#41
![]() "drclive" wrote in message oups.com... Can anybody point out a good bibliography or article that describes the differences in landing on a grass airstrip for the first time, tips and advices? Thanks One difference which almost bit me in the derrierre' when I was a new pilot is that a grass strip doesn't have a nice painted centerline or even runway edges to give you an indication that you're pointed in more or less the right direction. I had an experience where I drifted well off-line on takeoff from a grass strip and was more or less oblivious to the problem until I nearly collected the tree which defined the narrow point of the strip. Since then, I've done a much better job of lining up on grass fields and picking an object at the end of the field to use as an aim point. KB |
#42
#43
A Lieberman wrote:
On Sat, 17 Jun 2006 21:25:46 GMT, Matt Whiting wrote: See earlier message of mine on landing on grass, but one should always know the soil of the intended grass runway and taxi with the yoke full back. Even when taxiing back after landing into a 30K headwind? 30 knot head wind doesn't reduce the weight on the nose wheel on taxiing, so yes, you still need yoke full aft, just less power, But when you are taxiing back after landing that 30 knot headwind is now a 30 knot tailwind. Holding full up elevator with that strong a tailwind will put a lot more weight on the nosewheel and may even flip the airplane on its nose. You did learn proper control positioning for taxiing in strong windds during your primary instruction didn't you? Matt |
#44
Pastures are nice, but fresh cow patties must be washed off
before they dry too much. Everybody should fly a taildragger some, perhaps the new Sport Pilot Cub re-creations will help with that. Tundra tires make landing safer, but slow cruise. -- James H. Macklin ATP,CFI,A&P "birdog" wrote in message ... |I learned in a J-3 on a grass strip. I got a single sentence instruction for | my first hard surface landing. That was to be sure to track the runway in a | crosswind. You can be a little sloppy on grass, but not on asphalt, | especially in a taildragger. | | Never gave it any thought before, but taildragger pilots are always going to | touch down nose high and slowed to near stall in any craft, on grass or | asphalt. If there are any taildragger pilots around now days, watch 'em | landing tri-'s sometime. | | Sounds like some of you guys are talking about landing in a cow pasture. | Most dirt fields I've flown into had a distinct path marking the strip used | as the runway. No way would I ever intentionally, i. e. on purpose, set one | down in a uniform field of grass about which I was unfamiliar. | | There is distinct advantages in becoming proficient in a taildragger and one | that is not spin-proof. I guess all of this dates me. | | |
#45
If you have a big field of grass, you can always land into
the wind. The British used such fields for the narrow gear on the Spitfire. It is also harder to bomb the runway when it is 2,000 foot by 2,000 or bigger. "Kyle Boatright" wrote in message ... | | "drclive" wrote in message | oups.com... | Can anybody point out a good bibliography or article that describes the | differences in landing on a grass airstrip for the first time, tips and | advices? Thanks | | One difference which almost bit me in the derrierre' when I was a new pilot | is that a grass strip doesn't have a nice painted centerline or even runway | edges to give you an indication that you're pointed in more or less the | right direction. I had an experience where I drifted well off-line on | takeoff from a grass strip and was more or less oblivious to the problem | until I nearly collected the tree which defined the narrow point of the | strip. | | Since then, I've done a much better job of lining up on grass fields and | picking an object at the end of the field to use as an aim point. | | KB | | |
#46
Jim Macklin wrote:
I fly at about 20 feet, just to the side of the runway and look it over. I do the same with water landings, looking for rocks, logs and even alligators. I had an Air Force tanker pilot come to me for a CFI rating. He had never been on grass and in fact couldn't find an airport that did not have radar vectors and navaids on the field. We did a lot of grass strips and pilotage to get him up to speed. He did the SEL add-on in a few days and took his CFI check with the feds the next day. A very good pilot and fast learner, but the USAF doesn't teach T-38/KC 135 pilots to find grass strips in the middle of a world of grass. The US Army and USMC do a better job at that task. No wonder the rescue operation in Iran was botched so many years ago. This is truly scary that a military pilot has no training in landing in unimproved areas. Wow. Matt |
#47
Jim Macklin wrote:
Vandals tip headstones over in cemeteries and sometimes visit grass strips for similar reasons. If the airport isn't attended, a low and slow look-see is a good idea. If attended, a telephone call can alert you to any new issues, such as a prairie dog colony. I've never seen a headstone on a grass airstrip. :-) I'll take your word for it, however. Matt |
#48
john smith wrote:
In article , A Lieberman wrote: No difference, just land normally... Incorrect advice..... You want to land as softly and as slowly as possible on a grass strip. Also want to keep the nosewheel off terra firma as long as possible so it doesn't run the risk of "digging in" from the weight of the engine and prop when the nose wheel does touch down. After touchtown, the yoke should be full aft. You mean you don't do a normal landing this way? It seems a lot of pilots these days aren't taught this way. It certainly is the way I was taught. The only real difference between my soft-field technique and a normal landing is the addition of power after touchdown in order to hold the nosewheel off and to facilitate taxi. My approach and landing technique is the same no matter what the runway. Matt |
#49
A Lieberman wrote:
On Sat, 17 Jun 2006 22:33:32 GMT, john smith wrote: In article , A Lieberman wrote: No difference, just land normally... Incorrect advice..... You want to land as softly and as slowly as possible on a grass strip. Also want to keep the nosewheel off terra firma as long as possible so it doesn't run the risk of "digging in" from the weight of the engine and prop when the nose wheel does touch down. After touchtown, the yoke should be full aft. You mean you don't do a normal landing this way? ***I don't need the yoke in full aft position AFTER touchdown on paved runways.*** You don't want to use brakes at all for grass strips on landing or you will invite the chances of the nose wheel digging in. This is funny. It is becoming increasingly obvious that you have little experience on grass runways, especially short ones. Matt |
#50
birdog wrote:
I learned in a J-3 on a grass strip. I got a single sentence instruction for my first hard surface landing. That was to be sure to track the runway in a crosswind. You can be a little sloppy on grass, but not on asphalt, especially in a taildragger. Never gave it any thought before, but taildragger pilots are always going to touch down nose high and slowed to near stall in any craft, on grass or asphalt. If there are any taildragger pilots around now days, watch 'em landing tri-'s sometime. Sounds like some of you guys are talking about landing in a cow pasture. Most dirt fields I've flown into had a distinct path marking the strip used as the runway. No way would I ever intentionally, i. e. on purpose, set one down in a uniform field of grass about which I was unfamiliar. There is distinct advantages in becoming proficient in a taildragger and one that is not spin-proof. I guess all of this dates me. It dates you, but it also suggests that you had good primary instruction. I didn't learn in a tail dragger, but I learned from an old instructor who has about 50,000 hours, a good share of that instructing. It appears the more that I read here that newer instructors aren't teaching folks how to really fly under a wide range of conditions. The thought of needing a CFI to go from asphalt to grass just strikes me as so hilarious. Matt |
Nevada County (Grass Valley) Airport - local transport? | bk | General Aviation | 2 | January 26th 05 11:51 PM |
Greasy Grass | George Shirley | Naval Aviation | 1 | October 30th 04 06:20 PM |
Mooney M20 K on Grass ? | vfr2003 | Owning | 10 | August 18th 04 04:18 PM |
Mooney M20 K on Grass ? | Andrew Boyd | Owning | 0 | August 13th 04 03:00 PM |
Buildng a grass airstrip | Yosef Mendelsohn | General Aviation | 3 | May 13th 04 05:44 AM |
