#41
On Aug 5, 5:17 am, Stealth Pilot wrote: when I put new pads on earlier this year I broke one so I actually have one of the pads sitting 2inches from my space bar as I type. I calculated that it has a surface area of no more than 1.57 square inches. when you brake hard in the aircraft they get fitted to you are using no more than 6 and a quarter square inches of pad to stop a one thousand five hundred pound weight aircraft. as for standing on the brakes sure it can be done but at some considerable abuse to the braking systems. the concept is one of half m vee squared's worth of energy being converted to heat by 6 or so square inches of pad. Plenty of area to stop a 1500 lb airplane. As I said before, my 4500 lb car has brake pads that are no more than three times as large as the pads you have there, and those car brakes are used to stop the car from 80 MPH, are used on long downhills, are used hundreds of times every day in traffic, and so on. They're designed to do that. The light aircraft brakes are used to hold the airplane during runup and to stop it at the end of a taxi or landing roll, neither of which are anywhere near as brutal as the auto's brakes have to deal with. Many older light aircraft had pads even smaller, yet they worked just fine. The bigger issue is heat dissipaton from the disc, since excessive disc temperature will cause brake fade no matter how large the pads. Kinetic energy is transformed into heat, and when the discs are hot they can't absorb much more energy and will lose their effectiveness. Aircraft brakes are out in the breeze and get better cooling than car brakes. Occasional hard braking in your airplane won't hurt the brakes and will maybe keep the airplane out of the rhubarb. Brake pads are cheaper than airframe damage any day. Dan |
#42
#43
"Stealth Pilot" wrote in message ... the 3 lines above contain exactly the point I was making in my original post. the brakes in a light aircraft are not intended for decelerating an aircraft. Actually you just have to read the title of this thread, because you are the OP. What you said was light "aircraft brakes were never designed for stopping an aircraft", and you have been shown to be dead wrong. You can read the design requirements for USA certified light aircraft at 14 CFR part 23 Sec. 23.735. I am sure that the European standards are similar. You have tried to make this thread about piloting style, but your words which started this thread are quite different. We are discussing aircraft design, not piloting. Vaughn |
#44
On Aug 7, 4:57 am, Stealth Pilot wrote: slamming the brakes on during a normal landing is as frowned on as landing on the nose wheel. short field landings are only an occasional technique not to be used for every landing. And that's what Cessna and Transport Canada and a whole lot of instructors teach. You had insisted that brakes were only for holding and airplane that's already motionless, and that's not true at all. We could use simple axle locks for that, similar to the Park lock on an automatic transmission, not heat-creating friction brakes. Dan |
#45
On Thu, 07 Aug 2008 12:11:20 GMT, "Vaughn Simon"
wrote: "Stealth Pilot" wrote in message .. . the 3 lines above contain exactly the point I was making in my original post. the brakes in a light aircraft are not intended for decelerating an aircraft. Actually you just have to read the title of this thread, because you are the OP. What you said was light "aircraft brakes were never designed for stopping an aircraft", and you have been shown to be dead wrong. You can read the design requirements for USA certified light aircraft at 14 CFR part 23 Sec. 23.735. I am sure that the European standards are similar. You have tried to make this thread about piloting style, but your words which started this thread are quite different. We are discussing aircraft design, not piloting. Vaughn what you discuss is entirely up to you. my comment is that it is bad piloting technique to stop an aircraft on landing using the tiny brakes. it is better to use aerodynamic forces and the runway length to stop the aircraft. dan was waxing eloquent about stamping on the brakes on landing and I thought that his comments were a little amiss. poor technique in fact given the small size of the brakes involved. read into that whatever you will. btw wtf is 14 CFR etc etc ?? ....never mind we'll have to agree to disagree. Stealth Pilot |
#46
On Aug 10, 5:26*am, Stealth Pilot
wrote: On Thu, 07 Aug 2008 12:11:20 GMT, "Vaughn Simon" wrote: "Stealth Pilot" wrote in message .. . the 3 lines above contain exactly the point I was making in my original post. the brakes in a light aircraft are not intended for decelerating an aircraft. * Actually you just have to read the title of this thread, because you are the OP. *What you said was light "aircraft brakes were never designed for stopping an aircraft", and you have been shown to be dead wrong. *You can read the design requirements for USA certified light aircraft at 14 CFR part 23 Sec. 23.735. *I am sure that the European standards are similar. * You have tried to make this thread about piloting style, but your words which started this thread are quite different. *We are discussing aircraft design, not piloting. Vaughn what you discuss is entirely up to you. my comment is that it is bad piloting technique to stop an aircraft on landing using the tiny brakes. it is better to use aerodynamic forces and the runway length to stop the aircraft. dan was waxing eloquent about stamping on the brakes on landing and I thought that his comments were a little amiss. poor technique in fact given the small size of the brakes involved. read into that whatever you will. btw wtf is 14 CFR etc etc ?? ...never mind we'll have to agree to disagree. Stealth Pilot- Hide quoted text - - Show quoted text - You have the option of disagreeing with 99% of the people who know what brakes are for. Don't hold your breath waiting for someone to agree with your cockamamie theory. Harry K |
#47
"Stealth Pilot" wrote in message ... btw wtf is 14 CFR etc etc ?? So you haven't bothered to educate yourself? I thought not. Actually, I have told you what it is. The relevant passage can be on your screen seconds from now. Google is your friend. Vaughn |
#48
"Vaughn Simon" wrote in message
... "Stealth Pilot" wrote in message ... btw wtf is 14 CFR etc etc ?? So you haven't bothered to educate yourself? I thought not. Actually, I have told you what it is. The relevant passage can be on your screen seconds from now. Google is your friend. Well, he is from a place where the U.S. C.F.R. doesn't apply. But then, a significant percentage of the aircraft in the world were designed with those regulations in mind... Of course, now he is claiming it isn't a design issue, but a good piloting style issue - contrary to what was originally written. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
#49
On Sun, 10 Aug 2008 20:26:19 +0800, Stealth Pilot
wrote: my comment is that it is bad piloting technique to stop an aircraft on landing using the tiny brakes. it is better to use aerodynamic forces and the runway length to stop the aircraft. I've seldom had the pleasure to read bull**** of such a magnitude on the internet yet. Congratulations! You made my day! Bye Andreas |
#50
"Alan Baker" wrote in message ... In article , Stealth Pilot wrote: aircraft brakes were designed for use in holding the aircraft still while the engine was started. after the taxy out and the engine has warmed you do a run up check to make sure that the magneto circuits are up to the bit of work that lies ahead for them. the brakes are applied to hold the aircraft while the revs are bought up and each maggy checked in turn. from a design aspect that is the end of the use of a light aircraft's brakes until after landing and we wish to hold the aircraft still for shutdown and disembarkation. of course brakes are brakes and people will use them like they were driving cars. light aircraft brakes were never designed for slowing an aircraft when landing. I know that they get used for that by students of bad piloting technique but the design intent is a fact borne out by their diminutive size. Stealth Pilot Nonsense: complete and utter. What aircraft brakes aren't designed for is stopping aircraft *repeatedly*. The chief advantage of putting larger brakes on any vehicle is that it providess a greater heat sink to allow for more braking before the brakes overheat. Aircraft brakes need to be able to stop an aircraft *once* and then have an essentially infinite amount of time to cool down again. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg Right. Almost. Maybe..... My Stinson has 9 inch diameter drum brakes and has lots of area on the brakes, but low pressure applied. It uses a largish master cylinder to pump fluid into an "expander tube" under the brake shoes inside the drum. They work great for holding the airplane for runup and are essential for ground handling and taxiing because the tailwheel is a swivel and in not connected to anything that could allow it to be used for steering. As a result, all steering is by differential braking. You can apply the brakes on the landing roll and it will quickly slow the airplane. However, if you do so, you may not be able to leave the runway. Rubbing all that shoe area inside the drum makes it quite hot inside the drum. My little infrared laser guided remote reading thermometer gives temperatures in the 400 to 600 degree range. It takes a while to dissipate that heat from inside the drum and until it does the brake fluid inside the "expander tube" gets quite warm. When it does it expands and the brakes tend to remain quite "ON" until things cool down. Even a long and complicated taxi, like into a parking spot at Oshkosh, will generally result in a noticeable loss of "differential" in the braking activity and a substantial increase in the power required to taxi. I have found that it is wise to NOT attempt a takeoff if it requires over 1000 RPM to maintain a reasonable taxi speed. :-) Of course, this airplane weighs generally two tons and lands at 70 mph at touchdown in a three point attitude. :-) The general limiting factor in ALL aircraft brakes is heat dissipation. The wheels are relatively small and the brakes are in a small space. The more effective the brakes are, the more heat they produce. All that energy they are dissipating when they slow you down has to go somewhere. Thermodynamics tells us that most wasted energy appears as heat! Randomized molecular activity. :-) To stop the airplane you have to waste the energy. 1/2 M V^2. You can't get around it. Fortunately, a taildragger with the flaps down and the tail on the ground takes a LOT of energy to keep moving, so you can waste a lot of the energy you have to get rid of by stirring up the air. Then apply the brakes to turn off the runway after you have slowed down without them. FWIW Department. You scrape a lot more rubber off you tires by landing and applying brakes vigorously while little weight is on the wheels than you would in many many miles of taxiing around or rolling out with the brakes off! :-) Highflyer Highflight Aviation Services Pinckneyville Airport (PJY) |
| Thread Tools | |
| Display Modes | |
| Aircraft parts FS Cleveland Whels Brakes & Discs ! | Victor Bravo | Home Built | 1 | August 18th 07 05:00 PM |
| Aircraft parts FS Cleveland Whels Brakes & Discs ! | Victor Bravo | Aviation Marketplace | 1 | August 18th 07 05:00 PM |
| Commercial rating: complex aircraft required aircraft for practical test? | Marc J. Zeitlin | Piloting | 22 | November 24th 05 05:11 AM |
| Intended stopping point | W.J. \(Bill\) Dean \(U.K.\). | Soaring | 0 | February 17th 05 03:04 AM |
| Experience transitioning from C-172 to complex aircraft as potential first owned aircraft? | Jack Allison | Owning | 12 | June 14th 04 09:01 PM |
