know where you are because their console twinkles all the
receivers you hit.
  #50
Old July 22nd 05, 02:42 AM
new technique? :-)
Actually, the tailwheel version of the Me-262 required one to tap the brakes for
a second during the takeoff run to pop the tail up off the ground. Aside from
that, probably not. Not too many Me-262's floating around any more.
VE
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Does China have long range bombers? Mike Military Aviation 10 May 24th 04 02:16 AM
making the transition from renter to owner part 1 (long) Journeyman Piloting 0 April 13th 04 02:40 PM
Long Range Spitfires??? ArtKramr Military Aviation 3 September 9th 03 10:05 PM
First flight with my wife! (long) Wily Wapiti Piloting 8 August 30th 03 05:57 PM
