Preheater
Old November 4th 03, 06:34 AM
Tony Roberts
Default Preheater
Hi
I'm looking for a preheater for my 172.
I don't have a power source near my tiedown.
I don't own a generator.
Because of all of the above I'm looking for a propane powered preheater
but I can't find one.
Any recommendations? Any reason why I shouldn't buy a propane one.
Thanks
Tony Roberts )
PP-ASEL
VFR-OTT - Night
Cessna 172H
Old November 4th 03, 10:46 AM
Roger Long
We have a 300 watt oil pan heater and the engine starts much better and oil
temperature comes up faster than when we used the FBO's dragon. The size
and weight of a portable generator that would power one of these is similar
to the size and weight of a dragon. Why not buy the generator which would
have all sorts of other uses?
Roger Long
Old November 4th 03, 02:24 PM
Jay Honeck
oil
similar
It's much easier on the fiberglass cowling, too. (I actually bubbled the
paint on a rental bird, using one of those "stick it in the cowling" jet
engine heaters...)
However, it doesn't warm the cylinders at all.
I wonder if a portable generator could power the cylinder warmers, too?
We've got the oil pan and cylinder warmers, and the oil is usually warmer
when we start up in winter (verified with our digital oil temperature gauge)
than it is in spring and fall.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old November 4th 03, 02:39 PM
Jay Masino
Shouldn't be a problem. If I remember right, my cylinder warmers were
about 50 watts a piece. And, although I don't have the pan heater, I
think they're usually about 150 watts. So the max, on a 6 cyl, would be
about 450 watts. I think that's well within the capabilities of even
small generators. I would think the big pain in the butt would be that
fact that it takes electric warmers a reasonable length of time to warm
the engine, which means th generator would be sitting their running for
many hours.
-- Jay
__!__
http://www2.ari.net/jmasino/ ! ! !
Checkout http://www.oc-adolfos.com/
for the best Italian food in Ocean City, MD and...
Checkout http://www.brolow.com/ for authentic Blues music on Delmarva
Old November 4th 03, 03:41 PM
That's true... just about the smallest generator would be fine to
power a plane or two. For a 20 degree day, plugging the plane in for 3
hours or so typically seems to bring it up to warm to the touch. That's
only 1.5 kWh of juice, so it's roughly $0.25 worth of gasoline for a
generator.
Seems to make more sense than a portable preheater. Also, I've
read that the flame-thrower type (expecially the propane bottle ones)
don't put enough heat in the right places to help prevent cylinder
scuffing. Leaving a multi-point heater plugged in for a few hours is the
best, and the generator has many more uses elsewhere.
-Cory
Jay Masino wrote:
: Shouldn't be a problem. If I remember right, my cylinder warmers were
: about 50 watts a piece. And, although I don't have the pan heater, I
: think they're usually about 150 watts. So the max, on a 6 cyl, would be
: about 450 watts. I think that's well within the capabilities of even
: small generators. I would think the big pain in the butt would be that
: fact that it takes electric warmers a reasonable length of time to warm
: the engine, which means th generator would be sitting their running for
: many hours.
: -- Jay
: __!__
: Jay and Teresa Masino ___(_)___
: http://www2.ari.net/jmasino/ ! ! !
: Checkout http://www.oc-adolfos.com/
: for the best Italian food in Ocean City, MD and...
: Checkout http://www.brolow.com/ for authentic Blues music on Delmarva
* The prime directive of Linux: *
* - learn what you don't know, *
* - teach what you do. *
* (Just my 20 USm$) *
Old November 4th 03, 03:54 PM
Jay Honeck
Of course, the rub is turning the danged thing on 3 hours in advance. Didn't
someone rig up a "cell-phone-on/off-trigger" for their pre-heater last year?
I remember thinking it was way cool, for those who don't have a hangar with
electricity. (If you have a hangar, the best trigger, IMHO, is the
temperature-sensitive cubes. They go "On" at 35 degrees, "Off" at 40
degrees...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old November 6th 03, 12:31 AM
Ray Andraka
I have the Reiff cylinder heaters and oil sump heater. Mine are for the narrow
deck engine, so each cylinder heater is 50W. I think the sump heater is 300W,
so for my Six, a generator capable of at least 600W should work fine. I think
most of the portable generators are good for about 1000W.
oil
similar
engine heaters...)
Jay Honeck
Iowa City, IA
Pathfinder N56993
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old November 10th 03, 08:48 PM
Steven P. McNicoll
"Ray Andraka" wrote in message
narrow deck engine, so each cylinder heater is 50W. I think the sump
heater is 300W, so for my Six, a generator capable of at least 600W
should work fine. I think most of the portable generators are good for
about 1000W.
I purchased a Hot Padd heater from Reiff. The heater could not be mounted
on my engine in accordance with the supplied instructions, so I made do as
best I could. The adhesive didn't cure and the pad easily peeled off. I
returned the pad to Reiff for a refund, they sent it back to me with more
adhesive. Apparently I violated the warranty by not following the
instructions to the letter, (the fact that it was impossible to follow them
was of no interest to Reiff). I don't know if the Reiff heater is any good
or not, I do know that their product support and customer relations are
terrible. I won't do business with them again.
I purchased a "milkhouse heater" and some ductwork at a local home
improvement store. The cost was about $35 and it does a fine job.
Old November 4th 03, 04:13 PM
Kyler Laird
"Roger Long" om writes:
I second the generator idea. Electric heaters are *so* handy. You can
even put some in your cabin to keep your seat and instruments warm. If
you run the generator off of 100LL, you won't have to mess with carrying
(other) tanks of fuel. I'd feel a lot better about leaving a generator
running (for a day trip) than leaving a Dragon running too.
The Red Dragon *without* fuel tank is a little lighter than a generator
(16-22 vs. 29 pounds) but it requires electrical power. In the cold,
I'd much rather leave something running that's charging, not
discharging, my plane's battery. Small generators often have 12VDC
outputs
http://www.mayberrys.com/honda/gener...ls/eu1000i.htm
so if your plane has a 12V system, you're all set.
I've checked with a few FBOs about plugging in my plane on the ramp
when we travel. The answers range from "Sure, no problem" to "Bring
your own extension cord." That means you'd usually be able to avoid
having to deploy the generator.
So...do you want to lug around a tank of LP, mess with connecting a
heater to your engine and battery and then run down your battery, or
would you rather drain a little fuel into a generator, plug it in,
and await a warm cockpit and freshly-charged battery?
--kyler
Lycoming intake preheater Dale Larsen Home Built 5 June 6th 04 10:32 PM
