How does Winscore calculate finish altitude?
Old July 31st 07, 03:35 AM posted to rec.aviation.soaring
Andy[_1_]
Default How does Winscore calculate finish altitude?
On Jul 30, 6:21 am, John Sinclair
I don't find this to be true, Andy. Altimeters need
to be re-set primarily when landing at a destination
1000's of miles away from the takeoff location. I find
my altimeter to be surprisingly accurate when landing
at my takeoff location after a 4 hour flight. This
is true with the SN10 altineter, also.
JJ
JJ,
My observation is based on analysis of many of my own flight logs. I
am so convinced this 100 foot difference is valid that, if there is no
local altimeter setting available, I set my altimeter 100ft lower
before starting final glide. I had planned to spend this evening
reviewing your recent flight logs but I don't find you as a registered
OLC contestant. Perhaps you could check a few of your logs,
measuring the exact difference between on ground altitude at takeoff
and on ground altitude after landing and report the results. If you
use Parowan logs please allow for the difference due to runway slope.
( most days I was there this year takeoffs were from the low end and
landings ended at the high end)
Andy
Old July 31st 07, 05:23 AM posted to rec.aviation.soaring
Duane Eisenbeiss[_2_]
"Andy" wrote in message
local altimeter setting available, ....... snip
Andy
I also beleive the 100 foot (plus or minus) from take-off to landing is
valid.
It is called diurnial effect. The suns heating of the ground during the day
causes the pressure in the lower atmosphere to decrease slighly causing the
altimeter to read about 100 feet higher than actual. This is on most days,
we all know that weather facts are sometimes variable. Of course if you
land next to some mountains where there is down flow during the late
afternoon your milage (pressure) may vary.
Duane
Old July 30th 07, 09:12 PM posted to rec.aviation.soaring
John Sinclair
Tom,
You are noting the altimeter correction factor and
then applying it to the new altimeter setting, aren't
you?
If I get 29.90 from AWOS at Minden and then set it
into my altimeter and it reads 4800 feet, I must readjust
the setting to make it read field elevation (4720)
and then note the altimeter correction factor (- .1)
which I must apply to any new altimeter setting I get
in the air.
JJ
At 17:12 30 July 2007, 5z wrote:
On Jul 30, 7:21 am, John Sinclair
We have an AWOS right on the airport, so I set the
mechanical and 302
to this shortly before takeoff. When I check the altimeter
after 4-6
hours, the change is typically 1-200' - and usually
puts me lower.
Really unsettling if I'm on a marginal glide and the
air looks stable
ahead.
-Tom
Old July 30th 07, 11:34 PM posted to rec.aviation.soaring
5Z
On Jul 30, 2:12 pm, John Sinclair
Tom,
you?
When I set my altimeter per the Kollsman window, it reads field
elevation +/-20' so there is no correction factor needed.
In a contest, if the field elevation is 1234' MSL, and if there is a
nearby altimeter available, I'll typically see something like
1200-1250, so I just set my 500' finish to be at 1800' MSL as
indicated on the altimeter.
FYI, it's really easy to sync the Kollsman indication to match the
field elevation, but probably not something to be done outside a
repair station.
-Tom
Old July 31st 07, 03:44 AM posted to rec.aviation.soaring
John Sinclair
As this discussion has shown, if you set field elevation
before takeoff and don't change it, then finish with
500 feet on your altimeter, Windscore won't flag you
with a penalty. That's what I do and I haven't been
tagged with a finish penalty yet. Start gate is another
story......................
JJ
find
JJ
JJ,
flight logs. I
if there is no
100ft lower
this evening
you as a registered
your logs,
at takeoff
results. If you
to runway slope.
the low end and
Andy
Old July 31st 07, 07:06 PM posted to rec.aviation.soaring
Andy Blackburn
At 13:54 30 July 2007, Kirk.Stant wrote:
I think if you have a 'zero penalty' band pilots will
tend to use it. I can't figure the difference between
and 700' finish with a 200' band and a 500' finish.
Andy,
My point is that the current system encourages you
(the racing pilot)
to shave the 500' limit as close as you can, but at
the risk of losing
a lot if you miscalculate - or opt for a low altitude
dash to a rushed
landing to minimize your losses. Plus it encourages
expensive gadgets/
software (as I now realize that my SN10 will show the
info I need, for
example - priced one lately?) and clock watching at
the finish.
Providing an 'altitude-neutral' band to finish in should
remove the
incentive to aim for the bottom, since there would
no longer be a
benefit to be gained, while the risk of losing a lot
would be a strong
incentive to aim for the top of the finish band. The
band should be
big enough to hit easily with a properly set regular
altimeter (I
think 200' would work) without being so big the adjustment
for
altitude becomes 'gameable'.
Heck, how about adding one second for every 2 feet
below the top -
that works out to a 1.2 knot final climb - which wouldn't
hurt you
much if you were 20 ft low, but would still encourage
not finishing
199 ft low (who wants to give away time, after all).
The addition of 'no racing after the finish' (i.e.
if below the
bottom, the 'hard deck' in fighter speak, you get your
finish and
penalty right there and can forget about a straight
in finish and
concentrate on making a safe low altitude landing)
would additionally
discourage high risk finishes.
I know, I know, enough whining, this is pretty much
beat to death -
time to start bashing 2-33s again...
Cheers,
Kirk
I must be missing the point Kirk - if there is no penalty
for finishing at the bottom of the 'neutral band' then
I'd be inclined to shoot for the bottom of it to save
time. With the 30 seconds per 100' penalty band my
behavior changes - in that case I'd shoot for the top
of the penalty band but wouldn't worry too much about
a few feet of miscalculation or misjudgement. Are you
thinking of my 'penalty band' when you say 'neutral
band'? Maybe that's it.
9B
Old July 31st 07, 07:38 PM posted to rec.aviation.soaring
kirk.stant
On Jul 31, 1:06 pm, Andy Blackburn
Andy,
(the racing pilot)
the risk of losing
dash to a rushed
expensive gadgets/
info I need, for
the finish.
remove the
no longer be a
would be a strong
band should be
altimeter (I
for
below the top -
hurt you
not finishing
if below the
finish and
in finish and
would additionally
beat to death -
Cheers,
Kirk
9B- Hide quoted text -
- Show quoted text -
I guess I'm not making myself very clear. I see the "neutral band" as
an area where there is no advantage anywhere in it - you get the time
it would take to climb to the top added if you finish below the top.
So you might as well climb the extra 200 ft and not risk a low finish,
but having done that, if you run into sink and finish 100' below the
top (but 100' above the bottom) you only get dinged by the time you
would have spent getting that 100 ft back. But if you push it and aim
for the bottom of the neutral band, you get time added (time it would
have taken to climb to the top), and if you miss low - then you get a
big hit (no finish or rolling finish). To me, that would encourage me
to plan my final glide to the top of the window, but not worry too
much if I'm 50 ft low when I finally cross the line. If I saw I was
getting too close to finishing at the bottom, then I could slow down
early enough or change my finish strategy.
I guess that the crucial calculation would be the climb rate used to
equalize the neutral band. A bad choice would obviously create a bias
towards finishing high or low. Better to bias towards finishing high?
And maybe 200' is too much - perhaps a 100 ft window?
I'm no mathematician, so my logic and assumptions may be false, but it
seems doable to have the rule create a "window" that we can aim for
(assuming we want to win, and are not going to climb way above the
optimum finish height).
A side note - which of the current glide computers/PDA programs figure
the final glide to the finish line, instead of to the finish point
(center of the finish circle)? I'm pretty sure my SN10 figures to the
center of the finish circle, not the actual line - Dave Nadler, if you
are reading this, could you chime in?
Kirk
WinScore Question Ray Lovinggood Soaring 2 June 5th 07 03:15 PM
calculate last point of diversion jaws Piloting 1 July 5th 06 04:19 PM
How to calculate TOC and TOD? Andrea da lontano Piloting 3 October 21st 04 09:24 PM
Weight and Balance Formula, Can one calculate the envelope Joe Wasik Piloting 12 September 29th 04 08:15 AM
Winscore source code now available Guy Byars Soaring 0 February 5th 04 10:43 AM
