Supercooled Water - More on Icing
Old December 7th 03, 04:33 PM
O. Sami Saydjari
Default Supercooled Water - More on Icing
This question is a question on physcial phenomena, NOT on regulation (so
I am starting a new thread).
As I understand it, icing happens between +2C and -10C. Assuming this
is correct, I have three questions.
(a) Does that mean one is relatively safe if the surface temperature is
below -10C (and there is no temperature inversion, meaning that the
temperature is known to decrease as one goes up in altitude)?
(b) Is icing from 0C to +2C a possibility only when your aircraft skin
is colder than 0C (probably because you are descending from altitude)?
Or is there some other condition where this is possible?
(c) I have been told that icing is possible from -10C to 0C because
water sometimes get "super-cooled" (which I assume means that water gets
below freezing, but does not form ice for some reason). Is that right?
If so, under what atmospheric conditions does water get super-cooled?
Removing water repelent from fiberglass lay-up? Roger Home Built 2 December 2nd 04 11:15 PM
FAR 91.157 Operating in icing conditions O. Sami Saydjari Instrument Flight Rules 98 December 11th 03 06:58 AM
water bombers Stew Hicks Home Built 2 September 8th 03 11:55 PM
water bombers Stew Hicks Home Built 0 September 7th 03 04:27 PM
Need help with Fluid Mechanics equation Doug Home Built 4 August 16th 03 03:13 AM
