#41
peld wrote:
I was actually surprised how easy it was to get out of the cockpit. Having undone the harness it seemed like no trouble at all to just roll over the canopy rail and out into the wild blue yonder. I have a below knee artificial right leg so I had considered this scenario for some time, expecting to have a lot of trouble just getting my leg past the instrument panel, but no, it was really a piece of cake. I have the same right leg modification as you, so I'm very happy to hear that getting out wasn't a problem. I'd wondered if it might be a problem. Did the leg cause any problems when you landed? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
#42
Jon,
No, the MKII yarn is not replaceable, so changing to a heavier string would not be cost effective. Instead, you might add a lead "split-shot" fishing weight* to the end of the yarn. This should dampen the erratic yaw string movements you are experiencing. *Side effects common but most often mild. They may include lead arc on the canopy, mood-swings, vertigo, nausea, and diarrhea. Do not suck on or swallow lead split-shot as this can exacerbate these symptoms. If you experience a yaw string erection that lasts for more than 4 hours, seek immediate medical attention . . . or enjoy the flight. bumper :c) "jonathan" wrote in message ... bumper, I find my yaw string always swings out to one side or the other - should I use a heavier string? Jon ;-) "bumper" wrote in message ... Bill, I too applaud DG for developing the NOAH system. However, complexity, cost, and it's "one time use" nature may limit its appeal for many. After suffering a bout of "frozen shoulder" last year, that made it difficult for me to even exit my glider on the ground, I've decided there's a need to develop a more simple air-lift bag for my glider. This bag would probably be made of coated nylon and be inflated with an easily refillable compressed air bottle. Inflation would be via a quarter-turn manual valve with no safety devices except perhaps a manual interlock pin (if a solenoid valve were used, a canopy-open interlock could be incorporated). The intent would be to design the "air-lift under cushion" for ground use only, to assist the pilot in exiting the ship. If this system were marketed, restricting it to ground use would hopefully help eliminate the liability concerns of a system intended to assist a bail out. Like many of my ideas, I may not find the time to make this. And if do, I may only make one to test in my glider. (I'm still questioning the decision to market the Quiet Vent and MKII Yaw String :c). Comments, suggestions welcome. bumper ZZ Minden "Bill Daniels" bildan@comcast-dot-net wrote in message . .. "bagmaker" wrote in message ... - You've had a whack, but everything feels fine. Do you stay in the glider, or leave? Just how reliable are the parachutes we use? I understand that they're fairly simple quick-opening designs, but there's no reserve, right? Has a glider-pilot parachute ever failed? Dan - Dan, Simply, there is no blanket answer, way too many variables exist. Derek Piggot writes a fascinating account of his bail-out in some of his gliding books, I would suggest reading them. Gliding Kiwi has a great article this month on a NZ instructor landing a rudderless puch with a PAX - more heart stopping reading! Basically if it does fly after a hit, check to see that it will keep flying with some harsh movements -height limits withstanding- long enough to land. Landing manuevering can be rough, you want to be sure the thing doesnt fail at 100 feet after nursing down from a good bail out height. Rough rule has been bandied about RAS about 1500 ft as a minimum bail-out altitude, many would disagree, but if you dont have a choice..... Bottom line is you are worth more than a glider, if in doubt, get out fly safe Bagger I've twice faced the decision to jump or land a crippled glider. The first was a Pratt-Read badly damaged from a mid-air. I had fresh jump training, a fresh repack and a stable jump platform but I decided to land it anyway. The critical decision was whether I could control the glider from the time it decended below a safe jump altitude until it was on the ground. I could and did. For the record, the other pilot in the mid-air did the same thing. The second was an experimental flying wing where a suposedly secure lead shot bag shifted in flight so as to jam the elevator/aileron bellcranks. I found I could steer with rudder and slow it to 70Kts with trim. That let me hit the runway on a fast, shallow glide. It was a rough landing but the glider and I survived to fly again. In both cases there was intense discussion post flight about the wisdom of my decisions. A slim majority said the conservative action was to have abandoned ship. My view was if the thing is more or less controllable, and you have a big airfield to aim at, land it. If it is an airplane loaded with fuel, that might shift the decision toward jumping. However, a glider that can be flown to hit a large flat area at a shallow angle is likely to be safer than the 'chute. If there is any doubt that the glider will remain controllable - jump. The real problem here is struggling to rise from a reclining position and crawl over the side with a 15 pound 'chute on your back. That's difficult. Being old, out of shape and/or overweight makes it impossible. This is where the NOAH system from DG is so significant. Of all the safety related things that one could spend money on, the NOAH system tops the list for me. Bill Daniels |
#43
I know of some bush pilots who wear helmets. I opted for the Amsafe air-bag
system when I bought my Husky, figuring it would provide better protection overall, and be less hassle than a helmet. I don't have headroom in the glider for a helmet. I do use 1/4" of Confor (NASA, Tempur etc) foam in the top of my floppy terri hat. It helps keep my bald noggin from bonking the canopy too hard in rotor and probably helps protect the canopy too. One might not think that just 1/4" of extra-firm Confor would do much, but it does! You can test this by putting the Confor on concrete and then hitting it with your fist. Hint - don't hit it as hard as you can - - makes an amazing difference. bumper "Eric Greenwell" wrote in message news:gr2Gi.8312$Ic3.1085@trndny09... Mark Dickson wrote: Pretty much the only pilots that wear helmets are military pilots, and that is probably due to the excessive g they experience and the forces involved in ejecting. Also for attaching sun visors, oxygen masks, headphones and mics. Glider pilots definately do not need helmets; not in the air anyway, maybe on the ground to protect against walking into trailing edges. I do know of one pilot that wears a helmet while wave flying. It looks like a military jet pilot's helmet, including the darkened "goggle" portion that covers the eyes. He does it for the warmth in normal wave flying, for protection from the bright sun (he doesn't fly wave where I fly!), to support the oxygen mask, to provide protection from a canopy that shatters in the cold, and for protection from the wind and cold if he has to bail out at high altitudes. He doesn't have any problems with clearance to the canopy, but I think a lot of pilots would. I rarely fly above 18,000 in wave, but if I did it routinely, I'd consider wearing a helmet. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes" http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#44
On Sep 14, 1:28 am, Martin Gregorie
wrote: peld wrote: I was actually surprised how easy it was to get out of the cockpit. Having undone the harness it seemed like no trouble at all to just roll over the canopy rail and out into the wild blue yonder. I have a below knee artificial right leg so I had considered this scenario for some time, expecting to have a lot of trouble just getting my leg past the instrument panel, but no, it was really a piece of cake. I have the same right leg modification as you, so I'm very happy to hear that getting out wasn't a problem. I'd wondered if it might be a problem. Did the leg cause any problems when you landed? -- martin@ | Martin Gregorie gregorie. | Essex, UK org | Martin, Like you I thought I would have problems. I used to think that the leg would catch on the panel and come off, but that wasn't a problem at all. As for landing, I came down on my backside, don't ask me how, and the leg was no problem at all then. However, I badly bruised my coccyx and jarred my back pretty bad. What the hell, I was down OK. Thats what they say about emergency chutes: its only gonna save your life, it won't be a soft landing. You come down pretty fast. Phil |
#45
Hey Bumper, how about marketing soaring hats with foams? Make mine
brown. I was just suggesting foam on the other helmet thread, sounds like a simple solution to a serious risk. Ramy On Sep 13, 2:22 pm, "bumper" wrote: I know of some bush pilots who wear helmets. I opted for the Amsafe air-bag system when I bought my Husky, figuring it would provide better protection overall, and be less hassle than a helmet. I don't have headroom in the glider for a helmet. I do use 1/4" of Confor (NASA, Tempur etc) foam in the top of my floppy terri hat. It helps keep my bald noggin from bonking the canopy too hard in rotor and probably helps protect the canopy too. One might not think that just 1/4" of extra-firm Confor would do much, but it does! You can test this by putting the Confor on concrete and then hitting it with your fist. Hint - don't hit it as hard as you can - - makes an amazing difference. bumper "Eric Greenwell" wrote in message news:gr2Gi.8312$Ic3.1085@trndny09... Mark Dickson wrote: Pretty much the only pilots that wear helmets are military pilots, and that is probably due to the excessive g they experience and the forces involved in ejecting. Also for attaching sun visors, oxygen masks, headphones and mics. Glider pilots definately do not need helmets; not in the air anyway, maybe on the ground to protect against walking into trailing edges. I do know of one pilot that wears a helmet while wave flying. It looks like a military jet pilot's helmet, including the darkened "goggle" portion that covers the eyes. He does it for the warmth in normal wave flying, for protection from the bright sun (he doesn't fly wave where I fly!), to support the oxygen mask, to provide protection from a canopy that shatters in the cold, and for protection from the wind and cold if he has to bail out at high altitudes. He doesn't have any problems with clearance to the canopy, but I think a lot of pilots would. I rarely fly above 18,000 in wave, but if I did it routinely, I'd consider wearing a helmet. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * "Transponders in Sailplanes"http://tinyurl.com/y739x4 * "A Guide to Self-launching Sailplane Operation" atwww.motorglider.org- Hide quoted text - - Show quoted text - |
#46
peld wrote:
Like you I thought I would have problems. I used to think that the leg would catch on the panel and come off, but that wasn't a problem at all. I have a "naked" limb (no cosmetic wrappings, just an anodized shaft) and, as a result, often have to disengage the heel of my shoe while getting out after a flight. It catches on the lip on the cross-beam that supports the stick and front of the seat pan in my Libelle. I've always wondered if that would be a problem during emergency egress. I imagined that the shoe would depart before my leg came off: the liner seems to have a pretty good grip on my remaining bits. As for landing, I came down on my backside, don't ask me how, and the leg was no problem at all then. However, I badly bruised my coccyx and jarred my back pretty bad. My sympathies: damaged backs are no joke, but as you say getting down in one piece is all that matters. Thanks for the explanation of why your leg wasn't affected. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
70 kg 31:1 glider is here to stay? | Andre Volant | Soaring | 57 | November 27th 04 11:21 AM |
Region 1 Contest - will trade place to stay | Quebec Tango | Soaring | 0 | May 10th 04 03:17 PM |
How Aircraft Stay In The Air | Sarah Hotdesking | Military Aviation | 145 | March 25th 04 05:13 PM |
The Bud Light logo will stay | Cub Driver | Military Aviation | 8 | November 24th 03 01:08 AM |
The Bud Light logo will stay | Cub Driver | Piloting | 7 | November 24th 03 01:08 AM |
