On Mon, 6 Aug 2007 20:43:47 -0500, "Maxwell" wrote
in : "Larry Dighera" wrote in message .. . Personally, I'd like to see an electrically powered parachute (http://skyhighflying.com/homepage.html) design attempted. Surly the lighter weight would require less power. It would seem that lithium-ion polymer batteries are a potential enabling technology. They might be lightweight and strong, but I think they would be far too inefficent. All the canopies I have been around have had a very poor L/D when compared to something like a sailplane. The web site below mentions an L/D of four to one. I always assumed they were so popular because they were so strong, portable and quick to set-up. But I'm thinking their fuel mileage would be very poor. I would be more interested in the specific horsepower required to operate powered parachutes than their efficiency. This web site mentions 50 HP to 65 HP: http://www.all-about-powered-parachutes.com/faq.htm There is a 14 HP Powered Paraglider (PPG) engine offered he http://www.poweredparasports.com/Par...#Jet%20Details They also state that the weight of their engines ranges from 46 lbs. to 68 lbs. If a 14 HP electric propulsion system weighing 46 lbs could be constructed, apparently it would permit the use of PPGs by pilots up to 180 lbs. |
Larry Dighera wrote:
There is a 14 HP Powered Paraglider (PPG) engine offered he http://www.poweredparasports.com/Par...#Jet%20Details They also state that the weight of their engines ranges from 46 lbs. to 68 lbs. If a 14 HP electric propulsion system weighing 46 lbs could be constructed, apparently it would permit the use of PPGs by pilots up to 180 lbs. Yeah sure, but its not practical for anything but an hour or two of playing around on a Saturday afternoon. You can't carry anything or go anywhere to accomplish anything except maybe brag about how little energy you used goofing off for a few hours. Its like blasting around on a jet ski... basically a total waste of energy without producing any useful work or benefit to mankind. Don't get me wrong, I love new technology and if you can afford to spend money on extra curricular stuff like aimlessley cruising about in solar powered paragliders or jet skis fine. But don't think you are doing the world a big favor because you used something other than gasoline to power it. |
On Wed, 08 Aug 2007 01:05:16 GMT, kontiki
wrote in : Yeah sure, but its not practical for anything but an hour or two of playing around on a Saturday afternoon. I'll bet you would have said something similar to the Wrights. :-) Where's you vision, man? Now here's an electrically powered aircraft that really is playing around: http://www.nesail.com/videos/jazz.wmv |
![]() "kontiki" wrote Yeah sure, but its not practical for anything but an hour or two of playing around on a Saturday afternoon. Flight training in the pattern is an obvious first application. |
![]() "Larry Dighera" wrote in message ... I would be more interested in the specific horsepower required to operate powered parachutes than their efficiency. This web site mentions 50 HP to 65 HP: http://www.all-about-powered-parachutes.com/faq.htm That's what I have seen. We even have a tandem trike locally that uses a Subaru. There is a 14 HP Powered Paraglider (PPG) engine offered he http://www.poweredparasports.com/Par...#Jet%20Details They also state that the weight of their engines ranges from 46 lbs. to 68 lbs. If a 14 HP electric propulsion system weighing 46 lbs could be constructed, apparently it would permit the use of PPGs by pilots up to 180 lbs. I would think that would be close to the bare minimum. I flew a fixed wing hang glider on 10 HP for a while back in the 70s. A Manta Fledgling, and it was very underpowered. Maybe 100 fpm climb or so. |
On Wed, 8 Aug 2007 01:12:26 -0500, "Maxwell" wrote
in : "Larry Dighera" wrote in message .. . There is a 14 HP Powered Paraglider (PPG) engine offered he http://www.poweredparasports.com/Par...#Jet%20Details They also state that the weight of their engines ranges from 46 lbs. to 68 lbs. If a 14 HP electric propulsion system weighing 46 lbs could be constructed, apparently it would permit the use of PPGs by pilots up to 180 lbs. I would think that would be close to the bare minimum. I flew a fixed wing hang glider on 10 HP for a while back in the 70s. A Manta Fledgling, and it was very underpowered. Maybe 100 fpm climb or so. I would guess the rigid wing would have a higher L/D than a powered parachute's 4:1, so it might require less power. Does that sound correct in your experience? |
![]() "Larry Dighera" wrote in message ... I would think that would be close to the bare minimum. I flew a fixed wing hang glider on 10 HP for a while back in the 70s. A Manta Fledgling, and it was very underpowered. Maybe 100 fpm climb or so. I would guess the rigid wing would have a higher L/D than a powered parachute's 4:1, so it might require less power. Does that sound correct in your experience? Indeed, quite a bit less from my experience. I think my Fledge was supposed to be around 10:1. |
On Tue, 07 Aug 2007 14:58:07 GMT, Larry Dighera
wrote: If a 14 HP electric propulsion system weighing 46 lbs could be constructed, apparently it would permit the use of PPGs by pilots up to 180 lbs. A PPG is a LOT more efficient than a powered parachute (PPC), but still far less efficient than a rigid wing. Still, several electric PPG's have been flown. The primary goal here is noise and vibration reduction, a worthy goal when the engine is strapped to the pilot's back. The major problem is the weight of the batteries, still far heavier than gasoline. Also the lithium polymer batteries used are still quite expensive (over $10,000 for enough for a half hour flight) and somewhat dangerous (sort them out and they can explode!) -Dana -- -- If replying by email, please make the obvious changes. ------------------------------------------------------------------------------- The number of elected federal officials is limited to congress, the president and the vice president. That's only 537 people. The federal bureaucracy numbers in the millions..... |
![]() "Dana wrote The major problem is the weight of the batteries, still far heavier than gasoline. Also the lithium polymer batteries used are still quite expensive (over $10,000 for enough for a half hour flight) and somewhat dangerous (sort them out and they can explode!) Damn straight! No way am I going to strap a bunch of lithium polymer batteries to my butt. Some of the newer Lithium iron cells, maybe, but they also cost a LOT more. Still, electric flight, like many have said, still have a way to go. -- Jim in NC |
Morgans wrote:
"Dana wrote The major problem is the weight of the batteries, still far heavier than gasoline. Also the lithium polymer batteries used are still quite expensive (over $10,000 for enough for a half hour flight) and somewhat dangerous (sort them out and they can explode!) Damn straight! No way am I going to strap a bunch of lithium polymer batteries to my butt. Some of the newer Lithium iron cells, maybe, but they also cost a LOT more. Still, electric flight, like many have said, still have a way to go. And as if we need more proof of this. TOKYO: Japan's Toyota Motor Corp. will delay by one or two years the rollout of new high-mileage hybrids with lithium-ion batteries because of safety concerns, reported a newspaper. Toyota's decision was prompted by worries that the batteries could overheat, catch fire or even explode, the Wall Street Journal on Thursday reported in its online edition, quoting unnamed Toyota executives. |
Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 01:11 PM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Is JB Weld electrically conductive? | Scott | Home Built | 14 | July 12th 04 11:24 PM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
