Organizational Skills Required During Instrument Flight
Old February 19th 07, 10:50 PM posted to rec.aviation.student,rec.aviation.ifr
John Clonts
Default Organizational Skills Required During Instrument Flight
On Feb 19, 6:00 am, Thomas Borchert
One thing I haven't figured out yet is where to put the handheld backup
GPS (we have a Garmin 430 in the plane). I would NEVER fly without at
least a handheld GPS in IMC (if there is none in the panel - if there
is, I still like the backup). The cost of that safety device has become
trivial, with the Lowrance Airmap 500 or 600c. One can put it on the
yoke, and I would if it were my primary GPS, to have it in the scan. But
in my set-up, it then gets obscured by anything on the yoke clip.
I have a Geko 201 I toss up on the glareshield. I used to use it
simply to record tracks, but now for IMC trips I will set it to
"navigate-to" my destination airport. No map; only track, desired
track, distance, and altitude. But I do train with it, so it would be
sufficient in the event of complete electrical failure....
Cheers,
John Clonts
Temple, Texas
N7NZ
  #42
Old February 19th 07, 11:25 PM posted to rec.aviation.student,rec.aviation.ifr
dlevy
Andrew Sarangan taught me how to use a vor. My instructor told me a million
times but reading Mr. Sarangan's article seemed very clear to me. Mr.
Campbell's is similar.
snip
I've read an interesting article about an alternative way to interpret
the VOR. Has anyone read Joe Campbell's IFR diary, or this article:
http://www.campbells.org/Airplanes/VOR/vor.html ? If so, what did you
think?
  #43
Old February 20th 07, 12:10 AM posted to rec.aviation.student,rec.aviation.ifr
Tony
I'd like to to consider another organizational skill for flying in
IMC, this is related to approaches etc.
Always -- make that ALWAYS -- brief yourself on the approach, but with
this important difference. You may have said to yourself "OK, final
approach fix at 3500, fly 210 degrees, descend to 2150, fly for 2
minutes 30 seconds, land. Don't do that!
Always self brief the miss. "Fly for 2 minutes 30 seconds, look for
the airport, full throttle, gear up, establish positive climb rate,
report the miss to approach, maintain 210 degrees, climb to 4000, left
turn,"
Always treat seeing the airport as a happy accident -- you know how to
land, don't sweat that.
In real life, especially if you're flying into uncontrolled airports,
you may be flying missed approaches one time in 20 or 1 time in a
hundred, and I want you to be ready for that exceptional time. It'll
be handy on your check ride, too, because you just know the examiner
is going to tell you to fly the miss at a time when you're focusing on
landing.
Treat this advice like the others you have gotten -- if it makes sense
to you, make it your own. But trust me on this. This mind set, that
seeing the runway at MDA is a happy accident, and you've already
planned to fly the miss, will save you a lot of workload at a critical
time. I can't imagine a downside, although some readers may find one.
On Feb 18, 9:33 pm, wrote:
What methods do you deploy? How many folks use a kneeboard? What
kind of timer (analog or digital stopwatch) do you use, and where do
you put it? Where do you keep the charts, approach plates, and
scratch paper? How many people write down every clearance, heading,
altitude and frequency change? How do you keep from dropping your pen
(or pencil)? Is it on a string? Where do you put in when not in
use? Velcro? Your pocket?
I've read the books, but I just wonder how people cope in real life.
Rod Machado talks about using a clipboard (with extra clips on the 3
other sides) in his excellent training manual. This seems like a good
idea to me.
Steve
PP ASEL
Instrument student
  #44
Old February 20th 07, 12:34 AM posted to rec.aviation.student,rec.aviation.ifr
Barry
turn,"
Good advice to brief and be ready for the missed approach. However, for the
actual mechanics of the missed, I'd add as the first step "pitch up to climb
attitude" (generally about 10 degrees, or 2-3 bar widths). Many times on an
instrument proficiency check I've seen the pilot add full power without a
definite pitch up, and spend a lot longer than he should down near 200 feet.
Absolute priority on the missed is to get the climb established, and you do
this with both pitch and power.
Barry
  #45
Old February 20th 07, 12:39 AM posted to rec.aviation.student,rec.aviation.ifr
turn,"
landing.
idea to me.
Steve
PP ASEL
Instrument student
Sounds like great advice to me! I imagine as time goes on it will be
easy to become complacent. This sounds like a good way to guard
against that!
  #46
Old February 20th 07, 01:07 AM posted to rec.aviation.student,rec.aviation.ifr
Mitty
On 2/18/2007 8:33 PM, wrote the following:
Me. And a yoke board.
What
you put it?
ASA Timer but it's very bulky. Attached to yoke board with 3M Dual Lock,
similar to Velcro.
scratch paper?
On the knee board, either Jepp punched on the binder rings or under the clip.
Plates are moved to the yoke board when I'm using them, so very little head
movement and easy to see. Otherwise the airplane specific checklist is visible
on the yoke board.
Me. Or I try to. I use custom paper printed from an Excel spreadsheet that
gives me, among other things, three columns of blanks titled Altitude, Heading,
and Frequency. The bottom number written in each column is the current
assignment. I could email you the spreadsheet if you like.
(or pencil)?
Sometimes not too effectively. I have spares. Waiting until three are on the
floor substantially increases my odds of finding _one_ by blind groping.
Both the yoke board and the knee board have velcro to hold pens.
  #47
Old February 20th 07, 01:21 AM posted to rec.aviation.student,rec.aviation.ifr
snip
http://www.campbells.org/Airplanes/VOR/vor.html? If so, what did you
think?
I just found it at http://www.sarangan.org/aviation/art...or-article.pdf
.. Thanks!!
  #48
Old February 20th 07, 01:34 AM posted to rec.aviation.student,rec.aviation.ifr
Blanche
Velcro.
The top of my glareshield is slowly evolving to complete velcro. I've
got one of those little photo lights on a velcro strap that is placed
very conveniently on the glareshield in front of me.
Removed the ashtray years ago and now have a battery-powered
'ash light' (no, this isn't an ad).
Frankly, flashlights are the least of my worries at night or IFR.
(small maglight in pocket next to me, big D cell maglight under the
seat, etc)
I tried the clipboard concept - not practical when there's really
not enough room in my lap (I need to sit close, short legs).
Timer, with velcro on the back, on the glareshield. But I really like
the clock in the aircraft with the second hand. Dealing with setting
and resetting the digital clock is a pain when trying to do multiple
things.
  #49
Old February 20th 07, 02:55 AM posted to rec.aviation.student,rec.aviation.ifr
On Feb 19, 7:34 pm, Blanche wrote:
Velcro.
You have to be careful when saying those words aloud.
seat, etc)
things.
Velcro seems to be a common theme here! What a great invention!
Anyone remember those old David Letterman shows where he played
"Velcro Man" (am I remembering this right?). He donned a velcro suit,
jumped on a trampoline, and then stuck to a velcro wall. Anyway, I
thought it was funny.
Thanks Blanche!
  #50
Old February 20th 07, 01:59 PM posted to rec.aviation.student,rec.aviation.ifr
idea to me.
Steve
PP ASEL
Instrument student
Thanks to everyone who offered up so many great ideas! This seems to
be a very individual thing, but it's great to have so many workable
ideas to choose from.
I've only been posting for less than a week, but I have found this
group to be invaluable! It's amazing to me that so many folks with
common interests are willing to provide thoughtful responses to a
perfect stranger (me)! I really appreciate it!
Flight over water...required equipment? ET Piloting 14 March 27th 06 11:47 PM
Aerial PHotography Flights 'Required' to File Flight Plans C J Campbell Piloting 15 December 6th 04 02:17 PM
Horsepower required for level flight question... BllFs6 Home Built 17 March 30th 04 12:18 AM
Is there a FAA Manual for Heli flight examiners? gps required? Eric D Rotorcraft 2 October 29th 03 11:34 AM
Is there a FAA Manual for Heli flight examiners? gps required? Eric D Rotorcraft 1 October 21st 03 04:38 PM
