Stay in, or get out?
Old September 10th 07, 11:01 PM posted to rec.aviation.soaring
Dan G
Default Stay in, or get out?
You've had a whack, but everything feels fine. Do you stay in the
glider, or leave? Just how reliable are the parachutes we use? I
understand that they're fairly simple quick-opening designs, but
there's no reserve, right? Has a glider-pilot parachute ever failed?
Dan
Old September 11th 07, 12:42 AM posted to rec.aviation.soaring
Peter Thomas
failure rate is one per low thousands, your chances
of leaving the glider are 50/50
if you lose some wing it spins, if the tailplane comes
of it bunts, then is to late......
I recall there was a deployment failure in the uk,
but apparently caused by the diy backpad preventing
proper operation of the chute
I also know of at least one case where a pilot stayed
and the glider failed to low to bail out.
if you have a stable jump platform use it. I know at
least 4 people who have baled out of gliders ok, but
they were all no brainers, one of them was a K21 which
turned into a dart shortly after being struck by lighting!
(I saw that one happen)
Pete
stay in the
we use? I
designs, but
ever failed?
Dan
Old September 11th 07, 04:16 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
stay in the
we use? I
designs, but
ever failed?
Dan
[/quote]
Dan,
Simply, there is no blanket answer, way too many variables exist.
Derek Piggot writes a fascinating account of his bail-out in some of his gliding books, I would suggest reading them.
Gliding Kiwi has a great article this month on a NZ instructor landing a rudderless puch with a PAX - more heart stopping reading!
Basically if it does fly after a hit, check to see that it will keep flying with some harsh movements -height limits withstanding- long enough to land. Landing manuevering can be rough, you want to be sure the thing doesnt fail at 100 feet after nursing down from a good bail out height.
Rough rule has been bandied about RAS about 1500 ft as a minimum bail-out altitude, many would disagree, but if you dont have a choice.....
Bottom line is you are worth more than a glider, if in doubt, get out
fly safe
Bagger
bagger
Old September 11th 07, 04:58 PM posted to rec.aviation.soaring
Bill Daniels
"bagmaker" wrote in message
stay in the
we use? I
designs, but
ever failed?
Dan
Dan,
fly safe
Bagger
I've twice faced the decision to jump or land a crippled glider. The first
was a Pratt-Read badly damaged from a mid-air. I had fresh jump training, a
fresh repack and a stable jump platform but I decided to land it anyway.
The critical decision was whether I could control the glider from the time
it decended below a safe jump altitude until it was on the ground. I could
and did. For the record, the other pilot in the mid-air did the same thing.
The second was an experimental flying wing where a suposedly secure lead
shot bag shifted in flight so as to jam the elevator/aileron bellcranks. I
found I could steer with rudder and slow it to 70Kts with trim. That let me
hit the runway on a fast, shallow glide. It was a rough landing but the
glider and I survived to fly again.
In both cases there was intense discussion post flight about the wisdom of
my decisions. A slim majority said the conservative action was to have
abandoned ship. My view was if the thing is more or less controllable, and
you have a big airfield to aim at, land it. If it is an airplane loaded
with fuel, that might shift the decision toward jumping. However, a glider
that can be flown to hit a large flat area at a shallow angle is likely to
be safer than the 'chute. If there is any doubt that the glider will remain
controllable - jump.
The real problem here is struggling to rise from a reclining position and
crawl over the side with a 15 pound 'chute on your back. That's difficult.
Being old, out of shape and/or overweight makes it impossible. This is
where the NOAH system from DG is so significant. Of all the safety related
things that one could spend money on, the NOAH system tops the list for me.
Bill Daniels
Old September 11th 07, 06:42 PM posted to rec.aviation.soaring
bumper
Bill,
I too applaud DG for developing the NOAH system. However, complexity, cost,
and it's "one time use" nature may limit its appeal for many.
After suffering a bout of "frozen shoulder" last year, that made it
difficult for me to even exit my glider on the ground, I've decided there's
a need to develop a more simple air-lift bag for my glider.
This bag would probably be made of coated nylon and be inflated with an
easily refillable compressed air bottle. Inflation would be via a
quarter-turn manual valve with no safety devices except perhaps a manual
interlock pin (if a solenoid valve were used, a canopy-open interlock could
be incorporated). The intent would be to design the "air-lift under cushion"
for ground use only, to assist the pilot in exiting the ship. If this system
were marketed, restricting it to ground use would hopefully help eliminate
the liability concerns of a system intended to assist a bail out.
Like many of my ideas, I may not find the time to make this. And if do, I
may only make one to test in my glider. (I'm still questioning the decision
to market the Quiet Vent and MKII Yaw String :c).
Comments, suggestions welcome.
bumper
ZZ
Minden
"Bill Daniels" bildan@comcast-dot-net wrote in message
stay in the
we use? I
designs, but
ever failed?
Dan
Dan,
fly safe
Bagger
first was a Pratt-Read badly damaged from a mid-air. I had fresh jump
training, a fresh repack and a stable jump platform but I decided to land
it anyway. The critical decision was whether I could control the glider
from the time it decended below a safe jump altitude until it was on the
ground. I could and did. For the record, the other pilot in the mid-air
did the same thing.
I found I could steer with rudder and slow it to 70Kts with trim. That
let me hit the runway on a fast, shallow glide. It was a rough landing
but the glider and I survived to fly again.
and you have a big airfield to aim at, land it. If it is an airplane
loaded with fuel, that might shift the decision toward jumping. However,
a glider that can be flown to hit a large flat area at a shallow angle is
likely to be safer than the 'chute. If there is any doubt that the glider
will remain controllable - jump.
difficult. Being old, out of shape and/or overweight makes it impossible.
This is where the NOAH system from DG is so significant. Of all the
safety related things that one could spend money on, the NOAH system tops
the list for me.
Bill Daniels
Old September 12th 07, 06:34 AM posted to rec.aviation.soaring
Eric Greenwell
A friend of mine (Bob Moore) had an "elderly pilot's assist" (not that
I'm suggesting bumper is elderly, since I'm a bit older myself!)
installed in his PIK 20 E. He used it to enter and exit the glider on
the ground. It was a cloth bag with (I think) two aircraft tire tubes,
one on top of the other, inside the bag. A small 12 VDC pump run from
the glider battery inflated the tubes to raise the pilot; a valve
released the air to lower the pilot. It allowed him another couple years
of flying.
Old September 12th 07, 08:40 PM posted to rec.aviation.soaring
jonathan
bumper,
I find my yaw string always swings out to one side or the other - should I
use a heavier string?
Jon ;-)
"bumper" wrote in message
Bill,
cost, and it's "one time use" nature may limit its appeal for many.
there's a need to develop a more simple air-lift bag for my glider.
could be incorporated). The intent would be to design the "air-lift under
cushion" for ground use only, to assist the pilot in exiting the ship. If
this system were marketed, restricting it to ground use would hopefully
help eliminate the liability concerns of a system intended to assist a
bail out.
decision to market the Quiet Vent and MKII Yaw String :c).
bumper
ZZ
Minden
stay in the
we use? I
designs, but
ever failed?
Dan
Dan,
enough
bail-out
fly safe
Bagger
did the same thing.
of my decisions. A slim majority said the conservative action was to have
glider will remain controllable - jump.
the list for me.
Bill Daniels
Old September 11th 07, 10:34 PM posted to rec.aviation.soaring
Eric Greenwell
Default The most safety for the dollar - a list
It would be interesting to construct a list of these things, and
prioritize them by their cost/benefit ratio. Bill seems like a very
safety conscious pilot, so he probably is at the point where a NOAH
system would give him the most safety increase for the buck. I'll bet a
lot, maybe most, pilots aren't in that situation.
A simple example is the Roeger hook (or a variant) that is part of every
new glider with a forward opening canopy, ensuring it can be jettisoned
safely. DG makes a retrofit available for all their older gliders, yet
relatively few have purchased one. I know Schleicher offers retrofits
for at least one glider (I bought and installed one), and perhaps others.
How many pilots have a "spoilers open during takeoff" warning? I believe
more pilots have died because of this than those that couldn't bail out
of a glider because the G forces were to great.
Here's a start on a safety equipment list, ordered by cost/benefit:
A list for the *Serious Cross-Country Pilot*
"spoilers open on takeoff" warning ($100)
parachute ($1200)
Roeger hook ($600 - my cost)
PCAS transponder detector ($450)
Transponder ($3000)
NOAH ($5000)
ELT ($1000 - 406 hz unit)
PLB ($200 - $500)
My list reflects my situation. I'm sure there should probably be several
lists that account for where you fly and the kind of flying you do. What
do other pilots think this list should include, where would you place
things in the list, and what pilots is it intended for?
Old September 11th 07, 11:47 PM posted to rec.aviation.soaring
Jim Vincent
Add:
Gear warning system $20
Condom $1.50
news:aZCFi.2495$rw3.2350@trndny04...
the list for me.
prioritize them by their cost/benefit ratio. Bill seems like a very safety
conscious pilot, so he probably is at the point where a NOAH system would
give him the most safety increase for the buck. I'll bet a lot, maybe
relatively few have purchased one. I know Schleicher offers retrofits for
more pilots have died because of this than those that couldn't bail out of
parachute ($1200)
Transponder ($3000)
NOAH ($5000)
PLB ($200 - $500)
Old September 12th 07, 12:09 AM posted to rec.aviation.soaring
Ian[_2_]
parachute ($1200)
Transponder ($3000)
NOAH ($5000)
PLB ($200 - $500)
The obvious omission:
Flarm (US $400 - $500). My first hand experience is that in terms of
cost/benefit, it belongs up with the chute, maybe even above it. Even if
you are fortunate enough not to need one of these devices, remember it
also offers protection for the other pilot who might not see you.
It is time someone developed a version that is accepted world wide and can
be fitted to power aircraft as well, while keeping the costs "VFR
affordable".
Ian
70 kg 31:1 glider is here to stay? Andre Volant Soaring 57 November 27th 04 12:21 PM
Region 1 Contest - will trade place to stay Quebec Tango Soaring 0 May 10th 04 04:17 PM
How Aircraft Stay In The Air Sarah Hotdesking Military Aviation 145 March 25th 04 06:13 PM
The Bud Light logo will stay Cub Driver Military Aviation 8 November 24th 03 02:08 AM
The Bud Light logo will stay Cub Driver Piloting 7 November 24th 03 02:08 AM
